01-03-2013, 06:18 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Thank for your test report - The appropriate thread for this test report is - http://forum.gsmhosting.com/vbb/f609...-logs-1536337/ Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
01-06-2013, 12:48 | #4 (permalink) |
Freak Poster Join Date: Jul 2007 Location: ctg ,bangladesh Age: 42
Member: 538272 Status: Offline Sonork: 100.1589159 Thanks Meter: 71 | lumia 800 unlock not possibility with out testpoint |
The Following User Says Thank You to Palash Telecom_ctg For This Useful Post: |
01-06-2013, 14:13 | #5 (permalink) |
Freak Poster Join Date: Jul 2009 Age: 34
Member: 1078009 Status: Offline Thanks Meter: 12 | Do i need to repair boot to qualcomm bootloader, that i can do the unlock? or is this also possible with DLOAD? So i mean, if my phone is dload, just solder TP connection and click SP Unlock? cheers |
01-07-2013, 10:07 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,590 | Quote:
Yes, you got it right... if your phone is dload, just SP unlock with TP connection. And after you can also put qualcomm boot-loader in it, if you want to flash custom roms to your phone. BR | |
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post: |
01-07-2013, 18:39 | #7 (permalink) | |
Member: 1078009 Status: Offline Thanks Meter: 12 | Quote:
No, thanks, this will be an unlocked phone for my mum, i don't want her to accidently "destroy" her device by clicking the "format button" in windows | |
01-12-2013, 09:56 | #8 (permalink) | |
i've got another simlocked Dload lumia 800 here, and i want to unlock it and want to put qualcomm bootloader on it. Which variant is correct for me?: variant 1: 1) solder TP connection 2) Unlock phone with SP unlock 3) put qualcomm on it? or will i overwrite the unlock when i flash mbr, secboot and qualcomm? variant 2: 1) solder TP connection 2) Put qualcomm on phone 3) click SP unlock? btw: if my phone is qualcomm, can i unlock it under eMMC direct Tab with SP Unlock? cheers Last edited by lordmaxey; 01-12-2013 at 10:03. | |
01-12-2013, 10:47 | #9 (permalink) | |
1. Solder TP connection 2. Press SP unlock 3. Tick OSBL QULACOMM and Write boot-loader This is the most easiest way... If you put directly QUALCOMM boot via TP and want to unlock using eMMC direct tab - you can, but if patch not found in case, then you to have put again OSBL DLOAD via TP then Full Flash and again unlock etc. So would be good if you use above simple 3 steps. | |
01-14-2013, 23:34 | #11 (permalink) | |
Junior Member Join Date: Jan 2013
Member: 1868540 Status: Offline Thanks Meter: 0 | Quote:
Thank you very much for your attention. | |
01-15-2013, 10:15 | #13 (permalink) | |
No, its NOT possible to unlock ANY lumia phone with boot-loader DLOAD. Also, its NOT possible to install a custom rom to ANY lumia on boot-loader DLOAD. Both things requires boot-loader to be OSBL QUALCOMM. For Lumia 800 boot, use TP connection in order to change boot-loader, after you will be able to install any custom rom to it. BR | |
