Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 02-07-2013, 09:29   #1 (permalink)
Member: 1576733
Thanks Meter: 622
SL3 Nokia 5130 Config 000000 is Possible to repair by ATF BOX ??? < SOLVED >
Actually Problem was Blinking. Security Test Failed. I have written RPL without NPC now problem is Config Key 000000000.
What should i do for this. If this is possible by ATF Box.
Note: My ATF Box has not activated yet.
Diosa
Old 02-07-2013, 10:03   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
What is your problem with Config key ?
Br - srinibas
Old 02-07-2013, 10:11   #3 (permalink)
munnabhi's Avatar
Member: 1299626
Sonork: 100.1625198
Thanks Meter: 77
your prob.....................bro
Old 02-07-2013, 16:07   #4 (permalink)
Member: 1576733
Thanks Meter: 622
Bro,
Mobile ON and we can see NOKIA logo and it goes White. After 10 to 20 second it goes completely off.
Previously problem was Security Test Failed. But I have write RPL without NPC from Advance Box Folder, then, the Config Key 0000000000000000000. May be the reason...it goes off after showing Nokia logo and then white Screen.
Any Solution Bro?
Diosa
Old 02-07-2013, 20:04   #5 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Originally Posted by diosa View Post
Bro,
Any Solution Bro?
Diosa
Hi, try to flash phone first....
Old 02-07-2013, 20:41   #6 (permalink)
Member: 497508
Thanks Meter: 23
Mau be hard ware proplem
Old 02-08-2013, 03:45   #7 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: Kfe~Labs Co.-
Thanks Meter: 568
Bro,
Any Solution Bro?
Diosa
1)Make bkp simlock and rpl (full rpl and npc)
2) Save Full PM
3)Full erase
4) Write rpl and crt
5) Flash phone with a 7.95 version and post log (if fail write pm xs4 server) For DCC File problem u whachdog timer
Paste Log process (yes, is a downgrade)
Polaco
Old 02-10-2013, 06:04   #8 (permalink)
Member: 1576733
Thanks Meter: 622
@el-poleko Bro,
Backup PM not possible, shows error.
Flashing Logs :
10:34:27 : Advance Turbo Flasher Found
10:34:27 : ================================================
10:34:27 : Driver Version : 00020824
10:34:27 : Library Version : 00030207
10:34:29 : Box Type : AdvanceBox Turbo
10:34:29 : Box Firmware : LogiCore 10.3.30
10:34:29 : Software Version : v9.50
10:34:29 : AdvanceBox SN : ******************
10:34:29 : Box Status : ACTIVATED
10:34:29 : ================================================
10:34:29 : Box Successfully Initialized
10:34:29 :
10:34:29 : VBATT Powering Down <<<<
10:34:33 : VBATT Powering Up >>>>
10:34:33 : SET VCCIO Level Done
10:34:33 : SET BSI Load Done
10:34:33 :
10:34:33 :
10:34:33 :
10:34:33 : ///////// /// /// /////// /////// /////////
10:34:33 : /// /// /// /// // /// /// /// ///
10:34:33 : /// /// /// /////// /////// /// ///
10:34:33 : /// /// /// /// /// /// /// /// ///
10:34:33 : /// ///// /// /// /////// //////
10:34:33 :
10:34:33 : =======================================
10:34:33 : /// /// /// ///////// /////// //////
10:34:33 : ///// /// /// /// /// // /// ///
10:34:33 : /// ///// /// /// /////// /// ///
10:34:33 : /// //// /// /// /// /// /// ///
10:34:33 : /// /// /// /// /// /// //////
10:34:33 :
10:34:37 :
10:34:37 :
10:34:37 : ================================================
10:34:37 : Basic Phone Information
10:34:44 :
10:34:44 : ================================================== ====
10:34:44 : Selected VPL File:
10:34:44 : RM495_0575345_07.97_033.vpl
10:34:44 : Variant Details : RM-495_CTR_SEAP_MR_AQUA_LATIN_NEPAL-SA
10:34:44 : Software Version : 07.97
10:34:44 : Product Type : RM-495
10:34:44 : Product Code : 0575345
10:34:44 : Variant Version : 033
10:34:44 :
10:34:53 :
10:34:53 : ================================================== ====
10:34:53 : Flash File Checksum Verification
10:34:54 : rm495__07.97.mcusw: CHECKSUM PASSED
10:34:54 : rm495__07.97.ppm_mr: CHECKSUM PASSED
10:34:54 : rm495__07.97.image_mr_red: CHECKSUM PASSED
10:34:54 : ================================================== ====
10:34:54 : Verification Done...
10:34:55 : ATF Software Version v9.50
10:34:55 : ATF Box FBUS Flash Started...
10:34:55 :
10:34:55 : Number of Image Files: 3
10:34:55 :
10:34:55 : Processing Image File :
10:34:55 : C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.mcusw
10:34:55 : CMT Type : BB5
10:34:55 : CMT Algorithm : BB5 ALGORITHM
10:34:55 : Secondary Sending Speed : 3250000 Hz
10:34:55 : Algorithm Sending Speed : 6500000 Hz
10:34:55 : Program Sending Speed : 6500000 Hz
10:34:55 : Message Reading Speed : 98000 Hz
10:34:55 : Number of Blocks : 1178
10:34:55 : Entry Point : 0x5057
10:34:55 : Page Format : 128K
10:34:55 : Maximum Page Size : 0x00004000
10:34:55 :
10:34:55 : Changing MODE : FLASH
10:34:56 : Booting Phone via FBUS...
10:34:56 :
10:34:58 : VBATT Powering Down <<<<
10:35:02 : VBATT Powering Up >>>>
10:35:02 : SET VCCIO Level Done
10:35:02 : SET BSI Load Done
10:35:02 :
10:35:02 : AdvanceBox SendBootCodeEx
10:35:02 : InitialiseBootstrap_DCT5 DIR
10:35:02 : BootFlashMode_DCT5
10:35:02 :
10:35:02 : ************************************************** ****
10:35:02 : TIME STARTS HERE
10:35:02 :
10:35:02 : BootFlashModeDCT5Ex Succeeded after 3 Attempts
10:35:02 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
10:35:02 : Number of Sub Blocks 7 (0x07)
10:35:02 : 1 SYSTEM_ASIC_ID 01
10:35:02 : Block Length : 21 (15)
10:35:02 : BB ASIC Index : 0 (00) CMT
10:35:02 : ID DWORD 0 : 00000001
10:35:02 : ID DWORD 1 : 00000226
10:35:02 : ID DWORD 2 : 00010006
10:35:02 : ID DWORD 3 : 030C1921
10:35:02 : ID DWORD 4 : 01033000
10:35:02 : 2 EM_ASIC_ID 02
10:35:02 : Block Length : 5 (05)
10:35:03 : BB ASIC Index : 0 (00) CMT
10:35:03 : ID DWORD 0 : 00000296
10:35:03 : 3 EM_ASIC_ID 02
10:35:03 : Block Length : 5 (05)
10:35:03 : ID DWORD 0 : 00000B22
10:35:03 : 4 PUBLIC_ID 12
10:35:03 : Block Length : 21 (15)
10:35:03 : ID DWORD 0 : 04400105
10:35:03 : ID DWORD 1 : 62090556
10:35:03 : ID DWORD 2 : 5A1B7134
10:35:03 : ID DWORD 3 : D92380FD
10:35:03 : ID DWORD 4 : 3103BC6C
10:35:03 : 5 ASIC_MODE_ID 13
10:35:03 : Block Length : 2 (02)
10:35:03 : Mode Id : 00
10:35:03 : 6 ROOT_KEY_HASH 14
10:35:03 : Block Length : 17 (11)
10:35:03 : Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
10:35:03 : 7 ROM_ID 15
10:35:03 : Block Length : 9 (09)
10:35:03 : CRC 0 : 273F6D55
10:35:03 : CRC 1 : DFAAF68F
10:35:03 : Checksum A6
10:35:03 :
10:35:03 : SearchForBootstrap_DCT5..
10:35:03 : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
10:35:03 : Boot File - Version 010.042.00
10:35:03 : Boot File - Revision 0x0000 (0)
10:35:03 : eBB5ProtocolType == Original
10:35:03 : SearchForBootstrap_DCT5 : No Error - 0 (0x00)
10:35:03 : Secondary Loader Sent...
10:35:03 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
10:35:03 : MCU_CONFIGURATION_RESPONSE_BB5:
10:35:03 : MessageID : 03
10:35:03 : SubBlocks : 03
10:35:03 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
10:35:03 : Block Length : 0B
10:35:03 : BB ASIC Index : CMT 00
10:35:03 : Device Type : NOR 00
10:35:03 : Device Index : 00
10:35:03 : Manufacturer Code : 0089 ->
10:35:03 : Device ID : 8982 -> NU48F512
10:35:03 : Extended/Fixed ID : 0000
10:35:03 : Revision ID : 8A31
10:35:03 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
10:35:03 : Block Length : 13
10:35:03 : Device Contents : 00000000000000000000
10:35:03 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
10:35:03 : Device Type : MMC 04
10:35:03 : Manufacturer Code : FFFF -> Flash
10:35:03 : Device ID : 0000 -> BAD FLASH TYPE
10:35:03 : Revision ID : 0000
10:35:03 : Checksum : 51
10:35:03 : FLS1SendAlgoCodeEx..
10:35:03 : SendAlgoCode_DCT5..
10:35:03 : SearchForAlgorithm_DCT5..
10:35:03 : Looking for ALL Devices...
10:35:03 : Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
10:35:03 : Flash Descriptor
10:35:03 : Size : 04000000 (64 MB)
10:35:03 : VPP Info : 0009
10:35:03 : Erase10s : 28
10:35:03 : Block1s : 64
10:35:03 : BErase1s : 02
10:35:03 : Reserved0 : 00
10:35:03 : Reserved1 : 00
10:35:03 : Reserved2 : 00
10:35:03 : VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
10:35:03 : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
10:35:03 : Algorithm File - Version 010.040.00
10:35:03 : Algorithm File - Revision 0x0000 (0)
10:35:03 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
10:35:03 : TransmissionTypeRequest_DCT5...
10:35:03 : SuggestedType : 01 16BIT
10:35:03 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
10:35:03 : ReturnedType : 01 16BIT
10:35:03 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
10:35:03 :
10:35:03 : Uploading ALGO File...
10:35:04 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
10:35:04 :
10:35:04 : ============================================
10:35:04 : OLD Protocol Detected... Using Turbo Mode...
10:35:04 :
10:35:04 : PAPUB_KEYS_HASH_REQ_BB5
10:35:04 : PhoneInfoRequest_BB5 (Asic Index 00 )
10:35:04 : PHONE_INFO_RESPONSE_BB5
10:35:04 : PAPUB_KEYS_HASH_RESP_BB5 2A
10:35:04 : BB Asic Index : 00
10:35:04 : CMT PAPUBKEYS HASH:
10:35:04 : 0C917F11196FDB7378C18EF7260698CA4489DCA0
10:35:04 :
10:35:04 : Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
10:35:04 : Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
10:35:04 : Certificate 1
10:35:04 : Name : NPC
10:35:04 : ASIC Index : CMT 0
10:35:04 : Certificate 2
10:35:04 : Name : VARIANT
10:35:04 : Certificate 3
10:35:04 : Name : R&D
10:35:04 : Certificate 4
10:35:04 : Name : CCC
10:35:04 : Certificate 5
10:35:04 : Name : HWC
10:35:04 : STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
10:35:04 : STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
10:35:04 : VPP Enabled by Software
10:35:04 : Using Internal VPP
10:35:04 : StartErase_DCT5...
10:35:04 : BlockLength : 0x36 (54)
10:35:04 : ERASE Blocks : 0x01 (1)
10:35:04 : 0 ERASE_AREA_BB5 0x12
10:35:04 : Block Length : 0x33 (51)
10:35:04 : BB ASIC Index : 0x00 CMT
10:35:04 : Device Type : 0x00 NOR
10:35:04 : Device Index : 0x00
10:35:04 : 0 : 00000000-000006BF
10:35:04 : 1 : 000006C0-0001FFFF
10:35:04 : 2 : 00040000-000BFFFF
10:35:04 : 3 : 000C0000-0013FFFF
10:35:04 : 4 : 00140000-0137FFFF
10:35:04 : 5 : 01380000-0151FFFF
10:35:04 :
10:35:04 : Erase_SendEraseBlock_BB5_NOR
10:35:04 : Task in Progress... Please Wait...
10:36:59 : STATUS_REQUEST_BB5...
10:36:59 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
10:36:59 : Block Length : 01
10:36:59 : BB ASIC Index : 00
10:36:59 :
10:36:59 : Successfully erased..
10:36:59 : Time Taken to Erase : 00:01:54
10:36:59 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
10:36:59 : ReturnedType : 04 DDR & 2TX
10:36:59 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
10:36:59 :
10:36:59 : Flashing Speed: 5.00 Mhz
10:36:59 : Processing : rm495__07.97.mcusw
10:36:59 : Total blocks to write : 1178
10:36:59 : ================================================
10:36:59 : FBUS Cable RX2 PIN Diagnostics
10:36:59 : INFO: RX2 PIN is OK
10:36:59 : >> CMT Rootkey Hash CERT : NOLO
10:37:00 : >> CMT Rootkey Hash CERT : KEYS
10:37:00 : >> CMT Rootkey Hash CERT : PRIMAPP
10:37:00 : >> CMT Rootkey Hash CERT : PASUBTOC
10:37:04 : >> CMT Rootkey Hash CERT : PAPUBKEYS [0C917F11196FDB7378C18EF7260698CA4489DCA0]
10:37:04 : >> CMT Rootkey Hash CERT : UPDAPP
10:37:05 : >> CMT Rootkey Hash CERT : DSP0
10:37:08 : >> CMT Rootkey Hash CERT : MCUSW
10:37:48 : ContinueFlash_DCT5 Complete
10:37:48 : STATUS_REQUEST_BB5...
10:37:48 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
10:37:48 : Block Length : 01
10:37:48 : BB ASIC Index : 00
10:37:48 : Continue Flash Complete : : No Error - 0 (0x00)
10:37:48 : Time Taken to Flash : 00:00:48
10:37:48 :
10:37:48 : Processing Image File :
10:37:48 : C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.ppm_mr
10:37:48 : CMT Type : BB5
10:37:48 : CMT Algorithm : BB5 ALGORITHM
10:37:48 : Secondary Sending Speed : 3250000 Hz
10:37:48 : Algorithm Sending Speed : 6500000 Hz
10:37:48 : Program Sending Speed : 6500000 Hz
10:37:48 : Message Reading Speed : 98000 Hz
10:37:48 : Number of Blocks : 470
10:37:48 : Entry Point : 0x00BE
10:37:48 : Page Format : 128K
10:37:48 : Maximum Page Size : 0x00004000
10:37:48 :
10:37:48 : VPP Enabled by Software
10:37:48 : Using Internal VPP
10:37:48 : StartErase_DCT5...
10:37:48 : BlockLength : 0x0E (14)
10:37:48 : ERASE Blocks : 0x01 (1)
10:37:48 : 0 ERASE_AREA_BB5 0x12
10:37:48 : Block Length : 0x0B (11)
10:37:48 : BB ASIC Index : 0x00 CMT
10:37:48 : Device Type : 0x00 NOR
10:37:48 : Device Index : 0x00
10:37:48 : 0 : 01520000-01DBFFFF
10:37:48 :
10:37:48 : Erase_SendEraseBlock_BB5_NOR
10:37:48 : Task in Progress... Please Wait...
10:38:32 : STATUS_REQUEST_BB5...
10:38:32 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
10:38:32 : Block Length : 01
10:38:32 : BB ASIC Index : 00
10:38:32 :
10:38:32 : Successfully erased..
10:38:32 : Time Taken to Erase : 00:00:44
10:38:32 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
10:38:32 : ReturnedType : 04 DDR & 2TX
10:38:32 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
10:38:32 :
10:38:32 : Flashing Speed: 5.00 Mhz
10:38:32 : Processing : rm495__07.97.ppm_mr
10:38:32 : Total blocks to write : 470
10:38:51 : ContinueFlash_DCT5 Complete
10:38:51 : STATUS_REQUEST_BB5...
10:38:51 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
10:38:51 : Block Length : 01
10:38:51 : BB ASIC Index : 00
10:38:51 : Continue Flash Complete : : No Error - 0 (0x00)
10:38:51 : Time Taken to Flash : 00:00:18
10:38:51 :
10:38:51 : Processing Image File :
10:38:51 : C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.image_mr_red
10:38:51 : CMT Type : BB5
10:38:51 : CMT Algorithm : BB5 ALGORITHM
10:38:51 : Secondary Sending Speed : 3250000 Hz
10:38:51 : Algorithm Sending Speed : 6500000 Hz
10:38:51 : Program Sending Speed : 6500000 Hz
10:38:51 : Message Reading Speed : 98000 Hz
10:38:51 : Number of Blocks : 664
10:38:51 : Entry Point : 0x00D0
10:38:51 : Page Format : 128K
10:38:51 : Maximum Page Size : 0x00004000
10:38:51 :
10:38:51 : VPP Enabled by Software
10:38:51 : Using Internal VPP
10:38:51 : StartErase_DCT5...
10:38:51 : BlockLength : 0x16 (22)
10:38:51 : ERASE Blocks : 0x01 (1)
10:38:51 : 0 ERASE_AREA_BB5 0x12
10:38:51 : Block Length : 0x13 (19)
10:38:51 : BB ASIC Index : 0x00 CMT
10:38:51 : Device Type : 0x00 NOR
10:38:51 : Device Index : 0x00
10:38:51 : 0 : 01DC0000-0215FFFF
10:38:51 : 1 : 02160000-03FBFFFF
10:38:51 :
10:38:51 : Erase_SendEraseBlock_BB5_NOR
10:38:51 : Task in Progress... Please Wait...
10:40:29 : STATUS_REQUEST_BB5...
10:40:29 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
10:40:29 : Block Length : 01
10:40:29 : BB ASIC Index : 00
10:40:29 :
10:40:29 : Successfully erased..
10:40:29 : Time Taken to Erase : 00:01:38
10:40:29 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
10:40:29 : ReturnedType : 04 DDR & 2TX
10:40:29 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
10:40:29 :
10:40:29 : Flashing Speed: 5.00 Mhz
10:40:29 : Processing : rm495__07.97.image_mr_red
10:40:29 : Total blocks to write : 664
10:40:57 : ContinueFlash_DCT5 Complete
10:40:57 : STATUS_REQUEST_BB5...
10:40:57 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
10:40:57 : Block Length : 01
10:40:57 : BB ASIC Index : 00
10:40:57 : Continue Flash Complete : : No Error - 0 (0x00)
10:40:57 : Time Taken to Flash : 00:00:27
10:40:57 :
10:40:57 : Total Flash Write Time (Flashing Only) : 00:01:35
10:40:57 : Total Flashing Time (Booting + Erase + Flashing) : 00:05:52
10:40:57 :
10:41:08 :
10:41:08 : Waiting for Phone to Go Online...
10:41:09 : Elapsed Time: 1s
10:41:10 : Elapsed Time: 2s
10:41:11 : Elapsed Time: 3s
10:41:12 : Elapsed Time: 4s
10:41:13 : Elapsed Time: 5s
10:41:14 : Elapsed Time: 6s
10:41:15 : Elapsed Time: 7s
10:41:16 : Elapsed Time: 8s
10:41:17 : Elapsed Time: 9s
10:41:18 : Elapsed Time: 10s
10:41:18 :
10:41:18 : ================================================
10:41:18 : Basic Phone Information
10:41:18 : MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia
10:41:18 : IMEI Plain : 357885040515093
10:41:18 : IMEI Spare : A357885040515090
10:41:18 : IMEI SV : 33578850405150958F
10:41:18 : Phone Model: Nokia 5130c-2
10:41:18 : Category : Classic Phone
10:41:18 : Phone Type : RM-495
10:41:18 :
10:41:18 : Extended Phone Information
10:41:18 : Product Serial Number: 1B3A821AH
10:41:18 : Product Code : 0576616
10:41:18 : Module Code : 0204024
10:41:19 : Basic Production Code: 0567772
10:41:19 : Long Production SN : 0
10:41:19 : PPM SW Version : V 07.97 13-09-10 RM-495 (c) Nokia MR
10:41:19 : BT MCM Version : 2222-302
10:41:19 : MCU SW Version : V 07.97 13-09-10 RM-495 (c) Nokia
10:41:19 : HW Version : 1005
10:41:20 : RFIC Version : 06560601
10:41:20 : DSP Version : ICPR72_10w01
10:41:20 : LCD Version : SEIKO
10:41:21 : Content Pack Version : Content: mr_red V 07.97 13-09-10 RM-495 (c) Nokia
10:41:21 : AHNE Version : 30
10:41:21 : RETU Version : 16
10:41:21 : TAHVO Version : 22
10:41:21 : Bluetooth ID : D4:C1:FC:015:A4
10:41:22 : CS Type : GSM850, GSM900, GSM1800, GSM1900
10:41:22 :
10:41:22 : ================================================
10:41:22 : Simlock Information
10:41:22 : CONFIG KEY : 0000000000000000
10:41:22 : PROVIDER KEY : 2440700000000000
10:41:22 : NETWORK NAME : Nokia Default;Finland
10:41:22 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
10:41:22 : SIMLOCK TABLE :
10:41:22 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
10:41:22 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
10:41:22 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
10:41:22 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
10:41:22 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
10:41:22 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
10:41:22 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
10:41:22 : SIMLOCK STATE : Not Locked
10:41:22 :
10:41:23 : SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
10:41:23 : SIMLOCK_TEST : PASSED
10:41:23 : SECURITY_TEST : PASSED
10:41:23 : SECURITY_CODE : 12345
10:41:23 : PHONE_MODE : TEST
Diosa
Old 02-10-2013, 06:13   #9 (permalink)
Member: 1576733
Thanks Meter: 622
Please Check the Picture
Old 02-10-2013, 08:44   #10 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 385
bro change ear peace of fone i think ur problem will b solve
Old 02-10-2013, 08:58   #11 (permalink)
Member: 1576733
Thanks Meter: 622
@GSM.SOLVE,
Thankx for Solution. Problem Solved. Unbelievable.
Diosa
Page generated in 0.25132 seconds with 8 queries
