04-20-2010, 16:12 | #1 (permalink) | |
Freak Poster Join Date: Jun 2008 Location: Persia Age: 33
Member: 802870 Status: Offline Sonork: 100.1585683 Thanks Meter: 595 | Solotion For "Flashing FAILED Operations Failed...." In ATF v4.80 in v4.80 when u flashing ur phone show: Quote:
1. unistall ATF Program From ur PC and delete Program folder 2. Install v4.70_fixed 3. Just copy AdvanceBox.exe (v4.80) in program folder X:\Program Files\AdvanceBox Turbo Flasher And when question about replace Click Yes (Just AdvanceBox.exe NO AdvanceBox.ini ) better Download 4.80 exe file from here 4. Enjoy From ur ATF Here is Log of 6720c Flashing wh/ou any Problem (before that can't flash) Code: Reading Phone Information... MCU: V ICPR82_09w36.3 22-09-09 RM-424 (c) Nokia IMEI: 3************ Product code : ******** Reading SimLock ******** Simlock Version : SIMLOCK SERVER CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SL2 Phone Detected... ERROR : FAILED TO BACKUP, TRY AGAIN... Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02011104 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C34 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 23700003 ID DWORD 1 : 40640344 ID DWORD 2 : 3C005D42 ID DWORD 3 : 0CDEF9BE ID DWORD 4 : CD8BF150 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 25 B9 77 A0 55 BE 9B 5D EC 0C 38 A2 A2 79 C6 95 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 3E273BF6 CRC 1 : 37BE26FA Checksum 5F BootCodeLen : 61 SearchForBootstrap_DCT5.. KEYS CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 Checksum : 19 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121 RAPUv11_XSR17_alg.fg First Algo byte : 56 XSR 1.6 phone devicealgo : Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) ChkStatus : 80017E00 FUR control Ok VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 ChkStatus : 80017E00 START READING RPL DATA Reading : NPC OK Reading : VARIANT VARIANT : Empty Reading : CCC OK Reading : HWC OK Reading : R&D OK FINISHED READING RPL DATA RPL saved to: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\backup\353213032914071\353213032914071_61641.rpl FlashInfo.RestartMode : 2 ChkStatus : 80017E00 Processing Image File : I:\Program Files\Nokia\Phoenix\BB5\6720.RM-424\013.009\rm424_013.009_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 4003192102001104 > 400C192102001104 > 6003192102001104 > 600C192102001104 > 6003192102011104 > 600C192102011104 > 6003192102021104 > 600C192102021104 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 404 Entry Point: 0x01DA Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : I:\Program Files\Nokia\Phoenix\BB5\6720.RM-424\013.009\rm424_013.009_11.01_MENA_B_prd.rofs2.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 4003192102001104 > 400C192102001104 > 6003192102001104 > 600C192102001104 > 6003192102011104 > 600C192102011104 > 6003192102021104 > 600C192102021104 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 147 Entry Point: 0x00DF Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : I:\Program Files\Nokia\Phoenix\BB5\6720.RM-424\013.009\rm424_013.009_C12.01_BROWN_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 4003192102001104 > 400C192102001104 > 6003192102001104 > 600C192102001104 > 6003192102011104 > 600C192102011104 > 6003192102021104 > 600C192102021104 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 23 Entry Point: 0x00DF Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : I:\Program Files\Nokia\Phoenix\BB5\6720.RM-424\013.009\rm424_013.009_U008.000_prd.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 4003192102001104 > 400C192102001104 > 6003192102001104 > 600C192102001104 > 6003192102011104 > 600C192102011104 > 6003192102021104 > 600C192102021104 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 42 Entry Point: 0x00D9 Page Format : -1 MAX PAGE : 0x00040000 VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02011104 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C34 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 23700003 ID DWORD 1 : 40640344 ID DWORD 2 : 3C005D42 ID DWORD 3 : 0CDEF9BE ID DWORD 4 : CD8BF150 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 25 B9 77 A0 55 BE 9B 5D EC 0C 38 A2 A2 79 C6 95 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 3E273BF6 CRC 1 : 37BE26FA Checksum 5F BootCodeLen : 61 SearchForBootstrap_DCT5.. KEYS CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 Checksum : 19 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121 RAPUv11_XSR17_alg.fg First Algo byte : 56 XSR 1.6 phone devicealgo : Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) ChkStatus : 80017E00 FUR control Ok VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 ChkStatus : 80017E00 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 ChkStatus : 80017E00 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00020000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 03260000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 03260000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 03260000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 03260000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF000000040000000300000002000A000003260000000000040000000203300000079C000000000008000000010ACC0000049800000000000A000000010F640000003C000032 ChkStatus : 80017E00 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) No partition info.... No partition info.... No partition info.... StartErase_DCT5... BlockLength : 0x004F (79) ERASE Blocks : 0x0002 (2) erase blocks : 2 CurrPos : 03 CurrEraseLen : 1B 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00020000-0003FFFF 1 : 00060000-004DFFFF 2 : 008E0000-0ACBFFFF CurrPos : 20 CurrEraseLen : 2F 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID :0x02000000 Format Info :000000000000000A0000000000000002000000640000000B0000000200000001000000000000 ERASE_REQUEST_BB5 : 5003120B000300000200000003FFFF120B00030000060000004DFFFF120B000300008E00000ACBFFFFE7 ChkStatus : 80017E00 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000000000002000000640000000B000000020000000100000000000033 ChkStatus : 80017E00 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 06740000-09EBFFFF ERASE_REQUEST_BB5 : 5001120B0003000674000009EBFFFF72 ChkStatus : 80017E00 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 09EC0000-0ACBFFFF ERASE_REQUEST_BB5 : 5001120B00030009EC00000ACBFFFF16 ChkStatus : 80017E00 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:05 Is Flashing CLOCK AUTO : -1 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : rm424_013.009_prd.core.fpsx Total blocks to write : 404 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 >> CMT Rootkey Hash CERT : ADA ChkStatus : 80017E00 ChkStatus : 80017E00 >> CMT Rootkey Hash CERT : KEYS ChkStatus : 80017E00 >> CMT Rootkey Hash CERT : PRIMAPP ChkStatus : 80017E00 ChkStatus : 80017E00 >> CMT Rootkey Hash CERT : RAP3NAND ChkStatus : 80017E00 ChkStatus : 80017E00 >> CMT Rootkey Hash CERT : SOS+PMML ChkStatus : 80017E00 ChkStatus : 80017E00 >> CMT Rootkey Hash CERT : PASUBTOC ChkStatus : 80017E00 >> CMT Rootkey Hash CERT : PAPUBKEYS ChkStatus : 80017E00 >> CMT Rootkey Hash CERT : GENIO_INIT ChkStatus : 80017E00 ChkStatus : 80017E00 >> CMT Rootkey Hash CERT : SOS*UPDAPP ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 >> CMT Rootkey Hash CERT : SOS*DSP0 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 >> CMT Rootkey Hash CERT : LDSP ChkStatus : 80017E00 ChkStatus : 80017E00 >> CMT Rootkey Hash CERT : SOS*ISASW ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 >> CMT Rootkey Hash CERT : SOS+CORE ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 >> CMT Rootkey Hash CERT : SOS+ROFS1 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 Processing : rm424_013.009_11.01_MENA_B_prd.rofs2.fpsx Total blocks to write : 147 >> CMT Rootkey Hash CERT : SOS+ROFS2 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 Processing : rm424_013.009_C12.01_BROWN_prd.rofs3.fpsx Total blocks to write : 23 >> CMT Rootkey Hash CERT : SOS+ROFS3 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 Processing : rm424_013.009_U008.000_prd.uda.fpsx Total blocks to write : 42 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ChkStatus : 80017E00 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 ChkStatus : 80017E00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:49 Total Flashing Time (Booting + Erase + Flashing) : 00:01:59 Br, Farzad.M | |
The Following 3 Users Say Thank You to Farzad.m For This Useful Post: |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
