Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-30-2014, 14:31   #1 (permalink)
invaderaze's Avatar
Member: 2091798
Sonork: 100.1662559
Thanks Meter: 156
Exclamation Sm-t331 qhs_usb dload - (SOLVED via SDC Unbrick)
Hi ATF Team. Can you add solution for SM-T331 QHS_USB DLOAD problem? today i have bricked my tab, if you want we can test together
Old 09-30-2014, 14:48   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@invaderaze
Yes, it was added long time ago... called SDC Unbrick.
It will definitely work on your tab if your tab just have firmware issues.
You need to use ATF Plus ---> Image Tool
to create SDC Unbricker for your phone using flash files for your tab.
I can make it for you, but need some time to download the flash files.
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-30-2014, 14:57   #3 (permalink)
Member: 651945
Here is your SDC File
SM-T331_4.4.2_8GB_T331XXU1ANDA.sdc
Write it to a 8GB Branded Micro SD Card Class 10 or better.
You need ATF Plus ----> SDC Tool
to write .sdc files
After preparing the SD card, just insert it to the tablet and connect USB cable.
Old 09-30-2014, 15:35   #4 (permalink)
invaderaze's Avatar
Member: 2091798
Sonork: 100.1662559
Thanks Meter: 156
to write .sdc files
Thank you very much for quick reply....i have made SD Card ...now i insert it to phone and connect to PC, it is again detected as QHS_USB...can you write advanced isntruction? it is 100% software problem, because it was worked till i want to change imei with other box ..... (Selected different model, all gone good, but after reboot phone was detected as QHS_USB)
Old 09-30-2014, 15:40   #5 (permalink)
Member: 651945
@invaderaze
Do you remember version of phone before it died?
Normally, you do not need to do anything special...
Just try, VOLUME DOWN + HOME + POWER Button to force phone into DOWNLOAD MODE.
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 09-30-2014, 15:42   #6 (permalink)
invaderaze's Avatar
Member: 2091798
Sonork: 100.1662559
Thanks Meter: 156
Last time i flashed with this firmware - T331XXU1ANF2_T331SER1ANF2_SER Android 4.4.2
Old 09-30-2014, 15:46   #7 (permalink)
Member: 651945
@invaderaze
Hi, I rechecked something was wrong with that first SDC file, it was too small...
Download this instead:
SM-T331_4.4.2_8GB_T331XXU1ANDA.sdc 25MB
Make sure you write it using ATF Plus -----> SDC Tool... otherwise it will NOT WORK.
Show logs after you write it using SDC Tool so I can see Card Size etc...
B.R.
Old 09-30-2014, 15:46   #8 (permalink)
invaderaze's Avatar
Member: 2091798
Sonork: 100.1662559
Thanks Meter: 156
i have only 1 file firmware...can i create SDC with it? i have no bootloader, modem, and CSC
Old 09-30-2014, 15:49   #9 (permalink)
Member: 651945
You can create your own SDC file if you already have the flash file with you.
ATF Software will tell you if BL, CP etc are missing.. most likely, your file is ALL-IN-ONE pacakge...
Just go to ATF Plus ---> Image Tool...
Load your Flash Files... make sure you include PIT File
If you do not have PIT File, download this:
MILLET3G_EUR_OPEN.pit
Old 09-30-2014, 15:52   #10 (permalink)
invaderaze's Avatar
Member: 2091798
Sonork: 100.1662559
Thanks Meter: 156
Sandisc 8GB Class 10 (Black-Red)
SDC Direct Access Connection Module
Card Reset Done!
Initializing Micro SD Card...
Card Initialized OK (V2.0 Compliant)
Waiting for IDLE State...
Card is now IDLE!
Reading Micro SD Card Information...
Manufacturer ID : 0x03
Application ID : SD
Product Name : SL08G
Product Revision : 8.0
Serial Number : 259653F2
Manufacture Date: April 2014
Card CID: 035344534C30384780259653F200E4C7
Card CSD: 400E00325B5900003B377F800A4040AF
Card SCR: 0235800100000000
Card OCR: 00C0FF8000
SD Card Size : 7948206080 Bytes
SD Block Size: 512 Bytes
Maximum Speed: 25000000 Hertz
SDHC / SDXC Card Detected...
Checking Lock Status...
Micro SD Card is NOT Password Protected!!!
Erasing SDC...
Samsung SM-T331 CURR UNBRICK Android 4.4.2
Start Writing to SDC at 0x00000000...
Number of Blocks: 0x00040000
Process Done...
1. Insert Micro SD Card to Phone
2. Make Sure Battery is Fully Charged
3. Press Volume Down + Home + Power Button
4. Flash the Phone with ODIN
Total Elapsed Time 00:01:26
Write Success!
Old 09-30-2014, 15:57   #11 (permalink)
invaderaze's Avatar
Member: 2091798
Sonork: 100.1662559
Thanks Meter: 156
ohh..Thank you my dear....it's worked....my phone now is live ....Thank you very much
Old 09-30-2014, 16:04   #12 (permalink)
Member: 651945
@invaderaze
Maybe post picture of Repaired Tablet
Just so this thread will look nice and not just text logs hehehe.
You are welcome!
Feel the SDC Power
Old 09-30-2014, 17:19   #13 (permalink)
Member: 217891
Thanks Meter: 237
i can use normal sd card or only this name sd card sandisc 8gb calss10 ???
Old 09-30-2014, 19:48   #14 (permalink)
invaderaze's Avatar
Member: 2091798
Sonork: 100.1662559
Thanks Meter: 156
Hi mate. Try to use branded Micro sd like ******* kingston, samsung....with branded sd more success than unbranded
Old 09-30-2014, 20:32   #15 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
China made/unbranded micro sd card will not have 100% success rates. For better result you need to use branded *******/Samsung micro sd card.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Page generated in 0.25785 seconds with 8 queries
