10-28-2013, 23:40 | #62 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 261334 Status: Offline Thanks Meter: 13 | what was the solution to your problem as it gives me the same error. Sending OSBL Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED |
11-01-2013, 21:32 | #63 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: algeria
Member: 228703 Status: Offline Thanks Meter: 21 | Quote:
how did you solved your problem waiting your respense thx in advance | |
11-05-2013, 15:30 | #64 (permalink) |
Member: 261334 Status: Offline Thanks Meter: 13 | Please help friends since done the procedure many times and I get the same fault. Sending OSBL Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED |
11-11-2013, 11:24 | #65 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2008 Location: freedoom ...algeria
Member: 686535 Status: Offline Sonork: 1592667 Thanks Meter: 108 | --> 01B00BBB000000004B49434B <-- 01B00BBB000000004B49434B00000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000 --> 03B00BBB00000000 <-- 04B00BBB1000000001000100060001010C000000A54A3E4F00 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000 --> 01B00BBB000000004B49434B <-- 01B00BBB000000004B49434B00000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000 Sending OSBL Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED |
11-11-2013, 14:24 | #67 (permalink) |
Freak Poster Join Date: Jul 2010 Location: india Age: 40
Member: 1354455 Status: Offline Sonork: 100.1637595 Thanks Meter: 54 | i have unlock done after pack phone not power then use only step 1 boot repair then phone is on and enter sim unlock pin 00000000 then UNLOCK done. thanks ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V eMMC Boot Information BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 016G4B Product Rev : 0.0 Product SN : 8B50B7C8 Manufactured : January 2011 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 3 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Writing MBR... Write Success! Writing DBL... Write Success! Writing OSBL... Write Success! BOOT Images Written Successfully! Total Elapsed Time 00:01:56 |
12-06-2013, 00:45 | #71 (permalink) |
No Life Poster Join Date: Oct 2004 Location: italy
Member: 85139 Status: Offline Thanks Meter: 68 | lumia 800 hi, someone has na solution? pins are connected already well controlled, the software is updated. the settings of the vciio are automatic, but I tried them all and should not be .. atf team where am I wrong? thanks |
12-06-2013, 02:30 | #72 (permalink) |
Freak Poster Join Date: Sep 2010 Location: jamaica
Member: 1391794 Status: Offline Thanks Meter: 54 | after repair boot on lumia 800 i cant detect as storage.i don't know if after repair boot if i should remove test point or what i got this error when am trying to scan partition qualcomm mmc storage is not found.i want to if i should use battery after repair boot too. |
12-06-2013, 21:53 | #74 (permalink) | |
Freak Poster Join Date: May 2013 Location: Nigeria
Member: 1931004 Status: Offline Sonork: 100.1662382 Thanks Meter: 85 | Quote:
i also have the same problem. before phone can vibrate but now it cant.. i will only hear its conncting sound from my pc...... | |
