09-30-2014, 14:31 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: FRANCE
Member: 2091798 Status: Offline Sonork: 100.1662559 Thanks Meter: 156 | Sm-t331 qhs_usb dload - (SOLVED via SDC Unbrick) |
09-30-2014, 14:48 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @invaderaze Yes, it was added long time ago... called SDC Unbrick. It will definitely work on your tab if your tab just have firmware issues. You need to use ATF Plus ---> Image Tool to create SDC Unbricker for your phone using flash files for your tab. I can make it for you, but need some time to download the flash files. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
09-30-2014, 14:57 | #3 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Here is your SDC File SM-T331_4.4.2_8GB_T331XXU1ANDA.sdc Write it to a 8GB Branded Micro SD Card Class 10 or better. You need ATF Plus ----> SDC Tool to write .sdc files After preparing the SD card, just insert it to the tablet and connect USB cable. |
09-30-2014, 15:35 | #4 (permalink) | |
Member: 2091798 Status: Offline Sonork: 100.1662559 Thanks Meter: 156 | Quote:
09-30-2014, 15:40 | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @invaderaze Do you remember version of phone before it died? Normally, you do not need to do anything special... Just try, VOLUME DOWN + HOME + POWER Button to force phone into DOWNLOAD MODE. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
09-30-2014, 15:46 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @invaderaze Hi, I rechecked something was wrong with that first SDC file, it was too small... Download this instead: SM-T331_4.4.2_8GB_T331XXU1ANDA.sdc 25MB Make sure you write it using ATF Plus -----> SDC Tool... otherwise it will NOT WORK. Show logs after you write it using SDC Tool so I can see Card Size etc... B.R. |
09-30-2014, 15:49 | #9 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
ATF Software will tell you if BL, CP etc are missing.. most likely, your file is ALL-IN-ONE pacakge... Just go to ATF Plus ---> Image Tool... Load your Flash Files... make sure you include PIT File If you do not have PIT File, download this: MILLET3G_EUR_OPEN.pit | |
09-30-2014, 15:52 | #10 (permalink) |
Member: 2091798 Status: Offline Sonork: 100.1662559 Thanks Meter: 156 | Sandisc 8GB Class 10 (Black-Red) ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x03 Application ID : SD Product Name : SL08G Product Revision : 8.0 Serial Number : 259653F2 Manufacture Date: April 2014 Card CID: 035344534C30384780259653F200E4C7 Card CSD: 400E00325B5900003B377F800A4040AF Card SCR: 0235800100000000 Card OCR: 00C0FF8000 SD Card Size : 7948206080 Bytes SD Block Size: 512 Bytes Maximum Speed: 25000000 Hertz SDHC / SDXC Card Detected... Checking Lock Status... Micro SD Card is NOT Password Protected!!! Erasing SDC... Samsung SM-T331 CURR UNBRICK Android 4.4.2 Start Writing to SDC at 0x00000000... Number of Blocks: 0x00040000 Process Done... ================================================== ==== 1. Insert Micro SD Card to Phone 2. Make Sure Battery is Fully Charged 3. Press Volume Down + Home + Power Button 4. Flash the Phone with ODIN ================================================== ==== Total Elapsed Time 00:01:26 Write Success! |
09-30-2014, 16:04 | #12 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @invaderaze Maybe post picture of Repaired Tablet Just so this thread will look nice and not just text logs hehehe. You are welcome! Feel the SDC Power |
