12-14-2013, 02:31 | #1 (permalink) |
Freak Poster Join Date: Jan 2005
Member: 111423 Status: Offline Sonork: 100.1618414 Thanks Meter: 22 | SP DATA on RM-813 i have one Asha 302 RM 813 that was a problem with security code ... I have try everything to read and make reset but the guy don t want ... Do not entered in Local Mode only in Testmode sometimes not always ... So i have decide to full erase the guy but before make a backup from RPL... Now i flashed with the same firmware because i don t have other .. and rewrite RPL backup Auth SX4 and write again PM but now i can finish the job because i have Unable To read SPDATA.. and i have notice that when upload PM the last field was not write ... the logs ... Code: Booting Phone via USB... ====================================================== ====================================================== USB Phone BUSCheck Boot ====================================================== ====================================================== Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeded After 0 Tries SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 400C1921 ID DWORD 4 : 03032108 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001051 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001060 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 880E0000 ID DWORD 1 : FFFB3C40 ID DWORD 2 : 1FD7A5CA ID DWORD 3 : 6FD4C3DC ID DWORD 4 : E554CB70 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 2CAC45E2 CRC 1 : 3BC33C8B CMT Secondary Loader: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 0020 Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Reading : ISA-USER... OK! ====================================================== PHONE FIRMWARE VERSION: V 14.78 31-08-12 RM-813 (c) Nokia ====================================================== StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT ERASE_REQUEST_BB5 : 5001130D004E5043000000000000000000FD Successfully Erased... Now Writing : CMT NPC Certificate 0x0800 Bytes NPC Write Successful... StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT ERASE_REQUEST_BB5 : 5001130D0043434300000000000000000015 Successfully Erased... Now Writing : CMT CCC Certificate 0x0400 Bytes CCC Write Successful... StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT ERASE_REQUEST_BB5 : 5001130D00485743000000000000000000FC Successfully Erased... Now Writing : CMT HWC Certificate 0x0400 Bytes HWC Write Successful... StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT ERASE_REQUEST_BB5 : 5001130D0052264400000000000000000022 Successfully Erased... Now Writing : CMT R&D Certificate 0x0400 Bytes R&D Write Successful... Write Certificates OK! FlashInfo.RestartMode : Test Mode Process Done... RPL Upload Finished!!! Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 14.78 31-08-12 RM-813 (c) Nokia IMEI Plain : 355210051769723 IMEI Spare : A355210051769720 IMEI SV : 33552100517697211F Phone Model: Nokia 302 Category : Phone Phone Type : RM-813 ================================================ Extended Phone Information ================================================ Product Serial Number: 7C341DBAH Product Code : 059L1C6 Module Code : 0205095 Basic Production Code: 059J0F3 Long Production SN : 0 PPM SW Version : V 14.78 31-08-12 RM-813 (c) Nokia MEK BT MCM Version : 4217-v924 MCU SW Version : V 14.78 31-08-12 RM-813 (c) Nokia HW Version : 1500 RFIC Version : |Alli_4.3.4 DSP Version : 104_PM5_14.78 LCD Version : TPO AHNE Version : 21 RETU Version : 51 TAHVO Version : 00 Wireless LAN ID : 54:79:75:AD:11:E4 Bluetooth ID : 54:79:75:AB:D9:64 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ Unable to read SP Data.. Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 14.78 31-08-12 RM-813 (c) Nokia IMEI Plain : 355210051769723 IMEI Spare : A355210051769720 IMEI SV : 33552100517697211F Phone Model: Nokia 302 Category : Phone Phone Type : RM-813 ================================================ Extended Phone Information ================================================ Product Serial Number: 7C341DBAH Product Code : 059L1C6 Module Code : 0205095 Basic Production Code: 059J0F3 Long Production SN : 0 PPM SW Version : V 14.78 31-08-12 RM-813 (c) Nokia MEK BT MCM Version : 4217-v924 MCU SW Version : V 14.78 31-08-12 RM-813 (c) Nokia HW Version : 1500 RFIC Version : |Alli_4.3.4 DSP Version : 104_PM5_14.78 LCD Version : TPO AHNE Version : 21 RETU Version : 51 TAHVO Version : 00 Wireless LAN ID : 54:79:75:AD:11:E4 Bluetooth ID : 54:79:75:AB:D9:64 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ Unable to read SP Data.. SECURITY_TEST : PASSED PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01035602 DCC Ver: 004006 Status : OK Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... Changing Phone Mode... (Wait for 10 seconds) Successfully set to : Local Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 14.78 31-08-12 RM-813 (c) Nokia IMEI Plain : 355210051769723 IMEI Spare : A355210051769720 IMEI SV : 33552100517697211F Phone Model: Nokia 302 Category : Phone Phone Type : RM-813 ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01035602 DCC Ver: 004006 Status : OK Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 14.78 31-08-12 RM-813 (c) Nokia IMEI Plain : 355210051769723 IMEI Spare : A355210051769720 IMEI SV : 33552100517697211F Phone Model: Nokia 302 Category : Phone Phone Type : RM-813 ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01035602 DCC Ver: 004006 Status : OK You selected >>> C:\Users\yugi\Downloads\01035602_004006.dcc Uploading to phone... Successfully Uploaded DCC Data Rebooting Phone... (Wait for 9 Seconds) VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 14.78 31-08-12 RM-813 (c) Nokia IMEI Plain : 355210051769723 IMEI Spare : A355210051769720 IMEI SV : 33552100517697211F Phone Model: Nokia 302 Category : Phone Phone Type : RM-813 ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01035602 DCC Ver: 004006 Status : OK Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 14.78 31-08-12 RM-813 (c) Nokia IMEI Plain : 355210051769723 IMEI Spare : A355210051769720 IMEI SV : 33552100517697211F Phone Model: Nokia 302 Category : Phone Phone Type : RM-813 ================================================ Extended Phone Information ================================================ Product Serial Number: 7C341DBAH Product Code : 059L1C6 Module Code : 0205095 Basic Production Code: 059J0F3 Long Production SN : 0 PPM SW Version : V 14.78 31-08-12 RM-813 (c) Nokia MEK BT MCM Version : 4217-v924 MCU SW Version : V 14.78 31-08-12 RM-813 (c) Nokia HW Version : 1500 RFIC Version : |Alli_4.3.4 DSP Version : 104_PM5_14.78 LCD Version : TPO AHNE Version : 21 RETU Version : 51 TAHVO Version : 00 Wireless LAN ID : 54:79:75:AD:11:E4 Bluetooth ID : 54:79:75:AB:D9:64 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ Unable to read SP Data.. Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 14.78 31-08-12 RM-813 (c) Nokia IMEI Plain : 355210051769723 IMEI Spare : A355210051769720 IMEI SV : 33552100517697211F Phone Model: Nokia 302 Category : Phone Phone Type : RM-813 ================================================ Extended Phone Information ================================================ Product Serial Number: 7C341DBAH Product Code : 059L1C6 Module Code : 0205095 Basic Production Code: 059J0F3 Long Production SN : 0 PPM SW Version : V 14.78 31-08-12 RM-813 (c) Nokia MEK BT MCM Version : 4217-v924 MCU SW Version : V 14.78 31-08-12 RM-813 (c) Nokia HW Version : 1500 RFIC Version : |Alli_4.3.4 DSP Version : 104_PM5_14.78 LCD Version : TPO AHNE Version : 21 RETU Version : 51 TAHVO Version : 00 Wireless LAN ID : 54:79:75:AD:11:E4 Bluetooth ID : 54:79:75:AB:D9:64 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ Unable to read SP Data.. SECURITY_TEST : PASSED PHONE_MODE : LOCAL ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01035602 DCC Ver: 004006 Status : OK Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... and the problem when try to upload PM Code: Scanning USB Ports... Process Cancelled... ================================================ Basic Phone Information ================================================ MCU Version: V 14.78 31-08-12 RM-813 (c) Nokia IMEI Plain : 355210051769723 IMEI Spare : A355210051769720 IMEI SV : 33552100517697211F Phone Model: Nokia 302 Category : Phone Phone Type : RM-813 ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\ERASE_1_309.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 0 - Ok Field : 1 Sub : 1 Byte(s): 0 - Ok Field : 1 Sub : 2 Byte(s): 0 - Ok Field : 1 Sub : 3 Byte(s): 0 - Ok Field : 1 Sub : 4 Byte(s): 0 - Ok Field : 1 Sub : 5 Byte(s): 0 - Ok Field : 1 Sub : 6 Byte(s): 0 - Ok Field : 1 Sub : 7 Byte(s): 0 - Ok Field : 1 Sub : 8 Byte(s): 0 - Ok Field : 1 Sub : 9 Byte(s): 0 - Ok Field : 1 Sub : 10 Byte(s): 0 - Ok Field : 1 Sub : 11 Byte(s): 0 - Ok Field : 1 Sub : 12 Byte(s): 0 - Ok Field : 1 Sub : 13 Byte(s): 0 - Ok Field : 1 Sub : 14 Byte(s): 0 - Ok Field : 1 Sub : 15 Byte(s): 0 - Ok Field : 1 Sub : 16 Byte(s): 0 - Ok Field : 1 Sub : 17 Byte(s): 0 - Ok Field : 1 Sub : 18 Byte(s): 0 - Ok Field : 1 Sub : 19 Byte(s): 0 - Ok Field : 1 Sub : 20 Byte(s): 0 - Ok Field : 1 Sub : 21 Byte(s): 0 - Ok Field : 1 Sub : 22 Byte(s): 0 - Ok Field : 1 Sub : 23 Byte(s): 0 - Ok Field : 1 Sub : 24 Byte(s): 0 - Ok Field : 1 Sub : 25 Byte(s): 0 - Ok Field : 1 Sub : 26 Byte(s): 0 - Ok Field : 1 Sub : 27 Byte(s): 0 - Ok Field : 1 Sub : 28 Byte(s): 0 - Ok Field : 1 Sub : 29 Byte(s): 0 - Ok Field : 1 Sub : 30 Byte(s): 0 - Ok Field : 1 Sub : 31 Byte(s): 0 - Ok Field : 1 Sub : 32 Byte(s): 0 - Ok Field : 1 Sub : 33 Byte(s): 0 - Ok Field : 1 Sub : 34 Byte(s): 0 - Ok Field : 1 Sub : 35 Byte(s): 0 - Ok Field : 1 Sub : 36 Byte(s): 0 - Ok Field : 1 Sub : 37 Byte(s): 0 - Ok Field : 1 Sub : 38 Byte(s): 0 - Ok Field : 1 Sub : 39 Byte(s): 0 - Ok Field : 1 Sub : 40 Byte(s): 0 - Ok Field : 1 Sub : 41 Byte(s): 0 - Ok Field : 1 Sub : 42 Byte(s): 0 - Ok Field : 1 Sub : 43 Byte(s): 0 - Ok Field : 1 Sub : 44 Byte(s): 0 - Ok Field : 1 Sub : 45 Byte(s): 0 - Ok Field : 1 Sub : 46 Byte(s): 0 - Ok Field : 309 Sub : 0 Byte(s): 0 - Ok Field : 309 Sub : 1 Byte(s): 0 - Ok Field : 309 Sub : 2 Byte(s): 0 - Ok Field : 309 Sub : 3 Byte(s): 0 - Ok Field : 309 Sub : 4 Byte(s): 0 - Ok Field : 309 Sub : 5 Byte(s): 0 - Ok Field : 309 Sub : 6 Byte(s): 0 - Ok Field : 309 Sub : 7 Byte(s): 0 - Ok Field : 309 Sub : 8 Byte(s): 0 - Ok Field : 309 Sub : 9 Byte(s): 0 - Ok Field : 309 Sub : 10 Byte(s): 0 - Ok Field : 309 Sub : 11 Byte(s): 0 - Ok Field : 309 Sub : 12 Byte(s): 0 - Ok Field : 309 Sub : 13 Byte(s): 0 - Ok Field : 309 Sub : 14 Byte(s): 0 - Ok Field : 309 Sub : 15 Byte(s): 0 - Ok Field : 309 Sub : 16 Byte(s): 0 - Ok Field : 309 Sub : 17 Byte(s): 0 - Ok Field : 309 Sub : 18 Byte(s): 0 - Ok Field : 309 Sub : 19 Byte(s): 0 - Ok Field : 309 Sub : 20 Byte(s): 0 - Ok Field : 309 Sub : 21 Byte(s): 0 - Ok Field : 309 Sub : 22 Byte(s): 0 - Ok Field : 309 Sub : 23 Byte(s): 0 - Ok Field : 309 Sub : 24 Byte(s): 0 - Ok Field : 309 Sub : 25 Byte(s): 0 - Ok Field : 309 Sub : 26 Byte(s): 0 - Ok PM Upload Done!... Selected PM File: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\ERASE_1_309.pm Start Uploading PM... Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 14.78 31-08-12 RM-813 (c) Nokia IMEI Plain : 355210051769723 IMEI Spare : A355210051769720 IMEI SV : 33552100517697211F Phone Model: Nokia 302 Category : Phone Phone Type : RM-813 Field : 1 Sub : 0 Byte(s): 0 - Ok Field : 1 Sub : 1 Byte(s): 0 - Ok Field : 1 Sub : 2 Byte(s): 0 - Ok Field : 1 Sub : 3 Byte(s): 0 - Ok Field : 1 Sub : 4 Byte(s): 0 - Ok Field : 1 Sub : 5 Byte(s): 0 - Ok Field : 1 Sub : 6 Byte(s): 0 - Ok Field : 1 Sub : 7 Byte(s): 0 - Ok Field : 1 Sub : 8 Byte(s): 0 - Ok Field : 1 Sub : 9 Byte(s): 0 - Ok Field : 1 Sub : 10 Byte(s): 0 - Ok Field : 1 Sub : 11 Byte(s): 0 - Ok Field : 1 Sub : 12 Byte(s): 0 - Ok Field : 1 Sub : 13 Byte(s): 0 - Ok Field : 1 Sub : 14 Byte(s): 0 - Ok Field : 1 Sub : 15 Byte(s): 0 - Ok Field : 1 Sub : 16 Byte(s): 0 - Ok Field : 1 Sub : 17 Byte(s): 0 - Ok Field : 1 Sub : 18 Byte(s): 0 - Ok Field : 1 Sub : 19 Byte(s): 0 - Ok Field : 1 Sub : 20 Byte(s): 0 - Ok Field : 1 Sub : 21 Byte(s): 0 - Ok Field : 1 Sub : 22 Byte(s): 0 - Ok Field : 1 Sub : 23 Byte(s): 0 - Ok Field : 1 Sub : 24 Byte(s): 0 - Ok Field : 1 Sub : 25 Byte(s): 0 - Ok Field : 1 Sub : 26 Byte(s): 0 - Ok Field : 1 Sub : 27 Byte(s): 0 - Ok Field : 1 Sub : 28 Byte(s): 0 - Ok Field : 1 Sub : 29 Byte(s): 0 - Ok Field : 1 Sub : 30 Byte(s): 0 - Ok Field : 1 Sub : 31 Byte(s): 0 - Ok Field : 1 Sub : 32 Byte(s): 0 - Ok Field : 1 Sub : 33 Byte(s): 0 - Ok Field : 1 Sub : 34 Byte(s): 0 - Ok Field : 1 Sub : 35 Byte(s): 0 - Ok Field : 1 Sub : 36 Byte(s): 0 - Ok Field : 1 Sub : 37 Byte(s): 0 - Ok Field : 1 Sub : 38 Byte(s): 0 - Ok Field : 1 Sub : 39 Byte(s): 0 - Ok Field : 1 Sub : 40 Byte(s): 0 - Ok Field : 1 Sub : 41 Byte(s): 0 - Ok Field : 1 Sub : 42 Byte(s): 0 - Ok Field : 1 Sub : 43 Byte(s): 0 - Ok Field : 1 Sub : 44 Byte(s): 0 - Ok Field : 1 Sub : 45 Byte(s): 0 - Ok Field : 1 Sub : 46 Byte(s): 0 - Ok Field : 309 Sub : 0 Byte(s): 0 - Ok Field : 309 Sub : 1 Byte(s): 0 - Ok Field : 309 Sub : 2 Byte(s): 0 - Ok Field : 309 Sub : 3 Byte(s): 0 - Ok Field : 309 Sub : 4 Byte(s): 0 - Ok Field : 309 Sub : 5 Byte(s): 0 - Ok Field : 309 Sub : 6 Byte(s): 0 - Ok Field : 309 Sub : 7 Byte(s): 0 - Ok Field : 309 Sub : 8 Byte(s): 0 - Ok Field : 309 Sub : 9 Byte(s): 0 - Ok Field : 309 Sub : 10 Byte(s): 0 - Ok Field : 309 Sub : 11 Byte(s): 0 - Ok Field : 309 Sub : 12 Byte(s): 0 - Ok Field : 309 Sub : 13 Byte(s): 0 - Ok Field : 309 Sub : 14 Byte(s): 0 - Ok Field : 309 Sub : 15 Byte(s): 0 - Ok Field : 309 Sub : 16 Byte(s): 0 - Ok Field : 309 Sub : 17 Byte(s): 0 - Ok Field : 309 Sub : 18 Byte(s): 0 - Ok Field : 309 Sub : 19 Byte(s): 0 - Ok Field : 309 Sub : 20 Byte(s): 0 - Ok Field : 309 Sub : 21 Byte(s): 0 - Ok Field : 309 Sub : 22 Byte(s): 0 - Ok Field : 309 Sub : 23 Byte(s): 0 - Ok Field : 309 Sub : 24 Byte(s): 0 - Ok Field : 309 Sub : 25 Byte(s): 0 - Ok Field : 309 Sub : 26 Byte(s): 0 - Ok PM Upload Done!... Selected PM File: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\GENERIC_1_309.pm Start Uploading PM... Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 14.78 31-08-12 RM-813 (c) Nokia IMEI Plain : 355210051769723 IMEI Spare : A355210051769720 IMEI SV : 33552100517697211F Phone Model: Nokia 302 Category : Phone Phone Type : RM-813 Field : 1 Sub : 0 Byte(s): 114 - Ok Field : 1 Sub : 1 Byte(s): 4 - Ok Field : 1 Sub : 2 Byte(s): 86 - Ok Field : 1 Sub : 4 Byte(s): 110 - Ok Field : 1 Sub : 5 Byte(s): 4 - Ok Field : 1 Sub : 6 Byte(s): 86 - Ok Field : 1 Sub : 8 Byte(s): 110 - Ok Field : 1 Sub : 13 Byte(s): 86 - Ok Field : 1 Sub : 15 Byte(s): 4 - Ok Field : 1 Sub : 16 Byte(s): 86 - Ok Field : 1 Sub : 18 Byte(s): 86 - Ok Field : 1 Sub : 20 Byte(s): 86 - Ok Field : 1 Sub : 22 Byte(s): 16 - Ok Field : 1 Sub : 23 Byte(s): 4 - Ok Field : 1 Sub : 24 Byte(s): 84 - Ok Field : 1 Sub : 25 Byte(s): 16 - Ok Field : 1 Sub : 29 Byte(s): 6 - Ok Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 2 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 5 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 8 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok PM Upload Done!... Selected PM File: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\PM Files\RM-813.pm Start Uploading PM... Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 14.78 31-08-12 RM-813 (c) Nokia IMEI Plain : 355210051769723 IMEI Spare : A355210051769720 IMEI SV : 33552100517697211F Phone Model: Nokia 302 Category : Phone Phone Type : RM-813 Field : 1 Sub : 0 Byte(s): 12 - Ok Field : 1 Sub : 1 Byte(s): 96 - Ok Field : 1 Sub : 2 Byte(s): 112 - Ok Field : 1 Sub : 4 Byte(s): 12 - Ok Field : 1 Sub : 5 Byte(s): 48 - Ok Field : 1 Sub : 6 Byte(s): 112 - Ok Field : 1 Sub : 7 Byte(s): 452 - Ok Field : 1 Sub : 8 Byte(s): 12 - Ok Field : 1 Sub : 13 Byte(s): 112 - Ok Field : 1 Sub : 15 Byte(s): 32 - Ok Field : 1 Sub : 16 Byte(s): 32 - Ok Field : 1 Sub : 17 Byte(s): 32 - Ok Field : 1 Sub : 18 Byte(s): 32 - Ok Field : 1 Sub : 19 Byte(s): 32 - Ok Field : 1 Sub : 22 Byte(s): 24 - Ok Field : 1 Sub : 26 Byte(s): 12 - Ok Field : 1 Sub : 27 Byte(s): 36 - Ok Field : 1 Sub : 28 Byte(s): 112 - Ok Field : 1 Sub : 29 Byte(s): 12 - Ok Field : 1 Sub : 30 Byte(s): 36 - Ok Field : 1 Sub : 31 Byte(s): 24 - Ok Field : 1 Sub : 32 Byte(s): 216 - Ok Field : 1 Sub : 33 Byte(s): 36 - Ok Field : 1 Sub : 35 Byte(s): 24 - Ok Field : 1 Sub : 36 Byte(s): 24 - Ok Field : 1 Sub : 38 Byte(s): 216 - Ok Field : 1 Sub : 39 Byte(s): 36 - Ok Field : 1 Sub : 40 Byte(s): 24 - Ok Field : 1 Sub : 41 Byte(s): 216 - Ok Field : 1 Sub : 43 Byte(s): 36 - Ok Field : 1 Sub : 44 Byte(s): 216 - Ok Field : 1 Sub : 45 Byte(s): 216 - Ok Field : 2 Sub : 0 Byte(s): 2240 - Ok Field : 4 Sub : 1 Byte(s): 48 - Ok Field : 4 Sub : 3 Byte(s): 12 - Ok Field : 4 Sub : 4 Byte(s): 8 - Ok Field : 4 Sub : 5 Byte(s): 8 - Ok Field : 4 Sub : 6 Byte(s): 8 - Ok Field : 4 Sub : 9 Byte(s): 8 - Ok Field : 4 Sub : 18 Byte(s): 80 - Ok Field : 4 Sub : 19 Byte(s): 4 - Ok Field : 4 Sub : 28 Byte(s): 4 - Ok Field : 8 Sub : 0 Byte(s): 4 - Ok Field : 8 Sub : 1 Byte(s): 16 - Ok Field : 8 Sub : 2 Byte(s): 16 - Ok Field : 8 Sub : 3 Byte(s): 128 - Ok Field : 8 Sub : 4 Byte(s): 128 - Ok Field : 8 Sub : 7 Byte(s): 4 - Ok Field : 8 Sub : 8 Byte(s): 8 - Ok Field : 8 Sub : 9 Byte(s): 8 - Ok Field : 8 Sub : 10 Byte(s): 32 - Ok Field : 8 Sub : 11 Byte(s): 4 - Ok Field : 8 Sub : 12 Byte(s): 4 - Ok Field : 11 Sub : 0 Byte(s): 4 - Ok Field : 11 Sub : 1 Byte(s): 4 - Ok Field : 11 Sub : 2 Byte(s): 4 - Ok Field : 11 Sub : 3 Byte(s): 4 - Ok Field : 11 Sub : 4 Byte(s): 244 - Ok Field : 12 Sub : 0 Byte(s): 8 - Ok Field : 13 Sub : 0 Byte(s): 4 - Ok Field : 13 Sub : 1 Byte(s): 4 - Ok Field : 13 Sub : 2 Byte(s): 4 - Ok Field : 13 Sub : 3 Byte(s): 4 - Ok Field : 13 Sub : 4 Byte(s): 4 - Ok Field : 13 Sub : 5 Byte(s): 4 - Ok Field : 13 Sub : 6 Byte(s): 4 - Ok Field : 13 Sub : 7 Byte(s): 4 - Ok Field : 13 Sub : 8 Byte(s): 4 - Ok Field : 13 Sub : 9 Byte(s): 4 - Ok Field : 13 Sub : 10 Byte(s): 4 - Ok Field : 13 Sub : 11 Byte(s): 48 - Ok Field : 13 Sub : 12 Byte(s): 4 - Ok Field : 13 Sub : 13 Byte(s): 4 - Ok Field : 13 Sub : 14 Byte(s): 4 - Ok Field : 13 Sub : 15 Byte(s): 888 - Ok Field : 13 Sub : 16 Byte(s): 4 - Ok Field : 13 Sub : 17 Byte(s): 4 - Ok Field : 13 Sub : 18 Byte(s): 4 - Ok Field : 13 Sub : 19 Byte(s): 8 - Ok Field : 13 Sub : 20 Byte(s): 4 - Ok Field : 13 Sub : 21 Byte(s): 4 - Ok Field : 13 Sub : 22 Byte(s): 4 - Ok Field : 13 Sub : 23 Byte(s): 4 - Ok Field : 13 Sub : 24 Byte(s): 4 - Ok Field : 13 Sub : 25 Byte(s): 4 - Ok Field : 13 Sub : 26 Byte(s): 4 - Ok Field : 13 Sub : 27 Byte(s): 4 - Ok Field : 13 Sub : 28 Byte(s): 4 - Ok Field : 13 Sub : 29 Byte(s): 4 - Ok Field : 13 Sub : 30 Byte(s): 4 - Ok Field : 13 Sub : 31 Byte(s): 4 - Ok Field : 13 Sub : 32 Byte(s): 4 - Ok Field : 13 Sub : 33 Byte(s): 4 - Ok Field : 13 Sub : 34 Byte(s): 4 - Ok Field : 13 Sub : 35 Byte(s): 4 - Ok Field : 13 Sub : 36 Byte(s): 4 - Ok Field : 13 Sub : 37 Byte(s): 4 - Ok Field : 13 Sub : 38 Byte(s): 4 - Ok Field : 13 Sub : 39 Byte(s): 4 - Ok Field : 13 Sub : 40 Byte(s): 4 - Ok Field : 13 Sub : 41 Byte(s): 4 - Ok Field : 13 Sub : 42 Byte(s): 4 - Ok Field : 13 Sub : 43 Byte(s): 4 - Ok Field : 13 Sub : 44 Byte(s): 4 - Ok Field : 13 Sub : 45 Byte(s): 4 - Ok Field : 13 Sub : 46 Byte(s): 4 - Ok Field : 13 Sub : 47 Byte(s): 4 - Ok Field : 13 Sub : 48 Byte(s): 4 - Ok Field : 13 Sub : 49 Byte(s): 4 - Ok Field : 13 Sub : 50 Byte(s): 4 - Ok Field : 13 Sub : 51 Byte(s): 4 - Ok Field : 13 Sub : 52 Byte(s): 4 - Ok Field : 13 Sub : 53 Byte(s): 4 - Ok Field : 13 Sub : 54 Byte(s): 4 - Ok Field : 13 Sub : 55 Byte(s): 4 - Ok Field : 13 Sub : 56 Byte(s): 4 - Ok Field : 13 Sub : 57 Byte(s): 4 - Ok Field : 13 Sub : 58 Byte(s): 4 - Ok Field : 13 Sub : 59 Byte(s): 4 - Ok Field : 13 Sub : 60 Byte(s): 4 - Ok Field : 13 Sub : 61 Byte(s): 4 - Ok Field : 13 Sub : 62 Byte(s): 4 - Ok Field : 13 Sub : 63 Byte(s): 4 - Ok Field : 13 Sub : 64 Byte(s): 4 - Ok Field : 13 Sub : 65 Byte(s): 4 - Ok Field : 13 Sub : 66 Byte(s): 4 - Ok Field : 13 Sub : 67 Byte(s): 4 - Ok Field : 13 Sub : 68 Byte(s): 4 - Ok Field : 13 Sub : 69 Byte(s): 4 - Ok Field : 13 Sub : 70 Byte(s): 4 - Ok Field : 13 Sub : 71 Byte(s): 4 - Ok Field : 13 Sub : 72 Byte(s): 4 - Ok Field : 13 Sub : 73 Byte(s): 4 - Ok Field : 13 Sub : 74 Byte(s): 4 - Ok Field : 13 Sub : 75 Byte(s): 4 - Ok Field : 13 Sub : 76 Byte(s): 4 - Ok Field : 13 Sub : 77 Byte(s): 4 - Ok Field : 13 Sub : 78 Byte(s): 4 - Ok Field : 13 Sub : 79 Byte(s): 4 - Ok Field : 13 Sub : 80 Byte(s): 4 - Ok Field : 13 Sub : 81 Byte(s): 4 - Ok Field : 13 Sub : 82 Byte(s): 4 - Ok Field : 13 Sub : 83 Byte(s): 4 - Ok Field : 13 Sub : 84 Byte(s): 4 - Ok Field : 13 Sub : 85 Byte(s): 4 - Ok Field : 13 Sub : 86 Byte(s): 4 - Ok Field : 13 Sub : 87 Byte(s): 4 - Ok Field : 13 Sub : 88 Byte(s): 4 - Ok Field : 13 Sub : 89 Byte(s): 4 - Ok Field : 13 Sub : 90 Byte(s): 4 - Ok Field : 13 Sub : 91 Byte(s): 4 - Ok Field : 13 Sub : 92 Byte(s): 4 - Ok Field : 13 Sub : 93 Byte(s): 4 - Ok Field : 13 Sub : 94 Byte(s): 4 - Ok Field : 13 Sub : 95 Byte(s): 4 - Ok Field : 13 Sub : 96 Byte(s): 4 - Ok Field : 13 Sub : 97 Byte(s): 4 - Ok Field : 13 Sub : 98 Byte(s): 4 - Ok Field : 13 Sub : 99 Byte(s): 4 - Ok Field : 13 Sub : 100 Byte(s): 4 - Ok Field : 13 Sub : 101 Byte(s): 4 - Ok Field : 13 Sub : 102 Byte(s): 4 - Ok Field : 13 Sub : 103 Byte(s): 4 - Ok Field : 13 Sub : 104 Byte(s): 4 - Ok Field : 13 Sub : 105 Byte(s): 4 - Ok Field : 13 Sub : 106 Byte(s): 4 - Ok Field : 13 Sub : 107 Byte(s): 4 - Ok Field : 13 Sub : 108 Byte(s): 4 - Ok Field : 13 Sub : 109 Byte(s): 4 - Ok Field : 13 Sub : 110 Byte(s): 4 - Ok Field : 13 Sub : 111 Byte(s): 4 - Ok Field : 13 Sub : 112 Byte(s): 4 - Ok Field : 13 Sub : 113 Byte(s): 4 - Ok Field : 13 Sub : 114 Byte(s): 4 - Ok Field : 13 Sub : 115 Byte(s): 4 - Ok Field : 13 Sub : 116 Byte(s): 4 - Ok Field : 13 Sub : 117 Byte(s): 4 - Ok Field : 13 Sub : 118 Byte(s): 4 - Ok Field : 13 Sub : 119 Byte(s): 4 - Ok Field : 13 Sub : 120 Byte(s): 4 - Ok Field : 13 Sub : 121 Byte(s): 4 - Ok Field : 13 Sub : 122 Byte(s): 4 - Ok Field : 13 Sub : 123 Byte(s): 8 - Ok Field : 13 Sub : 124 Byte(s): 4 - Ok Field : 13 Sub : 125 Byte(s): 4 - Ok Field : 13 Sub : 126 Byte(s): 4 - Ok Field : 13 Sub : 127 Byte(s): 4 - Ok Field : 13 Sub : 128 Byte(s): 4 - Ok Field : 13 Sub : 129 Byte(s): 4 - Ok Field : 13 Sub : 130 Byte(s): 4 - Ok Field : 13 Sub : 131 Byte(s): 4 - Ok Field : 13 Sub : 132 Byte(s): 4 - Ok Field : 13 Sub : 133 Byte(s): 4 - Ok Field : 13 Sub : 134 Byte(s): 4 - Ok Field : 13 Sub : 135 Byte(s): 4 - Ok Field : 13 Sub : 136 Byte(s): 4 - Ok Field : 13 Sub : 137 Byte(s): 4 - Ok Field : 13 Sub : 138 Byte(s): 4 - Ok Field : 13 Sub : 139 Byte(s): 4 - Ok Field : 13 Sub : 140 Byte(s): 4 - Ok Field : 13 Sub : 141 Byte(s): 4 - Ok Field : 13 Sub : 142 Byte(s): 4 - Ok Field : 13 Sub : 143 Byte(s): 4 - Ok Field : 13 Sub : 144 Byte(s): 4 - Ok Field : 13 Sub : 145 Byte(s): 8 - Ok Field : 13 Sub : 146 Byte(s): 4 - Ok Field : 13 Sub : 147 Byte(s): 4 - Ok Field : 13 Sub : 148 Byte(s): 4 - Ok Field : 13 Sub : 149 Byte(s): 4 - Ok Field : 13 Sub : 150 Byte(s): 4 - Ok Field : 13 Sub : 151 Byte(s): 4 - Ok Field : 13 Sub : 152 Byte(s): 4 - Ok Field : 13 Sub : 153 Byte(s): 4 - Ok Field : 13 Sub : 154 Byte(s): 4 - Ok Field : 13 Sub : 155 Byte(s): 4 - Ok Field : 13 Sub : 156 Byte(s): 4 - Ok Field : 13 Sub : 157 Byte(s): 4 - Ok Field : 13 Sub : 158 Byte(s): 4 - Ok Field : 13 Sub : 159 Byte(s): 4 - Ok Field : 13 Sub : 160 Byte(s): 4 - Ok Field : 13 Sub : 161 Byte(s): 4 - Ok Field : 13 Sub : 162 Byte(s): 4 - Ok Field : 13 Sub : 163 Byte(s): 4 - Ok Field : 13 Sub : 164 Byte(s): 4 - Ok Field : 13 Sub : 165 Byte(s): 4 - Ok Field : 13 Sub : 166 Byte(s): 4 - Ok Field : 26 Sub : 0 Byte(s): 16 - Ok Field : 26 Sub : 1 Byte(s): 68 - Ok Field : 31 Sub : 4 Byte(s): 20 - Ok Field : 42 Sub : 0 Byte(s): 4 - Ok Field : 42 Sub : 1 Byte(s): 12 - Ok Field : 42 Sub : 2 Byte(s): 36 - Ok Field : 42 Sub : 3 Byte(s): 36 - Ok Field : 42 Sub : 4 Byte(s): 36 - Ok Field : 42 Sub : 5 Byte(s): 36 - Ok Field : 42 Sub : 6 Byte(s): 36 - Ok Field : 42 Sub : 7 Byte(s): 40 - Ok Field : 42 Sub : 8 Byte(s): 40 - Ok Field : 42 Sub : 9 Byte(s): 40 - Ok Field : 42 Sub : 10 Byte(s): 40 - Ok Field : 42 Sub : 11 Byte(s): 40 - Ok Field : 42 Sub : 12 Byte(s): 40 - Ok Field : 42 Sub : 13 Byte(s): 40 - Ok Field : 42 Sub : 14 Byte(s): 40 - Ok Field : 42 Sub : 15 Byte(s): 40 - Ok Field : 42 Sub : 16 Byte(s): 40 - Ok Field : 42 Sub : 17 Byte(s): 40 - Ok Field : 42 Sub : 18 Byte(s): 40 - Ok Field : 42 Sub : 19 Byte(s): 40 - Ok Field : 42 Sub : 20 Byte(s): 40 - Ok Field : 42 Sub : 21 Byte(s): 40 - Ok Field : 42 Sub : 22 Byte(s): 40 - Ok Field : 42 Sub : 23 Byte(s): 40 - Ok Field : 42 Sub : 24 Byte(s): 40 - Ok Field : 42 Sub : 25 Byte(s): 40 - Ok Field : 42 Sub : 26 Byte(s): 40 - Ok Field : 44 Sub : 0 Byte(s): 4 - Ok Field : 50 Sub : 0 Byte(s): 4 - Ok Field : 50 Sub : 1 Byte(s): 4 - Ok Field : 54 Sub : 0 Byte(s): 4 - Ok Field : 88 Sub : 0 Byte(s): 36 - Ok Field : 96 Sub : 0 Byte(s): 4 - Ok Field : 96 Sub : 1 Byte(s): 20 - Ok Field : 107 Sub : 0 Byte(s): 24 - Ok Field : 107 Sub : 1 Byte(s): 92 - Ok Field : 107 Sub : 2 Byte(s): 72 - Ok Field : 107 Sub : 3 Byte(s): 72 - Ok Field : 107 Sub : 24 Byte(s): 596 - Ok Field : 107 Sub : 25 Byte(s): 136 - Ok Field : 107 Sub : 26 Byte(s): 12 - Ok Field : 116 Sub : 0 Byte(s): 4 - Ok Field : 116 Sub : 1 Byte(s): 12 - Ok Field : 116 Sub : 2 Byte(s): 36 - Ok Field : 116 Sub : 3 Byte(s): 36 - Ok Field : 116 Sub : 4 Byte(s): 36 - Ok Field : 116 Sub : 5 Byte(s): 36 - Ok Field : 116 Sub : 6 Byte(s): 36 - Ok Field : 116 Sub : 7 Byte(s): 40 - Ok Field : 116 Sub : 8 Byte(s): 40 - Ok Field : 116 Sub : 9 Byte(s): 40 - Ok Field : 116 Sub : 10 Byte(s): 40 - Ok Field : 116 Sub : 11 Byte(s): 40 - Ok Field : 116 Sub : 12 Byte(s): 40 - Ok Field : 116 Sub : 13 Byte(s): 40 - Ok Field : 116 Sub : 14 Byte(s): 40 - Ok Field : 116 Sub : 15 Byte(s): 40 - Ok Field : 116 Sub : 16 Byte(s): 40 - Ok Field : 153 Sub : 0 Byte(s): 68 - Ok Field : 153 Sub : 1 Byte(s): 68 - Ok Field : 153 Sub : 2 Byte(s): 68 - Ok Field : 153 Sub : 3 Byte(s): 68 - Ok Field : 153 Sub : 4 Byte(s): 68 - Ok Field : 153 Sub : 5 Byte(s): 68 - Ok Field : 193 Sub : 2 Byte(s): 8 - Ok Field : 193 Sub : 3 Byte(s): 32 - Ok Field : 193 Sub : 4 Byte(s): 32 - Ok Field : 193 Sub : 9 Byte(s): 64 - Ok Field : 217 Sub : 0 Byte(s): 32 - Ok Field : 218 Sub : 0 Byte(s): 4 - Ok Field : 238 Sub : 1 Byte(s): 4 - Ok Field : 239 Sub : 0 Byte(s): 4 - Ok Field : 239 Sub : 1 Byte(s): 11732 - Ok Field : 239 Sub : 2 Byte(s): 11732 - Ok Field : 296 Sub : 0 Byte(s): 4 - Ok Field : 296 Sub : 1 Byte(s): 4 - Ok Field : 296 Sub : 2 Byte(s): 24 - Ok Field : 296 Sub : 3 Byte(s): 8 - Ok Field : 301 Sub : 0 Byte(s): 4 - Ok Field : 301 Sub : 1 Byte(s): 12 - Ok Field : 301 Sub : 2 Byte(s): 36 - Ok Field : 301 Sub : 3 Byte(s): 36 - Ok Field : 301 Sub : 4 Byte(s): 36 - Ok Field : 301 Sub : 5 Byte(s): 36 - Ok Field : 301 Sub : 6 Byte(s): 36 - Ok Field : 301 Sub : 7 Byte(s): 40 - Ok Field : 301 Sub : 8 Byte(s): 40 - Ok Field : 301 Sub : 9 Byte(s): 40 - Ok Field : 301 Sub : 10 Byte(s): 40 - Ok Field : 301 Sub : 11 Byte(s): 40 - Ok Field : 301 Sub : 12 Byte(s): 40 - Ok Field : 301 Sub : 13 Byte(s): 40 - Ok Field : 301 Sub : 14 Byte(s): 40 - Ok Field : 301 Sub : 15 Byte(s): 40 - Ok Field : 301 Sub : 16 Byte(s): 40 - Ok Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 4 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 3 Byte(s): 36 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok Field : 313 Sub : 0 Byte(s): 192 - Ok Field : 322 Sub : 0 Byte(s): 4 - Ok Field : 334 Sub : 0 Byte(s): 4 - Ok Field : 339 Sub : 0 Byte(s): 512 - Ok Field : 339 Sub : 1 Byte(s): 512 - Ok Field : 341 Sub : 0 Byte(s): 4 - Ok Field : 341 Sub : 3 Byte(s): 4 - Ok Field : 341 Sub : 4 Byte(s): 4392 - Ok Field : 341 Sub : 5 Byte(s): 4 - Ok Field : 341 Sub : 6 Byte(s): 2380 - Ok Field : 354 Sub : 0 Byte(s): 28 - Ok Field : 355 Sub : 0 Byte(s): 9992 - Ok Field : 356 Sub : 0 Byte(s): 4 - Ok Field : 360 Sub : 0 Byte(s): 4 - Ok Field : 360 Sub : 1 Byte(s): 4 - Ok Field : 360 Sub : 2 Byte(s): 4 - Ok Field : 362 Sub : 0 Byte(s): 0 - Failed PM Upload Done!... Any Help please ... Tank s |
