06-28-2015, 08:56 | #137 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: PL Age: 44
Member: 477842 Status: Offline Thanks Meter: 80 | Quote:
After your procedure , bro Lumia 800 rm-801 shows low battery , and charge it . When I try to flash MCU , i have log : Sending WPOS Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 1604 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE WPOS CERTIFICATE FAILED any solution to repair via usb ? | |
07-26-2015, 11:09 | #138 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Russia. city Khasavyurt Age: 42
Member: 128322 Status: Offline Thanks Meter: 13 | I have a phone that when firmware writes ERROR: Data Rejected at SEQ 0x141 but after the restoration of this a manual .. phone earned .. BUT . When Hottel upgrade the software it says .. ERROR: Data Rejected at SEQ 0x3 |
07-26-2015, 11:31 | #139 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hi, Read Here: ATF doesn't support damaged keystore repair at this moment. But it allow you to write boots and flash via eMMC Direct. After flash phone should work normal but you can't flash this phone directly via USB next time. You will always need eMMC Direct to write flash boot.esco BR allumts |
01-19-2016, 09:11 | #140 (permalink) | |
No Life Poster Join Date: May 2009
Member: 1024748 Status: Offline Thanks Meter: 53 | Quote:
================================================== ==== How To Put QCOM OSBL into the Phone ================================================== ==== 1. Lumia 710 - VIA USB Flashing 2. Lumia 800 - VIA TP Boot Repair 3. Other Lumia Models are NOT SUPPORTED ERROR: AMSS Partition Not Found | |
03-05-2016, 21:21 | #141 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Algeria Age: 47
Member: 78657 Status: Offline Thanks Meter: 71 | hello does my driver is ok ? because ERROR: Qualcomm MMC Storage is NOT FOUND run as administrator but no sucess . and try with three PC. thank you. |
09-15-2016, 22:29 | #148 (permalink) | |
Freak Poster Join Date: Aug 2014 Location: France Age: 34
Member: 2235775 Status: Offline Thanks Meter: 351 | dear sir, I am tryng chain 8 days Quote:
09-16-2016, 12:02 | #149 (permalink) |
Member: 2235775 Status: Offline Thanks Meter: 351 | dear x shadow sir i am tryng chain 8 days! my phone for unlocking format drive.then dead . repair done. but not flashing.not detecting emmc drive when scan partition on atf pls pls pls help me |
09-16-2016, 12:08 | #150 (permalink) | |
Member: 2235775 Status: Offline Thanks Meter: 351 | i am tryng chain 8 days! but no luck Quote:
i am tryng chain 8 days! my phone for unlocking format drive.then dead . repair done. but not flashing.not detecting emmc drive when scan partition on atf pls pls pls help me | |
