Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 12-23-2013, 17:34   #91 (permalink)
Crazy Poster
Member: 494907
Thanks Meter: 2
Working perfect solution! Thx ATF box!!!
Old 12-26-2013, 05:52   #92 (permalink)
Member: 1838260
Sonork: N/A
Thanks Meter: 2
big thanks for this solution,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,
Old 01-03-2014, 00:05   #93 (permalink)
Member: 2092016
Everyone teaches do and undo with Qualcomm, but ningem explains how to find DLOAD driver, and make the jailbrake NOKIA DLOAD. perhaps no one even knows.
Old 01-04-2014, 07:18   #94 (permalink)
Member: 903576
Sonork: 100.1648991
Thanks Meter: 14
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
ERROR: EMMC WAS NOT Detected! (CMD1)
Check your Test Point Soldering!
CMD1 Reply: 0x5E5E5E5E
BOOT Images Written Successfully!
Total Elapsed Time 00:00:05
what is the problem sir
Old 01-16-2014, 12:32   #95 (permalink)
Member: 1769339
Sonork: 100.1627057
Thanks Meter: 12
lumia 710 cant repair boot error
Interface Reset OK!
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V
2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V
1.9-2.0V
CID : 0600003136FFFFFFFFFF195C4939
CSD : 904F012A0F5903FFF6DBFFEF8A400099
eMMC Boot Information
BOOT PARTITION : USER AREA
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT: DISABLED
PWR_BOOT_CFG_PROT : DISABLED
eMMC FirmW UPDATE : DISABLED
ERROR: EMMC_READ_SINGLE_BLOCK FAILED (CMD17)
Check GREEN Test Point Connection
need help
Old 01-16-2014, 14:26   #96 (permalink)
Member: 1218140
Thanks Meter: 2
i have a lumia 900 ,dont' flash
Sending AMSS Certificate
HASH: 6898A268F71233A06C3082728DB725A38679C21C
Certificate Size: 449 Bytes
ERROR: Data Rejected at SEQ 0x3
Status : WRITE AMSS CERTIFICATE FAILED
help me plz..thanks
Old 01-24-2014, 13:55   #97 (permalink)
nhumanh's Avatar
Member: 56938
Sonork: 100.1590777
Thanks Meter: 150
I got this
20:42:33 : Loading Partition File: E:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\dbl_RM-801_RM-819.bin
20:42:33 : Writing Partition 0x4D
20:42:35 : Partition 0x4D Write OK
20:42:35 :
20:42:35 : Total Elapsed Time 00:00:01
20:42:41 :
20:42:41 : Loading Partition File: E:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\osbl_nokia_RM-801_RM-819.bin
20:42:41 : Writing Partition 0x46
20:42:41 : Partition 0x46 Write OK
20:42:41 :
20:42:41 : Total Elapsed Time 00:00:00
20:42:46 :
20:42:46 : Loading Partition File: E:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\amss_adsp_RM-801_RM-819.bin
20:42:46 : Writing Partition 0x0C
20:42:46 : Partition 0x0C Write OK
20:42:46 :
20:42:46 : Total Elapsed Time 00:00:00
20:43:07 :
20:43:07 : Operation Cancelled...
20:43:28 :
20:43:28 : Loading Partition File: E:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\RM801_11501_prod_64 5_02_boot.esco
20:43:28 : Writing Partition 0x48
20:43:29 : Partition 0x48 Write OK
20:43:29 :
20:43:29 : Total Elapsed Time 00:00:00
20:44:13 :
20:44:13 : ERROR: Qualcomm MMC Storage is NOT FOUND
can not revive
Old 01-30-2014, 06:38   #98 (permalink)
Member: 366884
Thanks Meter: 9
Lumia 710 rm809
Sir , i was having problem after i perform testpoint unlock on lumia 710 rm809 whit atf. Everything when on smoothly,after coupling the phone ,try to power it up. It vibrate and shows a blinking nokia logo on the screen. I remove the battery and try to power it up againg but only vibrate, but refuse to boot up. I did boot repair by choosing the right with success response but still not power-up, scan partition, no partition detected. Please sir how do you help me by guide on how to get the phone back to working condition?
Old 02-05-2014, 06:26   #99 (permalink)
Member: 1854744
Sonork: 100.1583019
Thanks Meter: 3
lumia 710.....try again in 17910216 minutes.....plz help me
Old 02-07-2014, 07:03   #100 (permalink)
Member: 1769339
Sonork: 100.1627057
Thanks Meter: 12
Perform a hard reset if problem still exist then flash it, 100%
Old 02-08-2014, 10:16   #101 (permalink)
Crazy Poster
Member: 1231754
Thanks Meter: 25
100% working Thanks
Originally Posted by Advance-Box View Post
The solution described below is for phones with "un-alligned" or corrupted AMSS + ADSP Region caused by improper custom firmware flashing or by other means of data corruption.
Here is sample logs showing the error during Normal USB Flashing:
Sending OSBL Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4
Certificate Size: 452 Bytes
Status : WRITE OSBL CERTIFICATE FAILED
STEP 1:
In order to fix this problem, you first need to write QUALCOMM OSBL to your phone via TP Method.
Select Correct Phone Type and make sure M.B.R. + SEC_BOOT + OSBL QCOM is selected as well. Then click REPAIR BOOT!!!
STEP 2:
Remove USB Cable and press and hold POWER BUTTON for 18 Seconds. Then press and hold VOLUME UP Button while connecting the USB Cable to the phone.
*** Your Phone should now be detected as a New HDD Device and Windows will ask you to FORMAT IT... Of course
DO NOT FORMAT
STEP 3:
Download the proper RAW BOOT Files for your phone.
Lumia 710 RM-803 and RM-809
Lumia 800 RM-801 and RM-819
Lumia 800C RM-802
STEP 4:
Go to eMMC Direct tab in ATF Software and click "Scan Partitions". If your phone is NOT DETECTED, go back to STEP 2. Repeat Step 2 until your phone is DETECTED Properly.
After ATF Software successfully Lists the Partitions Found on the Phone, click "Backup Phone Data" so you will save your IMEI, Simlocks and other important data safely.
STEP 5:
Now Let us write Boot Files which you downloaded from Step 3.
Extract the RAR file and then write the 3 RAW Boot Files 1 by 1:
5a. dbl_RM-XXX.bin <--- Write this to 0x4D - DBL Partition
5b. osbl_nokia
_RM-XXX.bin <--- Write this to 0x46 - OSBL Partition
5c. amss_adsp
_RM-XXX.bin <--- Write this to 0x0C - AMSS_ADSP Partition
5a - DBL
5b - OSBL_NOKIA
5c - AMSS_ADSP
STEP 6:
Click "SP UNLOCK" if you want to unlock your phone after fixing the BOOTS.
STEP 7:
Flash the WP_OS partition using your regular ESCO Flash Files. This will have the same effect as you will flash the phone via USB... but via eMMC Direct, it is faster and does not care if your KEYSTORE is damaged or erased.
Write Flash file to 0x48 WP_OS Partition.
Flash File should be the BOOT file and should be more than 300 MB in size.
It looks like this:
RMxxx_11111_prod_111_11_boot.esco <--- 300+ MB
*** WARNING: Everytime you flash your phone with another firmware, you will always RESET the SP Lock status and RESET the SP Lock Counters. To avoid your phone from getting RE-LOCKED, always make sure to UN-CHECK the "XXXXXXX_prod_generic_amss.esco" flash file before you click the FLASH Button. By Skipping this file, you can always re-enter "00000000" to unlock your phone again after flashing.
100% 100% working Thank u very much
Old 02-21-2014, 08:21   #102 (permalink)
nhumanh's Avatar
Member: 56938
Sonork: 100.1590777
Thanks Meter: 150
after use this method, phone is on .
But I want to change bootloader to Qualcomm to flash custom rom , it show
How can i change to Qualcomm boot ?
Old 03-02-2014, 04:29   #103 (permalink)
Bruno Rafael's Avatar
Member: 700706
Sonork: 100.1590381
Thanks Meter: 202
hi, my phone is Lumia 710 ( hang in logo), but a try this 7 step in first post in this thered.
my phone is live now.
But...i need unlock bootloader for install app ( .XAP) but error in flash!
conditions:
Phone power on Ok!
Simlock = Unlocked
but show-me this error after try flash :
how to repair this without test point?
Old 03-22-2014, 17:56   #104 (permalink)
Member: 700706
Sonork: 100.1590381
Thanks Meter: 202
I have a lumia 710 not start it, appears the name of nokia and off.
I repair boot, and atf software shows that were recorded, but the phone is not recognized as Qualcomm, so I can not do the rest of the repair (BOOT recording RAW files).
What should I do?
my error in flash is:
ERROR: Data Rejected at SEQ 0x11
Old 03-23-2014, 09:53   #105 (permalink)
Crazy Poster
Member: 743109
Thanks Meter: 15
i do all this step but no result
STEP 1:
STEP 2:
DO NOT FORMAT
STEP 3:
Lumia 800C RM-802
STEP 4:
STEP 5:
5b. osbl_nokia
5c. amss_adsp
5a - DBL
5b - OSBL_NOKIA
5c - AMSS_ADSP
STEP 6:
STEP 7:
It looks like this:
this the error
Windows Phone Flashing Started
OSBL File Found:
RM803_12w12_prod_generic_nokia_osbl_0605.esco
ADSP File Found:
RM803_12w12_prod_generic_adsp_0605.esco
AMSS File Found:
RM803_12w12_prod_generic_amss_0605.esco
WPOS File Found:
RM809_12w12_prod_tmous_0605.esco
USER AREA ERASE File Found:
RM803_12w12_prod_generic_user_area_erase_0605.esco
Windows Phone Lumia Flasher
If the Phone is ALIVE
1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
1. Press and Hold the VOLUME UP button
2. Connect it to the USB Port while still Pressing
3. Continue to Press the VOLUME UP button for 8 more
seconds
Page generated in 0.99173 seconds with 8 queries
