Hi,
Phone dead during downgrading from 5.0.2 to 4.4.4, Flash was complete with ok report in Odin, it shows " Nokia Emergency connectivity in device manager , I find its testpoint on the board , here is emmc scan report
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 150100514E5730304D00F71CC8308173
CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Boot Information
Revision 1.0 (for MMC v4.0)
BOOT PARTITION : NOT BOOT ENABLED
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 0 KB
HC ERASE GROUP SIZE: 0 KB
USER AREA SIZE : 0 BYTES
BOOT PARTITION SIZE: 0 KB
RPMB PARTITION SIZE: 0 KB
eMMC Device Information
Manufacturer ID: SAMSUNG
Device Type : Embedded BGA
Application ID : 00
Product Name : QNW00M
Product Rev : 0.0
Product SN : F71CC830
Manufactured : January 1998
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 13 ns
TRAN_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
150100514E5730304D00F71CC8308173.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
Mount emmc chip logs
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 13 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
Dumping Custom Region
Please wait for some time...
Partition Selected: USER AREA
(eMMC Clock 7500000 Hz)
Custom Block Read OK
File Saved: C:\AdvanceBox Turbo Flasher\eMMC\Recovered\eMMC_GPT.bin
Total Elapsed Time 00:00:00
EFI Partition Table Header
ERROR: MBR + GPT Cannot be found!
GUID Partition Table cannot be Extracted
Sir Angel give me following files to write on it
BL_G530HXXU2BOJ3_CL845381_QB6587618_REV00_user_low _ship_MULTI_CERT.tar.md5
FORTUNA3G_EUR_OPEN.pit
MSM8x16_8x39_boot_recovery.pit
but no success, here are logs of writing these files
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 13 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
MBR is Corrupted...
Start Writing Flash Images...
Flash Image: MBR + PGPT
Start Writing 0x00000032 Blocks at 0x00000000
R1b Timeout Error!
R1b Timeout Error!
R1b Timeout Error!
any suggestion or tip?
I use both latest and 12.34 versions to solve issue but no luck
Urgent help will highly apprecieated
thanks
regards
