07-01-2014, 18:55 | #1 (permalink) |
Crazy Poster Join Date: Feb 2009
Member: 966319 Status: Offline Sonork: abc Thanks Meter: 7 | succe unlock lumia 610 thank team advance box |
07-01-2014, 19:03 | #2 (permalink) |
Member: 966319 Status: Offline Sonork: abc Thanks Meter: 7 | Default language ID 0x040C JTAG Interface Connected, S/N 0xA53F930A Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 26/11/2013 10:48:00 ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...Timeout During Operation! Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 33232946 ACTIVE Level 1 PUK: 12603536 ACTIVE Level 2 PIN: 67005509 Level 2 PUK: 64762968 Level 3 PIN: 32349325 Level 3 PUK: 06786036 Level 4 PIN: 28222156 Level 4 PUK: 69814620 Level 5 PIN: 38509225 Level 5 PUK: 79514053 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...Timeout During Operation! Saving "..\Logs\Screenshots\2014-07-01_19-53-08.jpg"...OK Saving "..\Logs\Screenshots\2014-07-01_19-53-09.jpg"...OK Saving "..\Logs\Screenshots\2014-07-01_19-53-09.jpg"...OK Saving "..\Logs\Screenshots\2014-07-01_19-53-09.jpg"...OK Saving "..\Logs\Screenshots\2014-07-01_19-53-10.jpg"...OK Saving "..\Logs\Screenshots\2014-07-01_19-53-10.jpg"...OK Saving "..\Logs\Screenshots\2014-07-01_19-53-11.jpg"...OK Saving "..\Logs\Screenshots\2014-07-01_19-53-11.jpg"...OK Saving "..\Logs\Screenshots\2014-07-01_19-53-27.jpg"...OK Saving "..\Logs\Screenshots\2014-07-01_19-59-02.jpg"...OK Saving "..\Logs\Screenshots\2014-07-01_20-01-19.jpg"...OK |
