04-10-2015, 16:56 | #31 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Quote:
Change in software settings VCCIO to 3.3 in adaptor Solder VCC &VCCQ to 3.3 try again | |
The Following User Says Thank You to Smart-gsm For This Useful Post: |
04-11-2015, 02:44 | #32 (permalink) |
Freak Poster Join Date: Aug 2011
Member: 1633328 Status: Offline Thanks Meter: 37 | Advice Hello Team. this is a very good tool but I'd like to know what's the best temperature to desolder the EMMC. I'd like to try but I dont want to burn it and if there is any other advice, tool etc.. for to do I would appreciate it. Regard tukara |
The Following User Says Thank You to tukara For This Useful Post: |
04-11-2015, 13:10 | #34 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
04-11-2015, 14:11 | #35 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Italy, Bahrain, India Age: 53
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 254 | Quote:
Depends on what you'll use to desolder it. Hot air?? Infrared? Try around 260-300 degrees | |
The Following User Says Thank You to excessive For This Useful Post: |
04-11-2015, 17:27 | #37 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2228227 Status: Offline Thanks Meter: 5 | eMMC Boot Information Revision 1.6 (for MMC v4.5, v4.51) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : 000000 Product Rev : 0.12 Product SN : 20130128 Manufactured : January 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO After update firmware emmc name still 000000 ..plz help |
The Following 2 Users Say Thank You to caos ad For This Useful Post: |
04-12-2015, 13:49 | #38 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @caos ad Make sure that when you UPDATE FIRMWARE, that you selected correct FIRMWARE for your eMMC and that the RED TEST POINT is no longer connected to GND. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
04-12-2015, 14:24 | #39 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | HI What about Read/Write FW Button? I have a lot Different Type of working eMMC How Can I Read FW+bootrom ?Then How Can I Write to Same eMMC with 00000 ID ??? |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
04-12-2015, 14:45 | #40 (permalink) | |
Member: 1633328 Status: Offline Thanks Meter: 37 | Quote:
Hello, very good question. Now I have one question for you. Does Riff Box can do this (emmc direct repair) and all that you are asking now ? BR Tukara Sent from my iPhone using Tapatalk | |
04-12-2015, 22:20 | #44 (permalink) | |
P.d. remember that at the end for get to "00000" nust need only one very small wire for Tp, after you cut this and write "eMMc fw"...so can also Not use any soket... BR | |
04-13-2015, 15:41 | #45 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | i have 2 samsung s3 dead conditon i alredy try mmc methed but phone not alive i direct connect in pcb but cant connect so i need help in emmc pinout for direct programing without pcb i alredy make new thread here http://forum.gsmhosting.com/vbb/f609...ndset-1937585/ |
