11-28-2015, 22:21 | #17 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Poland, Sroda Wielkopolska
Member: 608500 Status: Offline Thanks Meter: 32 | Hello. emmc pinouts for g530h is the same as g530fz from 278 post from this link: http://forum.gsmhosting.com/vbb/f672...4/index19.html We tested this pinouts and connection working but after mounting emmc chip system windows ask about formatting new disk. If i try write boot + pit got only errors. If someone have information how we can repair this phone, please help as. thanks |
11-30-2015, 15:18 | #18 (permalink) |
Member: 608500 Status: Offline Thanks Meter: 32 | Hello. We writed by emmc connection this file: G530HXXU2BOH5_G530HSER2BOH5_G530HXXU2BOH5_HOME.tar .md5 and phone is still dead ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : FE014E50314A39354B1302AFEF952279 CSD : D06E01320F5913FFFFFFFFEF92400071 eMMC Boot Information Revision 1.6 (for MMC v4.5, v4.51) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 8192 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 2048 KB eMMC Device Information Manufacturer ID: FE Device Type : Embedded BGA Application ID : 4E Product Name : P1J95K Product Rev : 1.3 Product SN : 02AFEF95 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 3000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: FE014E50314A39354B1302AFEF952279.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: MBR + PGPT Start Writing 0x00000032 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: PIT Start Writing 0x00000009 Blocks at 0x00000022 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: SGPT Start Writing 0x00000021 Blocks at 0x00E8FFDF Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: aboot.mbn Start Writing 0x00001000 Blocks at 0x000267C0 Partition Selected: USER AREA Total Elapsed Time 00:00:04 Write Success! Flash Image: sbl1.mbn Start Writing 0x00000400 Blocks at 0x00026380 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: rpm.mbn Start Writing 0x00000400 Blocks at 0x000277C0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: tz.mbn Start Writing 0x00000400 Blocks at 0x00027BC0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: hyp.mbn Start Writing 0x00000400 Blocks at 0x00027FC0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: non-hlos.bin Start Writing 0x00007800 Blocks at 0x00002000 Partition Selected: USER AREA Total Elapsed Time 00:00:25 Write Success! Flash Image: sec.dat Start Writing 0x00000020 Blocks at 0x00029BC0 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: boot.img Start Writing 0x00006800 Blocks at 0x0003E000 Partition Selected: USER AREA Total Elapsed Time 00:00:22 Write Success! Flash Image: recovery.img Start Writing 0x00007800 Blocks at 0x00044800 Partition Selected: USER AREA Total Elapsed Time 00:00:26 Write Success! Warning: EXT3/4 Image Detected Skipping system.img.ext4... Warning: EXT3/4 Image Detected Skipping cache.img.ext4... Warning: EXT3/4 Image Detected Skipping hidden.img.ext4... Flash Image: modem.bin Start Writing 0x0001CB80 Blocks at 0x00009800 Partition Selected: USER AREA Total Elapsed Time 00:01:36 Write Success! Total Images Written: 10 Process Done! what i doing wrong? |
The Following User Says Thank You to komargsm For This Useful Post: |
11-30-2015, 18:17 | #19 (permalink) |
Member: 608500 Status: Offline Thanks Meter: 32 | Hello. I looking for bin files from partition boot1, partition boot2 and partition user_area. If anybody have these files please share it. |
