Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-29-2014, 17:49   #1 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
Team Pay Attention Need Help Kindly Answer
Hi team i need help n some question regarding ATF Jtag...
I Hope I Get Reply Soon With All My Question Ans...
* How To Backup Lumia Handset Imei N All Data (Security Area) Possible Or Not
* Erase Option Missing On ATF JTAG
*How can i make my own AFP Format Files i m having some phones in hand n some phones official ffu files By Microsoft
*After erase Imei Kept Or loss??...Any Way to protect
*Kindly Add Search option On Update Dashboard so i can search for which file i need to be download
*Kindly Add Read Option
*What is use of emmc files
i m having 1 lumia 520 in hand when i start it it show error
Unable to find a bootable option. press any key to shutdown
I Write Big Boot File Then also Not Solve how to solve this issue......
Old 10-01-2014, 03:17   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
Possible, but you need to know address of What you want to Backup. Use "LUMIA_WIN8_CUSTOM_READ_WRITE.afp" Then manually Read Address where you want to Backup.
I can add option to Automatically Select Correct Address... but actually you do not need this because it will cause you more headache. ATF AFP Files 100% NEVER TOUCHES IMEI/Simlocks Etc... So you do not need to worry about this if you just use official ATF "AFP" Files.
It is not "Missing" but rather hidden from "Normal End User" who does not want to kill phone by experimenting. If you want to see it, use "LUMIA_WIN8_CUSTOM_READ_WRITE.afp" and you will see "Read" "Write" and "Erase"... Or course, you can easily KILL PHONES with these options... that is why it was "hidden" in the first place.
Only ATF Team can make signed "AFP" files. If you have "FFU" files by microsoft, then just use "FFU Flasher via JTAG". If you install ATF 11.70 Installer, you will see "FFU Flasher" files in "Phones\Nokia" Directory. This will allow you to flash FFU files via JTAG, which is very similar to old FBUS Flashing.
IMEI / Simlocks will be erased and phone will become totally useless.
You can easily sort it according to Alphabetical Order or by order of File Size, or Data Uploaded.
".mmc" Files are like "AFP" files but for eMMC Direct Connection and via ATF Plus ----> eMMC Tool in AdvanceBox.exe. This is an alternative to JTAG because some phones do not support JTAG.
Download highest possible FFU version for your phone via NaviFirm. Make sure you match the Product Code 100% Correctly. Then you can use "FFU Flashing via JTAG". If your phone's problem is purely "SOFTWARE", then this will definitely FIX IT.
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 10-01-2014, 07:29   #3 (permalink)
Member: 1834832
Thanks Meter: 1,450
Brother help me to read simlock area for lumia 520 win 8 phone i need it because i need to complete erase phone chip as problem not solve after write boot repair file bt same problem when i powered it on show error Unable to find a bootable option. press any key to shut down
n when i try to flash then also gives error this problem happens to many phones bt not a single one get repair i didnt found any success port just search error on Google u will know everything....
So bro lets do it world 1st by atf......... ;-)
Help me bro just i need sl backup rest i will do
Can u help me to find adress
Old 10-01-2014, 08:03   #4 (permalink)
Member: 1834832
Thanks Meter: 1,450
If model not in folder then how i m having some indian brands ffu files by Microsoft not not Nokia phones Then........?
How To Read N Write Bro Imei Loss Chances As Its Emmc File Means Memory Dump....
Here is log when i write ffu file with jtag
Initializing Device...OK
Detecting EMMC #1 ID...1501004D3847325943003D3665367082
Flash Description: Samsung M8G2YC, 7.28 GiB, SN 3D366536, Jul 1997
Flash Write Protection: PERM
Partition Config: Boot from USER, Boot ACK OFF (0x38)
Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00)
Testing Device Memory...OK
Sending Flash Loader...OK (5955 Op/Sec)
FFU File Loaded: RM914_3058.50000.1425.0001_RETAIL_im_india_269_01_ 444377_prd_signed.ffu
FFU File CRC-32: Computing, Please wait...File Read Error 0x00000000
Official firmware writing Gives Error Via Jtag n normal usb both
I Try Boot Repair Also Sucess boot repair then also file not write n give same error as before on phone....flashing also same error
Hope i get help soon......... ;-)
Old 10-01-2014, 10:12   #5 (permalink)
Member: 651945
@hitech care
This means something else if using the ffu file.
Make sure NO OTHER SOFTWARE is currently using the file, like AdvanceBox.exe
Old 10-01-2014, 10:59   #6 (permalink)
Member: 1834832
Thanks Meter: 1,450
When i flash with atf box then also gives error
Nokia Phone Info Mode Initiated...
Please wait upto 15 Seconds for SW Reset
IMEI: 3xxxxxxxxxxxx
Version: 1.1.1.3
Product Code: 059S1N6
Module Code: 0205435
Continuing Previous Boot...
Please wait upto 30 Seconds for Boot Re-entry
Boot Flash Mode Successful...
Buffers Flushed OK...
Phone Info Query Start...
Blocks Returned: 0x07 Blocks
Block ID 0x01 : 00241000
Block ID 0x02 : 00240000
Block ID 0x03 : 00E90000
Block ID 0x05 : Nokia.MSM8227.P6036.1.2
Block ID 0x0D : 0001
Block ID 0x0F : 0301010100000101FF
Block ID 0x10 : 0100130000
Checking SD Card Size...
Card Size: 0x00000000
Checking Platform Security Status...
Platform Secure Boot Status: Active
Secure FFU EFUSE Status: Active
Debug Status: Active
RDC Status: Not Active
Authentication Status: Not Active
UEFI Secure Boot Status: Active
Checking Secure FFU Mode...
Secure FFU Mode :
Query Flash App Information...
Flash App Information: 02010F011C00
UEFI App: FLASH APP
Flash App Protocol Version: 1.15
Flash App Implementation Version: 1.28
Query ROOT KEY HASH...
ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD
Sending Image Signatures...
ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000)
This Flash File is NOT COMPATIBLE with this Phone.
ERROR: Flashing Failed!
Old 10-02-2014, 08:18   #7 (permalink)
Member: 651945
@hitech care
Please read post #2 and post #5
I don't want to repeat myself already.
Old 10-02-2014, 20:49   #8 (permalink)
Member: 1834832
Thanks Meter: 1,450
No resources is using FFu File I Checked........... n Bro i m asking if i write emmc file imei preserve or lost?.............
u having solution for my Nokia??........
http://forum.gsmhosting.com/vbb/f609.../#post10588976
Old 10-03-2014, 01:22   #9 (permalink)
Member: 651945
.mmc File does not overwrite IMEI and Simlocks
.afp File does not overwrite IMEI and Simlocks
Solution to your problem can be solved by yourself.
I already told you what to do.
Page generated in 0.17705 seconds with 8 queries
