02-21-2016, 13:30 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Mumbai--Great INDIA
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | SM-J700F MBR is Corrupted...NEED HELP ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 11010034303030373300A47DD1B0A261 CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.0 (for MMC v4.0) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 0 KB HC ERASE GROUP SIZE: 0 KB USER AREA SIZE : 0 BYTES BOOT PARTITION SIZE: 0 KB RPMB PARTITION SIZE: 0 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : A47DD1B0 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 11010034303030373300A47DD1B0A261.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ ERROR: PIT Partition NOT FOUND! Please Provide a PIT File via Selecting "Re-Partition" /CODE] |
02-22-2016, 15:22 | #5 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Uzbekistan/Jizzakh
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | bro look here USER AREA SIZE : 0 BYTES BOOT PARTITION SIZE: 0 KB RPMB PARTITION SIZE: 0 KB your emmc dead! |
The Following User Says Thank You to mastersgsm For This Useful Post: |
