06-26-2015, 14:52 | #106 (permalink) |
Insane Poster Join Date: Jul 2009 Location: BEST is the BEST)) Age: 42
Member: 1078531 Status: Offline Sonork: 12345 Thanks Meter: 31 | orif Junior Member Join Date: Jul 2009 Location: BEST is the BEST)) Age: 33 Posts: 13 Member: 1078531 Status: Online Sonork: 12345 Thanks Meter: 3 excellent update but no result for me File Author: ATF Team @ X-Shadow Date Created: 23/04/2015 (dd/mm/yyyy) Description: Samsung eMMC Firmware eMMC Part Number: KMV3W000LM-B310 eMMC Product Name: V3W00M eMMC Product Rev: 0.0 Preparing eMMC for Firmware Update... Sending eMMC Firmware Blocks... All Blocks Sent! NAND Write Delay: 1 Second (Please Wait) Applying eMMC Firmware Update... Waiting for Device Re-Initialization... Firmware Write Protect Delay: 1 Second (Please Wait) Checking eMMC Firmware Update Status... Applying Final Patches... Block Write CRC Error 0x02 ERROR: eMMC Firmware Programming Failed 0x04 Total Elapsed Time 00:00:08 |
The Following User Says Thank You to orif For This Useful Post: |
06-30-2015, 08:41 | #108 (permalink) | |
Freak Poster Join Date: Sep 2002 Location: Bulgaria Age: 46
Member: 15921 Status: Offline Thanks Meter: 29 | Quote:
Code: 10:27:33 : Interface Reset OK! 10:27:33 : eMMC Access Type: SECTOR MODE 10:27:33 : eMMC Supported Voltage Range: 10:27:33 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 10:27:33 : 10:27:33 : CID : 1501003030303030305620110726589D 10:27:33 : CSD : 902701320F5903FFF6DBFFEF8A404023 10:27:33 : 10:27:33 : eMMC Boot Information 10:27:33 : Revision 1.5 (for MMC v4.41) 10:27:33 : BOOT PARTITION : NOT BOOT ENABLED 10:27:33 : PARTITION ACCESS : R/W USER PARTITION 10:27:33 : PERM_BOOT_CFG_PROT : DISABLED 10:27:33 : PWR_BOOT_CFG_PROT : DISABLED 10:27:33 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 10:27:33 : RESET BUS WIDTH : ENABLED 10:27:33 : eMMC FirmW UPDATE : DISABLED 10:27:33 : EMMC CACHE SIZE : 0 KB 10:27:33 : SUPER PAGE SIZE : 4096 KB 10:27:33 : HC ERASE GROUP SIZE: 512 KB 10:27:33 : USER AREA SIZE : 17179869184 BYTES 10:27:33 : BOOT PARTITION SIZE: 512 KB 10:27:33 : RPMB PARTITION SIZE: 128 KB 10:27:33 : 10:27:33 : 10:27:33 : eMMC Device Information 10:27:33 : Manufacturer ID: SAMSUNG 10:27:33 : Device Type : Embedded BGA 10:27:33 : Application ID : 00 10:27:33 : Product Name : 000000 10:27:33 : Product Rev : 5.6 10:27:33 : Product SN : 20110726 10:27:33 : Manufactured : January 2005 10:27:33 : 10:27:33 : Card Specific Data 10:27:33 : CSD_STRUCTURE : Version 1.2 10:27:33 : SPEC_VERS : Version 4.1/4.2/4.3 10:27:33 : TAAC : 13 ns 10:27:33 : TRAN_SPEED : 4000000 KHz 10:27:33 : READ_BL_LEN : 512 Bytes 10:27:33 : C_SIZE : HIGH CAPACITY 10:27:33 : WP_GRP_ENABLE : YES 10:27:33 : WRITE_BL_LEN : 512 Bytes 10:27:33 : CONTENT_PROT_APP : NO 10:27:33 : PERM_WRITE_PROTECT: NO 10:27:33 : TMP_WRITE_PROTECT : NO 10:27:33 : 10:27:33 : Extended CSD Saved: 10:27:33 : 1501003030303030305620110726589D.ext_csd 10:27:33 : Backup Directory: 10:27:33 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 10:27:33 : 10:27:37 : 10:27:37 : Task Selected: Samsung eMMC Firmware Update 10:27:37 : ====================================================== 10:27:37 : --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB 10:27:37 : --> This will RESET EXT_CSD Programming Such as BOOT 10:27:37 : Options, Bus Characteristics and Partition Sizes.. 10:27:37 : ====================================================== 10:27:37 : 10:27:37 : Please Manually Select the Correct 10:27:37 : Part Number of your eMMC Device. 10:27:37 : 10:27:37 : ====================================================== 10:27:37 : If you select a WRONG PART NUMBER, then 10:27:37 : YOU WILL PROBABLY KILL THE EMMC !!! 10:27:37 : ====================================================== 10:27:43 : 10:27:43 : ====================================================== 10:27:43 : Loading ATF eMMC Firmware File... (Please Wait) 10:27:43 : ====================================================== 10:27:43 : 10:27:43 : 10:27:46 : File Author: ATF Team @ X-Shadow 10:27:46 : Date Created: 29/06/2015 (dd/mm/yyyy) 10:27:46 : Description: Samsung eMMC Firmware 10:27:46 : eMMC Part Number: KLMAG2GE4A-A002 10:27:46 : eMMC Product Name: MAG2GA 10:27:46 : eMMC Product Rev: 0.7 10:27:46 : 10:27:46 : Preparing eMMC for Firmware Update... 10:28:25 : Sending eMMC Firmware Blocks... 10:28:27 : All Blocks Sent! 10:28:27 : NAND Write Delay: 1 Second (Please Wait) 10:28:28 : Applying eMMC Firmware Update... 10:28:28 : Waiting for Device Re-Initialization... 10:28:28 : Firmware Write Protect Delay: 1 Second (Please Wait) 10:28:29 : Checking eMMC Firmware Update Status... 10:28:47 : ERROR: eMMC EXT_CSD Patch Failed 0x01 10:28:47 : Check your Test Point Soldering! 10:28:47 : Total Elapsed Time 00:01:00 | |
The Following User Says Thank You to ribaria For This Useful Post: |
06-30-2015, 16:48 | #109 (permalink) |
Junior Member Join Date: Oct 2014 Location: Karachi Pakistan
Member: 2270935 Status: Offline Thanks Meter: 3 | Hello ATF Team I have a question Can this tool fix my G3 D855 eMMC ?? I tried JTAG method but it didn't help Need your help sir Kindly provide me the link for G3 eMMc repair by ATF so I can repair it easily and step by step Thanks |
The Following User Says Thank You to zohaibkhan143 For This Useful Post: |
07-02-2015, 10:52 | #110 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: slovenia Age: 48
Member: 18028 Status: Offline Thanks Meter: 20 | Quote:
I'm having same problem with p5100 emmc KLMAG2GE4A-A002. Here is my log: Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501003030303030305620110726589D CSD : 902701320F5903FFF6DBFFEF8A404023 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 17179869184 BYTES BOOT PARTITION SIZE: 512 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : 000000 Product Rev : 5.6 Product SN : 20110726 Manufactured : January 2005 Card Specific Data CSD_STRUCTURE : Version 1.2 SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501003030303030305620110726589D.ext_csd Backup Directory: H:\atf\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Samsung eMMC Firmware Update ====================================================== --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB --> This will RESET EXT_CSD Programming Such as BOOT Options, Bus Characteristics and Partition Sizes.. ====================================================== Please Manually Select the Correct Part Number of your eMMC Device. ====================================================== If you select a WRONG PART NUMBER, then YOU WILL PROBABLY KILL THE EMMC !!! ====================================================== ====================================================== Loading ATF eMMC Firmware File... (Please Wait) ====================================================== File Author: ATF Team @ X-Shadow Date Created: 29/06/2015 (dd/mm/yyyy) Description: Samsung eMMC Firmware eMMC Part Number: KLMAG2GE4A-A002 eMMC Product Name: MAG2GA eMMC Product Rev: 0.7 Preparing eMMC for Firmware Update... Sending eMMC Firmware Blocks... All Blocks Sent! NAND Write Delay: 1 Second (Please Wait) Applying eMMC Firmware Update... Waiting for Device Re-Initialization... Firmware Write Protect Delay: 1 Second (Please Wait) Checking eMMC Firmware Update Status... ERROR: eMMC Firmware Programming Failed 0x02 Total Elapsed Time 00:01:07 Procedure is : 1. connect soldered emmc to ATF with testpoint connected. 2. Scan emmc 3. Disconnect testpoint 4. Update fw + format. All other emmc's I've done are working, only this is giving me problems. Any Clue? P.S. emmc gets detected only if TP is connected to GND. br | |
The Following 2 Users Say Thank You to VELIKI For This Useful Post: |
07-05-2015, 22:03 | #111 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | @VELIKI Try Select KMV3U000LM or KMVISU00LM Manuly |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
07-05-2015, 22:07 | #112 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
As I Know All D855 is San-DisK ,So You Can't Repair,Only You can Replae by New One Good Luck | |
07-09-2015, 19:57 | #113 (permalink) |
Junior Member Join Date: Dec 2014 Location: Ukraine
Member: 2310472 Status: Offline Thanks Meter: 3 | Klmag2ge4a-a002 repair failed Code: Description: Samsung eMMC Firmware eMMC Part Number: KLMAG2GE4A-A002 eMMC Product Name: MAG2GA eMMC Product Rev: 0.7 Preparing eMMC for Firmware Update... Sending eMMC Firmware Blocks... All Blocks Sent! NAND Write Delay: 1 Second (Please Wait) Applying eMMC Firmware Update... Waiting for Device Re-Initialization... Firmware Write Protect Delay: 1 Second (Please Wait) Checking eMMC Firmware Update Status... ERROR: eMMC EXT_CSD Patch Failed 0x01 Check your Test Point Soldering! Total Elapsed Time 00:01:03 |
The Following User Says Thank You to victormobium For This Useful Post: |
07-10-2015, 09:57 | #114 (permalink) |
Member: 15921 Status: Offline Thanks Meter: 29 | I try to update KLMAG2GE4A-A002 with KMV3U000LM and KMVISU00LM firmware. With KMVISU00LM have success, now emmc connects without TP but if I try another operation for repair everything go back to first broken state. Code: File Author: ATF Team @ Babak Nuri Date Created: 04/06/2015 (dd/mm/yyyy) Description: Samsung eMMC Firmware eMMC Part Number: KMVIS000LM-B503 eMMC Product Name: VIS00M eMMC Product Rev: 0.9 Preparing eMMC for Firmware Update... Sending eMMC Firmware Blocks... All Blocks Sent! NAND Write Delay: 1 Second (Please Wait) Applying eMMC Firmware Update... Waiting for Device Re-Initialization... Firmware Write Protect Delay: 1 Second (Please Wait) Checking eMMC Firmware Update Status... Applying Final Patches... eMMC Firmware Update Successful! ====================================================== Your eMMC is now a Brand New BLANK Device!!! ====================================================== Resize BOOT and RPM Partitions if needed... ReWrite BOOT1, BOOT2 and USER Partitions if needed... ReWrite EXT_CSD File if needed... Make sure eMMC BOOT Options are Correct for your Phone ====================================================== Total Elapsed Time 00:00:44 ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010056495330304D094BDE17F63F57 CSD : 902701320F5903FFF6DBFFEF8A404023 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 17179869184 BYTES BOOT PARTITION SIZE: 512 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : VIS00M Product Rev : 0.9 Product SN : 4BDE17F6 Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Version 1.2 SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010056495330304D094BDE17F63F57.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
07-10-2015, 18:04 | #115 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | @VELIKI @victormobium @ribaria ------------- use this firmware your problem will solved..... KLMAG2GE4A-A001 select firmware manualy |
The Following User Says Thank You to chand_gee For This Useful Post: |
07-13-2015, 09:56 | #117 (permalink) | |
Can't update with this firmware. Code: File Author: ATF Team @ X-Shadow Date Created: 16/04/2015 (dd/mm/yyyy) Description: Samsung eMMC Firmware eMMC Part Number: KLMAG2GE4A-A001 eMMC Product Name: MAG2GA eMMC Product Rev: 0.6 Preparing eMMC for Firmware Update... Sending eMMC Firmware Blocks... All Blocks Sent! NAND Write Delay: 1 Second (Please Wait) Applying eMMC Firmware Update... Waiting for Device Re-Initialization... Firmware Write Protect Delay: 1 Second (Please Wait) Checking eMMC Firmware Update Status... ERROR: eMMC EXT_CSD Patch Failed 0x01 Check your Test Point Soldering! Total Elapsed Time 00:01:04 | |
07-13-2015, 16:27 | #119 (permalink) |
Member: 15921 Status: Offline Thanks Meter: 29 | No ... Code: File Author: ATF Team @ X-Shadow Date Created: 16/04/2015 (dd/mm/yyyy) Description: Samsung eMMC Firmware eMMC Part Number: KLMAG2GE4A-A001 eMMC Product Name: MAG2GA eMMC Product Rev: 0.6 Preparing eMMC for Firmware Update... Sending eMMC Firmware Blocks... All Blocks Sent! NAND Write Delay: 1 Second (Please Wait) Applying eMMC Firmware Update... Waiting for Device Re-Initialization... Firmware Write Protect Delay: 1 Second (Please Wait) Checking eMMC Firmware Update Status... ERROR: eMMC Firmware Programming Failed 0x02 Total Elapsed Time 00:01:01 |
07-14-2015, 03:09 | #120 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | Now product name changed from 000000 to mag2ga try now to format samsunt factiry And writ csd backup file then boot1 Last edited by elpring; 07-14-2015 at 03:17. |
The Following User Says Thank You to elpring For This Useful Post: |
