06-29-2016, 17:55 | #1 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 420820 Status: Offline Thanks Meter: 71 | SL3 Hash Read Nokia 301 cant detect I am trying to unlock a Nokia 301 by reading log for BF, but cant get phone to detect via USB. Have logged into ATF network and try and authorise BB5 but phone just shows as charging and just keep getting the following; Code: Booting Phone via USB... ====================================================== ====================================================== USB Phone BUSCheck Boot ====================================================== ====================================================== Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ====================================================== Unable to detect "Nokia USB Flashing Generic" ERROR: Boot Failed! Code: Booting Phone via USB... ====================================================== ====================================================== USB Phone BUSCheck Boot ====================================================== ====================================================== Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ====================================================== Unable to detect "Nokia USB Flashing Generic" ERROR: Boot Failed! I am new to the box, is there something im doing wrong? Have read FAQ section and followed all instructions but can not get it to work for last couple of days. Thanks in advance BR |
07-04-2016, 11:35 | #4 (permalink) | |
Member: 420820 Status: Offline Thanks Meter: 71 | Quote:
Modem mode Sync and connect Memory card Im assuming sync and connect is the same, have tried both modes with phone on and then following instructions, removing USB cable and battery and putting back but each time phone just jumps into charging mode BR | |
07-05-2016, 12:00 | #5 (permalink) |
Member: 420820 Status: Offline Thanks Meter: 71 | Ok have managed to get phone to connect using a different PC, but always fails reading halfway through, the phone does not have pc suite or ovi mode option when i connect USB, just the following options; Modem mode Sync and connect Memory card Have tried both "modem" mode and "sync and connect" mode but keep getting read failed; Code: Booting Phone via USB... ====================================================== ====================================================== USB Phone BUSCheck Boot ====================================================== ====================================================== Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ====================================================== Infineon Boot: F01650A9070100030101E0200C12001CF7D2582A99B4FFFF CPU Type: Intel XG618 <<<< Connect Battery Now >>>> Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Unique Data: E0200C12001CF7D2 Original Product Code: 059T622 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\35174********\351744********_115528.rpl Infineon USB Buscheck Done Phone Restart Mode: TEST MODE Process Done... Scanning USB Ports... ====================================================== ERROR: Active Phone Handle was NOT DETECTED ====================================================== TIP: Make sure that Phone USB Connection Mode is OVI Suite Mode or PC Suite Mode ====================================================== ERROR: Read Phone Failed! Thanks in advance BR |
10-21-2017, 08:50 | #8 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: FMI OF Age: 52
Member: 866455 Status: Offline Sonork: SAMSUNG CPID ONLINE Thanks Meter: 579 | Quote:
install and fixed | |
10-21-2017, 11:56 | #9 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | ok thx sir but here is where i always fail. can't detect phone at dead mode why? Quote:
