05-20-2014, 19:48 | #121 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
STEP 7: Flash the WP_OS partition using your regular ESCO Flash Files. This will have the same effect as you will flash the phone via USB... but via eMMC Direct, it is faster and does not care if your KEYSTORE is damaged or erased. | |
05-20-2014, 21:57 | #122 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | Quote:
And I wrote that I followed the tutorial COMPLETE and everything went OK. But still Touch Screen not working | |
06-15-2014, 15:57 | #125 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Russia,Anapa Age: 48
Member: 16938 Status: Offline Thanks Meter: 28 | All doe twice! Not working! I had read all topic and have error when try to flash: Sending OSBL Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED BUT I ALREADY WROTE OS PARTITION DIERECTLY eMMC connect (RM803_12460_prod_231_05_boot.esco) WHAT SUPPOSE TO DO? |
06-15-2014, 19:11 | #126 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | ATF doesn't support damaged keystore repair at this moment. But it allow you to write boots and flash via eMMC Direct. After flash phone should work normal but you can't flash this phone directly via USB next time. You will always need eMMC Direct to write flash boot.esco |
06-20-2014, 06:36 | #128 (permalink) | |
Member: 16938 Status: Offline Thanks Meter: 28 | Quote:
06-20-2014, 09:51 | #130 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Russia norten-caucasus Age: 52
Member: 18234 Status: Offline Thanks Meter: 97 | or plz loock my solution how repair phone -http://forum.gsmhosting.com/vbb/f609/after-repair-boot-lumia-710-rm-803-error-data-rejected-seq-0x3-1703842/index2.html |
01-13-2015, 11:40 | #132 (permalink) |
No Life Poster Join Date: Feb 2010 Location: 90-region Age: 39
Member: 1246378 Status: Offline Thanks Meter: 123 | help no flashed log Windows Phone Flashing Started OSBL File Found: RM801_12w22_prod_generic_nokia_osbl.esco AMSS File Found: RM801_12w22_prod_generic_amss.esco ADSP File Found: RM801_12w22_prod_generic_adsp.esco WPOS File Found: RM801_12220_prod_418_05_boot.esco USER AREA ERASE File Found: RM801_12w22_prod_generic_user_area_erase.esco ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== Process Cancelled... ERROR: Data Rejected at SEQ 0x1 ERROR: Data Rejected at SEQ 0x2 Sending OSBL Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED |
02-06-2015, 18:18 | #133 (permalink) |
No Life Poster Join Date: Feb 2008 Location: KABUPATEN SLEMAN
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | please help... my phone dead just vibrate try repair with tp but error mbr cannt write ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 90014A48594E4958205C08FBA57C CSD : D04F01320F5903FFFFFFFFFF8A400001 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 8192 KB USER AREA SIZE : 15896412160 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB Lumia 800/800C Detected eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : HYNIX Product Rev : 5.12 Product SN : 08FBA57C Manufactured : January 2011 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 300 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 90014A48594E4958205C08FBA57C_73DFE5E7.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Writing MBR... Block Write CRC Error ERROR: Block Write Failed at 0x00000000 Check your Test Point Soldering! ERROR: WRITE FAILED! Total Elapsed Time 00:00:01 |
03-14-2015, 14:08 | #134 (permalink) |
Freak Poster Join Date: Mar 2009 Location: 75.BAITUN NOOR SHOPPING CENTER
Member: 987131 Status: Offline Sonork: 100.1614852 Thanks Meter: 25 | ERROR Qualcomm MMC Storage is NOT FOUND ERROR: Qualcomm MMC Storage is NOT FOUND Make sure your are running AdvanceBox.exe with Administrator Priviledges ================================================== ==== How To Run AdvanceBox.exe "as administrator" ================================================== ==== 1. Close ATF Software 2. Goto C:\AdvanceBox Turbo Flasher\ 3. Right-Click Mouse on File AdvanceBox.exe 4. Select "Run as administrator" Maybe your Phone is not running QCOM OSBL ================================================== ==== How To Enter Qualcomm MMC Storage Mode ================================================== ==== 1. Power OFF the Phone 2. Press and HOLD Volume UP Button on the Phone 3. Connect USB Cable to Phone Maybe your Phone is does not have QCOM OSBL ??? ================================================== ==== How To Put QCOM OSBL into the Phone ================================================== ==== 1. Lumia 710 - VIA USB Flashing 2. Lumia 800 - VIA TP Boot Repair 3. Other Lumia Models are NOT SUPPORTED Lumia 800 dead Please help ATF Team |
