03-29-2013, 15:41 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | slim box after update again says update ur box <<< SOLVED >>> Big ATF box updated ok without any problem slim box after update again says update ur box |
03-29-2013, 17:14 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | 1. Make sure no other gsm box connected to your PC 2. Make sure atf box not connected to your pc 3. Run ATF software, it will say box not found 4. Go to product support ---> box tools and select Correct box type 5. Now connect ATF Box to usb port 6. Click restore box If you get same error code 6, then you need to this means you need to check legs of IC in your Box as some legs nog connected to pcb. |
03-29-2013, 17:45 | #5 (permalink) | |
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
Advance-Box Secure AES-128 Channel Open Port Success... Error return code 6 Error return code Elapsed time = 00:00:01 on old atf version this box working ok but cant update why ??? | |
03-30-2013, 06:13 | #6 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
04-01-2013, 10:29 | #7 (permalink) | |
thats why posted here also followed those steps but still same now what should i do ?????? | |
05-16-2013, 08:21 | #9 (permalink) |
Freak Poster Join Date: Oct 2005 Location: pakistan Age: 40
Member: 189855 Status: Offline Thanks Meter: 31 | i tried above instructions but got error code 25 Initializing Target Device... Advance-Box Secure AES-128 Channel Open Port Success... Error return code 25 Error return code Elapsed time = 00:00:00 |
07-19-2013, 15:18 | #11 (permalink) | |
and goes fine old software has bug in it after many months i got my lsim box working again thanx to ATF team for fixing the bug in the new update ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 10.3.50 Software Version : v9.90 AdvanceBox SN : 93DF929F8E4FD8678F1F6681 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done | |
