12-20-2014, 16:15 | #16 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Have repaired a couple of these phone, also with this issues, SD CARD is only for put phone in D.MODE, point. After phone is in D.Mote must need Obbligatory take out this and flash Right fw, (same of sdc file), putting each file in his field, Extract one by one these files, not gave LONG infinite directory only for an PIT and BL. Above for the 200 time @X-Shadow has esplained very good all also with all files, if cannot be good with these, sorry but also you not repair more these phone and send to other that know easy procedure for flash and repair BR |
12-20-2014, 16:45 | #17 (permalink) | |
Freak Poster Join Date: Apr 2012
Member: 1751722 Status: Offline Thanks Meter: 19 | Quote:
bro u r right i have uploaded pic with another firmware to just show u flashing process failed same error even with same sdc and firmware look i have tested with SM-G7102_4.4.2_8GB_G7102XXUBNG8.sdc ( same error with both sdc and firmware) ther is no pit binary while flashing MS013G_EUR_OPEN.pit BL_G7102XXUBNG8_2284897_REV00_user_low_ship_MULTI_ CERT.tar.md5 AP_G7102XXUBNG8_2284897_REV00_user_low_ship_MULTI_ CERT.tar.md5 CP_G7102DXUBNG1_REV00_CL_1619036.tar.md5 CSC_OLB_G7102OLBBNG3_2284897_REV00_user_low_ship_M ULTI_CERT.tar.md5 SM-G7102_4.4.2_8GB_G7102XXUBNK2[www.atfsupport.com].sdc MS013G_EUR_OPEN.pit BL_G7102XXUBNK2_CL3206704_QB2876299_REV00_user_low _ship_MULTI_CERT.tar.md5 AP_G7102XXUBNK2_CL3206704_QB2876299_REV00_user_low _ship_MULTI_CERT.tar.md5 CP_G7102XXUBNK1_REV00_CL_1743842.tar.md5 CSC_OJV_G7102OJVBNK2_CL3206704_QB2876299_REV00_use r_low_ship_MULTI_CERT.tar.md5 | |
12-22-2014, 10:46 | #19 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @.::GSMUnlock::. Perhaps you are not explaining yourself properly. 1. I already gave you SDC File 2. I already gave you Matching 4 Files BL + CP + PDA + CSC + PIT which was used to make the SDC file 3. I already told you to remove SD card before you FLASH with ODIN. What is the problem now? |
01-04-2015, 17:03 | #20 (permalink) |
Freak Poster Join Date: Jul 2012
Member: 1784273 Status: Offline Sonork: 100.1618700 Thanks Meter: 43 | @sanjibe121 SDC Latest Version: SM-G7102_4.4.2_8GB_G7102XXUBNK2.sdc Firmware G7102XXUBNK2 4 Files + PIT (BL + CP + PDA + CSC + PIT) SM-G7102_G7102XXUBNK2.rar 1. Insert SDC, phone should enter download mode... 2. Remove SDC from phone 3. Flash BL + PIT + "Re-Partition" Post here is still error... B.R. NOT WORKING STILL SAME IF I REMOVED SD CARD PHONE AGAIN DEAD ALREADY TRY THIS FILE READ SIR 1ST I PUT SD CARD TO PHONE WITH SDC SM-G7102_4.4.2_8GB_G7102XXUBNK2.sdc 2 PHONE NOW COMING DOWNLOAD MODE GOOD 3 NOW GOING REMOVE SD CARD 4 AFTER REMOVE SD CARD PHONE AGAIN DEAD 5 IF I PUT AGAIN SD CARD PHONE COMING DOWNLOAD MODE 6 AGAIN I REMOVE SD CARD AGAIN DEAD ALREADY TRY Z3X JTAG ZBIN FILE SAME SIR I THINK U UNDERSTOOD MY PROBLEMS IF NOT NO NEED MORE HELP TNX |
01-05-2015, 00:20 | #21 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
In this section there are almost 200 and more posts about Success repair of this model, the unique 2 phone "not reparable" are in your handles, so for me Change emmc and solved all your issues, no more solution BR allumts | |
01-05-2015, 09:23 | #22 (permalink) | |
procedure is 1) boot repair with ng8 sdc after phone boot in download mode 2) keep mmc inside phone start odin 3.9 3) important select pit (without repartition check) + bootloader in BL section of odin now press start after successfull flash phone reboots in firmware upgrade encountered mode 4) [B][COLOR=Yellow]most important now remove mmc from phone 5) flash the phone with all files (pit+BL+PDA+CP+CSC)with repartition checked done same method u can use with any latest full firmware with same sdc according to ur firmware Last edited by .::GSMUnlock::.; 01-05-2015 at 09:28. | |
01-06-2015, 09:29 | #23 (permalink) |
Insane Poster Join Date: Sep 2012
Member: 1813698 Status: Offline Thanks Meter: 8 | Hi I have G7102 DEAD When i Put SDCARd in phone phone boots into Download mode ___________________________- if I remove sdcard (after going to download mode) > can't flash phone with pit and bl file ! <ID:0/049> Odin v.3 engine (ID:49).. <ID:0/049> File analysis.. <ID:0/049> SetupConnection.. <ID:0/049> Initialzation.. <ID:0/049> Set PIT file.. <ID:0/049> DO NOT TURN OFF TARGET!! <ID:0/049> FAIL! <ID:0/049> <ID:0/049> Re-Partition operation failed. if I don't remove sdcard > phone flash completly (flashed with 4 part file with the same version of sdc ) but (WITH SDCARD ) u can see phone boots and show samsung g7102 logo! and can't boot into recovery also |
01-06-2015, 09:41 | #24 (permalink) | |
Member: 1813698 Status: Offline Thanks Meter: 8 | Quote:
but with sdcard goes into samsung g7102 logo and stuck | |
01-07-2015, 22:03 | #25 (permalink) | |
Steps 3 and 4 are totally wrong, only 3 steps not 5. here where you are wrong. If you Flash phone with Sd Card of boot you in next step will have device that not work more alone but have need always Sd Card for boot. | |
01-07-2015, 22:10 | #26 (permalink) | |
Now w/o Sd Card, first try with Wipe/Factory reset and if remain always in Logo then Flash only PIT+BL file and post result. Ask to @ .::GSMUnlock::. of to pay you phone now or repair him for you and for FREE, if he can. I not understand becouse the peoples want help other w/o knowing Right procedure, impossible this. FOR ALL, Use ONLY OFFICIAL PROCEDURE, not listen to all members that often make wrong procedure BR allumts | |
01-09-2015, 15:23 | #27 (permalink) |
Member: 1784273 Status: Offline Sonork: 100.1618700 Thanks Meter: 43 | sir allumts 3. I already told you to remove SD card before you FLASH with ODIN. What is the problem now? u told every time take out SD card then flash ur way is correct accepted but sir why u not reading post. where is the problem read again explain u after repair done with sdc file phone now coming download mode with sd card, now going to take out sd card and flash after removed sd card now phone again dead no download mode, without download mode how to flash tell me i need know that? plz read post sir,where is the problem give perfect solution i know this is strange problem but i have done many phone via sdc file this type problem i see first time after out sd card phone dead , if i in sd card again phone coming download mode Last edited by sanjibe121; 01-09-2015 at 15:32. |
01-09-2015, 19:53 | #28 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @sanjibe121, where are you quoted for anythingh of wrong?, what you problem now?, please not waste space in forum or let me see only 1 post where you are been quoted from to me?.... Continue to work and read you good first of quote me. Sinceraly speaking not import nothingh more to me if you are able to repair or not this phone, BR |
01-09-2015, 20:36 | #29 (permalink) | |
Member: 1784273 Status: Offline Sonork: 100.1618700 Thanks Meter: 43 | Quote:
where is the problem read sir again explain u 1. Inserted SDC, phone coming download mode 2. Remove SDC from phone done 3.after removed sd card now phone again dead no download mode, without download mode how to flash tell me sir? 4. if i enter again sdc phone again coming download mode,if removed again dead so that means my phone not coming download mode without sd card give perfect solution i know this is strange problem but i have done many phone via sdc method this is not my first time and also i try easy jtag sd method same problem. | |
01-09-2015, 21:56 | #30 (permalink) |
Member: 1751722 Status: Offline Thanks Meter: 19 | May b there is something needed more for those handsets which gets dead while trying to flash with pit after boot repair Best Regards IK SOFTWARE |
The Following User Says Thank You to .::GSMUnlock::. For This Useful Post: |
