03-19-2014, 11:14 | #1 (permalink) |
No Life Poster Join Date: May 2005
Member: 149305 Status: Offline Sonork: 100.1612778 Thanks Meter: 804 | successfully unlocked Lumia 610 by atf jtag JTAG Interface Connected, S/N ************ Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:48:00 AM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 68184149 ACTIVE Level 1 PUK: 16711150 ACTIVE Level 2 PIN: 63844811 Level 2 PUK: 74643088 Level 3 PIN: 67544111 Level 3 PUK: 64110737 Level 4 PIN: 57861345 Level 4 PUK: 56650516 Level 5 PIN: 89379662 Level 5 PUK: 76745539 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== Thanks Team Thanks a lot |
The Following User Says Thank You to azhar63 For This Useful Post: |
