12-04-2012, 12:14 | #1 (permalink) |
No Life Poster Join Date: Aug 2009
Member: 1092799 Status: Offline Sonork: 100.1603347 Thanks Meter: 111 | Successfully flashed nokia n9 REQUIRED MODE: BOOTLOADER MODE PHONET MODE Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTLOADER MODE Sending APE-ALGORITHM: SUCCESSFUL Nokia Bootloader/PhoNet Found! ================================================== ==== SECURE USER DATA ERASING IN PROGRESS ================================================== ==== Secure Data Erasing takes about 15 MINUTES... DO NOT DISCONNECT THE PHONE!!! JUST WAIT... Estimated Time to Finish Erasing: 15:46:06 (24-h Time Format) ================================================== ==== Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Processing Image: cert-sw Processing Image: cmt-2nd Processing Image: cmt-algo Processing Image: cmt-mcusw Processing Image: xloader Processing Image: secondary Processing Image: kernel Processing Image: rootfs ========================================= All Images were Succssfully Uploaded! Software Update Done []: Found 1 active devices. [Nokia N900 USB Phonet]: Opening Connection [Nokia N900 USB Phonet]: Port opened OK! Rebooting Phone... Total Flashing Time (Erase + Flashing) : 00:49:32 (Booting time is NOT Included) Phone is not Connected OR it is not in the Required Mode... Reboot the Phone and Enable "PC Suite" Mode Life timer data is not yet used... Life timer: ----:-- |
The Following User Says Thank You to nitinjaj007 For This Useful Post: |
