06-15-2013, 04:14 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | <<<<<< SOLUTION Lumia 710 / 800 / 800C "NOT FLASHING" after TP BOOT REPAIR >>>>>> Here is sample logs showing the error during Normal USB Flashing: ================================================== ====== Sending OSBL Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED ============================================== STEP 1: In order to fix this problem, you first need to write QUALCOMM OSBL to your phone via TP Method. Select Correct Phone Type and make sure M.B.R. + SEC_BOOT + OSBL QCOM is selected as well. Then click REPAIR BOOT!!! STEP 2: Remove USB Cable and press and hold POWER BUTTON for 18 Seconds. Then press and hold VOLUME UP Button while connecting the USB Cable to the phone. *** Your Phone should now be detected as a New HDD Device and Windows will ask you to FORMAT IT... Of course DO NOT FORMAT STEP 3: Download the proper RAW BOOT Files for your phone. Lumia 710 RM-803 and RM-809 Lumia 800 RM-801 and RM-819 Lumia 800C RM-802 STEP 4: Go to eMMC Direct tab in ATF Software and click "Scan Partitions". If your phone is NOT DETECTED, go back to STEP 2. Repeat Step 2 until your phone is DETECTED Properly. After ATF Software successfully Lists the Partitions Found on the Phone, click "Backup Phone Data" so you will save your IMEI, Simlocks and other important data safely. STEP 5: Now Let us write Boot Files which you downloaded from Step 3. Extract the RAR file and then write the 3 RAW Boot Files 1 by 1: 5a. dbl_RM-XXX.bin <--- Write this to 0x4D - DBL Partition 5b. osbl_nokia_RM-XXX.bin <--- Write this to 0x46 - OSBL Partition 5c. amss_adsp_RM-XXX.bin <--- Write this to 0x0C - AMSS_ADSP Partition 5a - DBL 5b - OSBL_NOKIA 5c - AMSS_ADSP STEP 6: Click "SP UNLOCK" if you want to unlock your phone after fixing the BOOTS. STEP 7: Flash the WP_OS partition using your regular ESCO Flash Files. This will have the same effect as you will flash the phone via USB... but via eMMC Direct, it is faster and does not care if your KEYSTORE is damaged or erased. Write Flash file to 0x48 WP_OS Partition. Flash File should be the BOOT file and should be more than 300 MB in size. It looks like this: RMxxx_11111_prod_111_11_boot.esco <--- 300+ MB *** WARNING: Everytime you flash your phone with another firmware, you will always RESET the SP Lock status and RESET the SP Lock Counters. To avoid your phone from getting RE-LOCKED, always make sure to UN-CHECK the "XXXXXXX_prod_generic_amss.esco" flash file before you click the FLASH Button. By Skipping this file, you can always re-enter "00000000" to unlock your phone again after flashing. Last edited by Advance-Box; 12-03-2013 at 17:52. |
The Following 31 Users Say Thank You to Advance-Box For This Useful Post: |
06-25-2013, 14:14 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | @advance box I have a nokia lumia 510 with the same problem! can u pls inform if i can follow the same for this model! to repir this problem? and i hve a few 610 which are re-locked after flashing, is there anyway i can do something about this phones? WBR ReyTech |
06-28-2013, 12:08 | #3 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1633373 Status: Offline Thanks Meter: 2 | My problem same as above, solved from Teamviewer with Advance-Box/ X-Shadow, with dump file, we flashed 3 partitions (including the OS) and Unlocked phone Thank you Advance-Box You really SAVED me |
06-28-2013, 19:07 | #4 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: Hanoi, Vietnam
Member: 1012390 Status: Offline Thanks Meter: 95 | Please help me sir, i get the hard problem I get a Lumia RM-819 from customer. I change OSBL DLOAD to QCOM and flash a custom firmware RM-801. After flash custom rom, phone no start up, still Qualcomm bootloader. I want to back Stock rom and re-changed to DLOAD bootloader, then flash rom and get this error. I followed this guide and do extract all steps to fix but now i still get this error Quote:
06-28-2013, 20:40 | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | @Hoayeu105 It means custom firmware "mis-alligned" your partition tables. 1. Put back QUALCOMM OSBL to your phone via TP Method 2. Show me screenshot of what ATF Software can see when you click "Scan Partitions" in eMMC Direct tab. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
06-29-2013, 02:57 | #6 (permalink) | ||
Member: 1012390 Status: Offline Thanks Meter: 95 | Quote:
dd if=/path_of_file/amssadsp.img_part3 of=/dev/sdb3 Please help me with your kind, sir Many thank! Last edited by Hoayeu105; 06-29-2013 at 03:03. | ||
06-29-2013, 04:51 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | @Hoayeu105 Hi, Please PM me teamviewer Username and Password. Also, click "Backup Phone Data" and Download this: http://174.120.45.27/tmp/RM-801_RM-819_BOOTS_RAW.rar I will be waiting for PM from you. |
06-29-2013, 13:48 | #9 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: PAKISTAN Age: 34
Member: 1082907 Status: Offline Sonork: 100.1606954 Thanks Meter: 342 | Quote:
Sending OSBL Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED same problem help me plz | |
06-29-2013, 16:38 | #11 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 345808 Status: Offline Thanks Meter: 21 | plz mobile is dead 800 lumia not booting i put tp after that this error ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! BYTES_MISSING ERROR: Connection Refused 0x06 Check your Test Point Soldering! BOOT Images Written Successfully! Total Elapsed Time 00:00:03 |
06-30-2013, 08:17 | #12 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
ERROR: Connection Refused 0x06 Check your Test Point Soldering! Br - srinibas | |
The Following User Says Thank You to srinibas For This Useful Post: |
06-30-2013, 09:01 | #13 (permalink) | |
Freak Poster Join Date: Dec 2009 Location: E G Y P T
Member: 1193296 Status: Offline Sonork: 100.1616292 Thanks Meter: 63 | Quote:
Great job thanks a lot | |
The Following 2 Users Say Thank You to m-soft For This Useful Post: |
