02-27-2010, 05:33 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: Alien Nation
Member: 515413 Status: Offline Thanks Meter: 146 | Test flash ATF type 5310 flashing MT enable VPP 10pin cable =4:58 minutes flashing ATF with enable VPP pin 2 = Total Flashing Time: 00:04:03 (Excluding ERASE Times) flashing ATF NO connected VPP pin 2 = Total Flashing Time: 00:03:58 (Excluding ERASE Times) why disable VPP more faster than enable VPP?.. ps flashing use same cable UFC combo (with small modif if enable vpp in rj45) ,same usb port with mt . Thank you B.R |
02-27-2010, 05:47 | #2 (permalink) |
Member: 515413 Status: Offline Thanks Meter: 146 | once again try small modif again in UFC, using VPP external rj48 , when erasing show error occured ( sorry no lgo) and flashing failure.. I can try again with log if needed.. Thank you |
02-27-2010, 06:01 | #3 (permalink) | |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | Quote:
You can get logs inside the logs folder inside C:/program files/AdvanceBox Turbo Flasher/Logs/ br Thomas | |
The Following User Says Thank You to gsmfun For This Useful Post: |
02-27-2010, 06:04 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @titan_wonder Open AdvanceBox.ini Find this section: ;vpp settings ; 0: 00v, 1: 3v, 2:5v, 3: 9v, 4: 12v ;------------ VPP_SET=0 Change it to ;vpp settings ; 0: 00v, 1: 3v, 2:5v, 3: 9v, 4: 12v ;------------ VPP_SET=3 Save AdvanceBox.ini Run AdvanceBox.exe, tick Enable VPP... Then Flash with 15Mhz or 7.5Mhz (make sure phone gets VPP). Orange LED SHOULD light up when phone start ERASING. In next version,, VPP VOLTAGE is setting is AUTO-SELECTED using the Flash Chip data read during phone booting. B.R. X-Shadow |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
02-27-2010, 08:22 | #6 (permalink) |
Member: 515413 Status: Offline Thanks Meter: 146 | Code: AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : 850C6E369E48098ABB7F4E12 BOX Status : ACTIVATED DDR DELAY : 01 INIT : OK Changing MODE : FLASH Processing Image File : f:\products\RM-303\rm303__10.10.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1107 Entry Point: 0x5047 Page Format : -1 MAX PAGE : 0x00004000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 4679992 (0x38) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01013000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 26900106 ID DWORD 1 : EB660254 ID DWORD 2 : 754E4C82 ID DWORD 3 : 05A9740B ID DWORD 4 : 342C2DE5 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 5C BootCodeLen : 61 SearchForBootstrap_DCT5.. Boot File MATCH : RAP3Gv3_2nd.fg Boot File - Version : 009.011.001 Boot File - Revision : 0x0000 BB5ProtocolType == : Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 003F -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : B5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... File MATCH : RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) No partition info.... VPP Enabled by Software Using External VPP StartErase_DCT5... BlockLength : 0x0036 (54) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x33 (51) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00040000-000BFFFF 3 : 000C0000-0013FFFF 4 : 00140000-010DFFFF 5 : 010E0000-0121FFFF ERASE_REQUEST_BB5 : 5001123300000000000000000006BF000006C00001FFFF00040000000BFFFF000C00000013FFFF00140000010DFFFF010E00000121FFFFB6 Please wait ERASING......... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:06 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 Processing : rm303__10.10.mcusw Total blocks to write : 1107 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 000508000744000000F87C0000FC7C 1 Sub Block ID : 16 PROGRAMMING_ERROR_BB5 Block Length : 0F BB ASIC Index : 00 Error Type : 05 Error Spec : 08 Of*****ng Address : 00074400 Expected Content : 0000F87C Detected Content : 0000FC7C Try to change the Flashing clock... Flashing FAILED Operations Failed.... try another phone 5310,error still problem ,but disable vpp flash ok.. phone use AMD flashchip.. Thx |
02-27-2010, 08:25 | #7 (permalink) |
Member: 515413 Status: Offline Thanks Meter: 146 | Code: 13:26:55 : =================================================== 13:26:56 : AdvanceFBox SendBootCodeEx 13:26:56 : InitialiseBootstrap_DCT5 DIR 13:26:56 : BootFlashMode_DCT5 13:26:56 : BootFlashModeDCT5Ex Succeeded First Time 13:26:56 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417160 (0x08) bytes returned 13:26:56 : Number of Sub Blocks 7 (0x07) 13:26:56 : 1 SYSTEM_ASIC_ID 01 13:26:56 : Block Length : 21 (15) 13:26:56 : BB ASIC Index : 0 (00) CMT 13:26:56 : ID DWORD 0 : 00000001 13:26:56 : ID DWORD 1 : 00000226 13:26:56 : ID DWORD 2 : 00010006 13:26:56 : ID DWORD 3 : 030C1921 13:26:56 : ID DWORD 4 : 01033000 13:26:56 : 2 ROM_ID 15 13:26:56 : Block Length : 5 (05) 13:26:56 : BB ASIC Index : 0 (00) CMT 13:26:56 : ID DWORD 0 : 00000296 13:26:56 : 3 ROM_ID 15 13:26:56 : Block Length : 5 (05) 13:26:56 : BB ASIC Index : 0 (00) CMT 13:26:56 : ID DWORD 0 : 00000B22 13:26:56 : 4 PUBLIC_ID 12 13:26:56 : Block Length : 21 (15) 13:26:56 : BB ASIC Index : 0 (00) CMT 13:26:56 : ID DWORD 0 : 2160010A 13:26:56 : ID DWORD 1 : D0EC8956 13:26:56 : ID DWORD 2 : 0B4986C3 13:26:56 : ID DWORD 3 : C0A07CC8 13:26:56 : ID DWORD 4 : D57CB523 13:26:56 : 5 ASIC_MODE_ID 13 13:26:56 : Block Length : 2 (02) 13:26:56 : BB ASIC Index : 0 (00) CMT 13:26:56 : Mode Id : 00 13:26:56 : 6 ROOT_KEY_HASH 14 13:26:56 : Block Length : 17 (11) 13:26:56 : BB ASIC Index : 0 (00) CMT 13:26:56 : Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 13:26:56 : 7 ROM_ID 15 13:26:56 : Block Length : 9 (09) 13:26:56 : BB ASIC Index : 0 (00) CMT 13:26:56 : CRC 0 : 273F6D55 13:26:56 : CRC 1 : DFAAF68F 13:26:56 : Checksum 14 13:26:56 : BootCodeLen : 61 13:26:56 : SearchForBootstrap_DCT5.. 13:26:57 : Boot File MATCH : RAP3Gv3_2nd.fg 13:26:57 : Boot File - Version : 009.011.001 13:26:57 : Boot File - Revision : 0x0000 13:26:58 : BB5ProtocolType == : Original 13:26:58 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 13:26:58 : MCU_CONFIGURATION_RESPONSE_BB5: 13:26:58 : MessageID : C1 13:26:58 : SubBlocks : 03 13:26:58 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 13:26:58 : Block Length : 0B 13:26:58 : BB ASIC Index : CMT 00 13:26:58 : Device Type : NOR 00 13:26:58 : Device Index : 00 13:26:58 : Manufacturer Code : 0089 -> 13:26:58 : Device ID : 8982 -> Type not in database 13:26:58 : Extended/Fixed ID : 0000 13:26:58 : Revision ID : 8A31 13:26:58 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 13:26:58 : Block Length : 13 13:26:58 : BB ASIC Index : CMT 00 13:26:58 : Device Type : NOR 00 13:26:58 : Device Index : 00 13:26:58 : Device Contents : 00000000000000000000 13:26:58 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 13:26:58 : Block Length : 0B 13:26:58 : BB ASIC Index : CMT 00 13:26:58 : Device Type : MMC 04 13:26:58 : Device Index : 00 13:26:58 : Manufacturer Code : FFFF -> Flash 13:26:58 : Device ID : 0000 -> BAD FLASH TYPE 13:26:58 : Extended/Fixed ID : 0000 13:26:58 : Revision ID : 0000 13:26:58 : Checksum : 51 13:26:58 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 13:26:58 : FLS1SendAlgoCodeEx.. 13:26:59 : SendAlgoCode_DCT5.. 13:26:59 : SearchForAlgorithm_DCT5.. 13:26:59 : Looking for ALL Devices... 13:27:02 : NO MATCH ALGO LOADER 13:27:02 : SendAlgoCodeFile_DCT5 : Error 13:27:02 : Try TO UNPLUG RJ45 AND TRY AGAIN 13:27:02 : Failed to complete RPL backup.. 13:27:02 : =================================================== 13:27:02 : Processing Image File : F:\Products\rm-561l\rm561__07.81.mcusw 13:27:03 : CMT Type : BB5 13:27:03 : CMT Algorithm : BB5 ALGORITHM 13:27:03 : CMT Supported Hardwares : 13:27:03 : > 010C192101013000 13:27:03 : > 0103192101003000 13:27:03 : > 030C192101033000 13:27:03 : Secondary Sending Speed : 3250000Hz 13:27:03 : Algorithm Sending Speed : 6500000Hz 13:27:03 : Program Sending Speed : 6500000Hz 13:27:03 : Message Reading Speed : 98000Hz 13:27:03 : Number of Blocks : 1256 13:27:04 : Entry Point: 0x5047 13:27:04 : Page Format : -1 13:27:04 : MAX PAGE : 0x00004000 13:27:04 : AdvanceBox Turbo Flasher Found 13:27:04 : Initialize Device.... 13:27:04 : Init TRY : 1 13:27:04 : Changing Clock to 15mhz.. 13:27:06 : Box Name : AdvanceBox Turbo 13:27:06 : Box Firmware : LogiCore 1.16.10 13:27:06 : Software Version : v2010.0.1.21 13:27:06 : AdvanceBox SN : 850C6E369E48098ABB7F4E12 13:27:06 : BOX Status : ACTIVATED 13:27:06 : DDR DELAY : 01 13:27:06 : INIT : OK 13:27:06 : 13:27:06 : VBATT OFF ... 13:27:09 : VBATT ON 13:27:10 : Setting VBATT Done!... 13:27:10 : AdvanceFBox SendBootCodeEx 13:27:10 : InitialiseBootstrap_DCT5 DIR 13:27:10 : BootFlashMode_DCT5 13:27:10 : BootFlashModeDCT5Ex Succeeded First Time 13:27:10 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 4679992 (0x38) bytes returned 13:27:10 : Number of Sub Blocks 7 (0x07) 13:27:10 : 1 SYSTEM_ASIC_ID 01 13:27:10 : Block Length : 21 (15) 13:27:10 : BB ASIC Index : 0 (00) CMT 13:27:10 : ID DWORD 0 : 00000001 13:27:10 : ID DWORD 1 : 00000226 13:27:10 : ID DWORD 2 : 00010006 13:27:10 : ID DWORD 3 : 030C1921 13:27:10 : ID DWORD 4 : 01033000 13:27:10 : 2 ROM_ID 15 13:27:10 : Block Length : 5 (05) 13:27:11 : BB ASIC Index : 0 (00) CMT 13:27:11 : ID DWORD 0 : 00000296 13:27:11 : 3 ROM_ID 15 13:27:11 : Block Length : 5 (05) 13:27:11 : BB ASIC Index : 0 (00) CMT 13:27:11 : ID DWORD 0 : 00000B22 13:27:11 : 4 PUBLIC_ID 12 13:27:11 : Block Length : 21 (15) 13:27:11 : BB ASIC Index : 0 (00) CMT 13:27:11 : ID DWORD 0 : 2160010A 13:27:11 : ID DWORD 1 : D0EC8956 13:27:11 : ID DWORD 2 : 0B4986C3 13:27:11 : ID DWORD 3 : C0A07CC8 13:27:11 : ID DWORD 4 : D57CB523 13:27:11 : 5 ASIC_MODE_ID 13 13:27:11 : Block Length : 2 (02) 13:27:11 : BB ASIC Index : 0 (00) CMT 13:27:11 : Mode Id : 00 13:27:11 : 6 ROOT_KEY_HASH 14 13:27:11 : Block Length : 17 (11) 13:27:11 : BB ASIC Index : 0 (00) CMT 13:27:11 : Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 13:27:11 : 7 ROM_ID 15 13:27:11 : Block Length : 9 (09) 13:27:11 : BB ASIC Index : 0 (00) CMT 13:27:11 : CRC 0 : 273F6D55 13:27:11 : CRC 1 : DFAAF68F 13:27:11 : Checksum 14 13:27:11 : BootCodeLen : 61 13:27:11 : SearchForBootstrap_DCT5.. 13:27:12 : Boot File MATCH : RAP3Gv3_2nd.fg 13:27:12 : Boot File - Version : 009.011.001 13:27:12 : Boot File - Revision : 0x0000 13:27:12 : BB5ProtocolType == : Original 13:27:12 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 13:27:12 : MCU_CONFIGURATION_RESPONSE_BB5: 13:27:13 : MessageID : C1 13:27:13 : SubBlocks : 03 13:27:13 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 13:27:13 : Block Length : 0B 13:27:13 : BB ASIC Index : CMT 00 13:27:13 : Device Type : NOR 00 13:27:13 : Device Index : 00 13:27:13 : Manufacturer Code : 0089 -> 13:27:13 : Device ID : 8982 -> Type not in database 13:27:13 : Extended/Fixed ID : 0000 13:27:13 : Revision ID : 8A31 13:27:13 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 13:27:13 : Block Length : 13 13:27:13 : BB ASIC Index : CMT 00 13:27:13 : Device Type : NOR 00 13:27:13 : Device Index : 00 13:27:13 : Device Contents : 00000000000000000000 13:27:13 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 13:27:13 : Block Length : 0B 13:27:13 : BB ASIC Index : CMT 00 13:27:13 : Device Type : MMC 04 13:27:13 : Device Index : 00 13:27:13 : Manufacturer Code : FFFF -> Flash 13:27:13 : Device ID : 0000 -> BAD FLASH TYPE 13:27:13 : Extended/Fixed ID : 0000 13:27:13 : Revision ID : 0000 13:27:13 : Checksum : 51 13:27:13 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 13:27:13 : FLS1SendAlgoCodeEx.. 13:27:13 : SendAlgoCode_DCT5.. 13:27:13 : SearchForAlgorithm_DCT5.. 13:27:13 : Looking for ALL Devices... 13:27:14 : File MATCH : RAP3Gv3_algo.fg 13:27:14 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00) 13:27:14 : TransmissionTypeRequest_DCT5... 13:27:15 : SuggestedType : 01 16BIT 13:27:15 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC 13:27:15 : ReturnedType : 01 16BIT 13:27:15 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 13:27:15 : 13:27:15 : Uploading ALGO File... 13:27:15 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 13:27:15 : No partition info.... 13:27:15 : VPP Enabled by Software 13:27:15 : Using External VPP 13:27:15 : StartErase_DCT5... 13:27:15 : BlockLength : 0x0036 (54) 13:27:15 : ERASE Blocks : 0x0001 (1) 13:27:15 : 0 ERASE_AREA_BB5 0x12 13:27:15 : Block Length : 0x33 (51) 13:27:15 : BB ASIC Index : 0x00 CMT 13:27:15 : Device Type : 0x00 NOR 13:27:15 : Device Index : 0x00 13:27:15 : 0 : 00000000-000006BF 13:27:16 : 1 : 000006C0-0001FFFF 13:27:16 : 2 : 00040000-000BFFFF 13:27:16 : 3 : 000C0000-0013FFFF 13:27:16 : 4 : 00140000-0137FFFF 13:27:16 : 5 : 01380000-0151FFFF 13:27:16 : ERASE_REQUEST_BB5 : 5001123300000000000000000006BF000006C00001FFFF00040000000BFFFF000C00000013FFFF001400000137FFFF013800000151FFFF32 13:27:16 : Please wait ERASING......... 13:28:43 : Status_BB5 STATUS_REQUEST_BB5.. 13:28:43 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 13:28:43 : Block Length : 01 13:28:43 : BB ASIC Index : 00 13:28:43 : Successfully erased.. 13:28:43 : Time Taken to Erase : 00:01:27 13:28:43 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 13:28:43 : ReturnedType : 04 DDRand2TX 13:28:44 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 13:28:44 : 13:28:44 : Is Flashing CLOCK AUTO : -1 13:28:44 : Processing : rm561__07.81.mcusw 13:28:44 : Total blocks to write : 1256 13:28:44 : >> CMT Rootkey Hash CERT : NOLO 13:28:44 : >> CMT Rootkey Hash CERT : KEYS 13:28:45 : >> CMT Rootkey Hash CERT : PRIMAPP 13:28:45 : >> CMT Rootkey Hash CERT : PASUBTOC 13:28:45 : >> CMT Rootkey Hash CERT : PAPUBKEYS 13:28:45 : >> CMT Rootkey Hash CERT : UPDAPP 13:28:46 : >> CMT Rootkey Hash CERT : DSP0 13:28:50 : >> CMT Rootkey Hash CERT : MCUSW 13:29:39 : ContinueFlash_DCT5 Complete 13:29:39 : Status_BB5 STATUS_REQUEST_BB5.. 13:29:39 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 13:29:39 : Block Length : 01 13:29:39 : BB ASIC Index : 00 13:29:39 : FlashInfo.RestartMode : 1 13:29:39 : Continue Flash Complete : : No Error - 0 (0x00) 13:29:39 : Time Taken to Flash : 00:00:55 13:29:39 : Making delay between files for 1000ms 13:29:40 : Processing Image File : F:\Products\rm-561l\rm561__07.81.ppm_ea 13:29:41 : CMT Type : BB5 13:29:41 : CMT Algorithm : BB5 ALGORITHM 13:29:41 : CMT Supported Hardwares : 13:29:41 : > 010C192101013000 13:29:41 : > 0103192101003000 13:29:41 : > 030C192101033000 13:29:41 : Secondary Sending Speed : 3250000Hz 13:29:41 : Algorithm Sending Speed : 6500000Hz 13:29:41 : Program Sending Speed : 6500000Hz 13:29:41 : Message Reading Speed : 98000Hz 13:29:41 : Number of Blocks : 367 13:29:41 : Entry Point: 0x00B6 13:29:41 : Page Format : -1 13:29:41 : MAX PAGE : 0x00004000 13:29:41 : AdvanceFBox SendBootCodeEx 13:29:41 : InitialiseBootstrap_DCT5 DIR 13:29:41 : BootFlashMode_DCT5 13:29:41 : BootFlashModeDCT5Ex Succeeded First Time 13:29:41 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 4679992 (0x38) bytes returned 13:29:41 : Number of Sub Blocks 7 (0x07) 13:29:41 : 1 SYSTEM_ASIC_ID 01 13:29:41 : Block Length : 21 (15) 13:29:41 : BB ASIC Index : 0 (00) CMT 13:29:41 : ID DWORD 0 : 00000001 13:29:41 : ID DWORD 1 : 00000226 13:29:41 : ID DWORD 2 : 00010006 13:29:41 : ID DWORD 3 : 030C1921 13:29:41 : ID DWORD 4 : 01033000 13:29:41 : 2 ROM_ID 15 13:29:41 : Block Length : 5 (05) 13:29:41 : BB ASIC Index : 0 (00) CMT 13:29:41 : ID DWORD 0 : 00000296 13:29:41 : 3 ROM_ID 15 13:29:41 : Block Length : 5 (05) 13:29:41 : BB ASIC Index : 0 (00) CMT 13:29:41 : ID DWORD 0 : 00000B22 13:29:41 : 4 PUBLIC_ID 12 13:29:41 : Block Length : 21 (15) 13:29:41 : BB ASIC Index : 0 (00) CMT 13:29:41 : ID DWORD 0 : 2160010A 13:29:42 : ID DWORD 1 : D0EC8956 13:29:42 : ID DWORD 2 : 0B4986C3 13:29:42 : ID DWORD 3 : C0A07CC8 13:29:42 : ID DWORD 4 : D57CB523 13:29:42 : 5 ASIC_MODE_ID 13 13:29:42 : Block Length : 2 (02) 13:29:42 : BB ASIC Index : 0 (00) CMT 13:29:42 : Mode Id : 00 13:29:42 : 6 ROOT_KEY_HASH 14 13:29:42 : Block Length : 17 (11) 13:29:42 : BB ASIC Index : 0 (00) CMT 13:29:42 : Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 13:29:42 : 7 ROM_ID 15 13:29:42 : Block Length : 9 (09) 13:29:42 : BB ASIC Index : 0 (00) CMT 13:29:42 : CRC 0 : 273F6D55 13:29:42 : CRC 1 : DFAAF68F 13:29:42 : Checksum 14 13:29:42 : BootCodeLen : 61 13:29:42 : SearchForBootstrap_DCT5.. 13:29:43 : Boot File MATCH : RAP3Gv3_2nd.fg 13:29:43 : Boot File - Version : 009.011.001 13:29:43 : Boot File - Revision : 0x0000 13:29:43 : BB5ProtocolType == : Original 13:29:43 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 13:29:43 : MCU_CONFIGURATION_RESPONSE_BB5: 13:29:43 : MessageID : C1 13:29:43 : SubBlocks : 03 13:29:43 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 13:29:43 : Block Length : 0B 13:29:43 : BB ASIC Index : CMT 00 13:29:43 : Device Type : NOR 00 13:29:43 : Device Index : 00 13:29:43 : Manufacturer Code : 0089 -> 13:29:43 : Device ID : 8982 -> Type not in database 13:29:43 : Extended/Fixed ID : 0000 13:29:43 : Revision ID : 8A31 13:29:43 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 13:29:43 : Block Length : 13 13:29:43 : BB ASIC Index : CMT 00 13:29:43 : Device Type : NOR 00 13:29:43 : Device Index : 00 13:29:43 : Device Contents : 00000000000000000000 13:29:43 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 13:29:43 : Block Length : 0B 13:29:43 : BB ASIC Index : CMT 00 13:29:44 : Device Type : MMC 04 13:29:44 : Device Index : 00 13:29:44 : Manufacturer Code : FFFF -> Flash 13:29:44 : Device ID : 0000 -> BAD FLASH TYPE 13:29:44 : Extended/Fixed ID : 0000 13:29:44 : Revision ID : 0000 13:29:44 : Checksum : 51 13:29:44 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 13:29:44 : FLS1SendAlgoCodeEx.. 13:29:44 : SendAlgoCode_DCT5.. 13:29:44 : SearchForAlgorithm_DCT5.. 13:29:44 : Looking for ALL Devices... 13:29:45 : File MATCH : RAP3Gv3_algo.fg 13:29:45 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00) 13:29:45 : TransmissionTypeRequest_DCT5... 13:29:45 : SuggestedType : 01 16BIT 13:29:45 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC 13:29:45 : ReturnedType : 01 16BIT 13:29:45 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 13:29:45 : 13:29:45 : Uploading ALGO File... 13:29:46 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 13:29:46 : No partition info.... 13:29:46 : VPP Enabled by Software 13:29:46 : Using External VPP 13:29:46 : StartErase_DCT5... 13:29:46 : BlockLength : 0x000E (14) 13:29:46 : ERASE Blocks : 0x0001 (1) 13:29:46 : 0 ERASE_AREA_BB5 0x12 13:29:46 : Block Length : 0x0B (11) 13:29:46 : BB ASIC Index : 0x00 CMT 13:29:46 : Device Type : 0x00 NOR 13:29:46 : Device Index : 0x00 13:29:46 : 0 : 01520000-01DBFFFF 13:29:46 : ERASE_REQUEST_BB5 : 5001120B0000000152000001DBFFFFB4 13:29:46 : Please wait ERASING......... 13:30:18 : Status_BB5 STATUS_REQUEST_BB5.. 13:30:19 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 13:30:19 : Block Length : 01 13:30:19 : BB ASIC Index : 00 13:30:19 : Successfully erased.. 13:30:19 : Time Taken to Erase : 00:00:33 13:30:19 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 13:30:20 : ReturnedType : 04 DDRand2TX 13:30:20 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 13:30:20 : 13:30:20 : Is Flashing CLOCK AUTO : -1 13:30:20 : Processing : rm561__07.81.ppm_ea 13:30:20 : Total blocks to write : 367 13:30:36 : ContinueFlash_DCT5 Complete 13:30:36 : Status_BB5 STATUS_REQUEST_BB5.. 13:30:36 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 13:30:36 : Block Length : 01 13:30:36 : BB ASIC Index : 00 13:30:36 : FlashInfo.RestartMode : 2 13:30:37 : Continue Flash Complete : : No Error - 0 (0x00) 13:30:37 : Time Taken to Flash : 00:00:16 13:30:37 : Making delay between files for 1000ms 13:30:38 : Processing Image File : F:\Products\rm-561l\rm561__07.81.image_ea_blac 13:30:38 : CMT Type : BB5 13:30:38 : CMT Algorithm : BB5 ALGORITHM 13:30:38 : CMT Supported Hardwares : 13:30:38 : > 010C192101013000 13:30:38 : > 0103192101003000 13:30:38 : > 030C192101033000 13:30:38 : Secondary Sending Speed : 3250000Hz 13:30:38 : Algorithm Sending Speed : 6500000Hz 13:30:38 : Program Sending Speed : 6500000Hz 13:30:39 : Message Reading Speed : 98000Hz 13:30:39 : Number of Blocks : 536 13:30:39 : Entry Point: 0x00C2 13:30:39 : Page Format : -1 13:30:39 : MAX PAGE : 0x00004000 13:30:39 : AdvanceFBox SendBootCodeEx 13:30:39 : InitialiseBootstrap_DCT5 DIR 13:30:39 : BootFlashMode_DCT5 13:30:39 : BootFlashModeDCT5Ex Succeeded First Time 13:30:39 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 4679992 (0x38) bytes returned 13:30:39 : Number of Sub Blocks 7 (0x07) 13:30:39 : 1 SYSTEM_ASIC_ID 01 13:30:39 : Block Length : 21 (15) 13:30:39 : BB ASIC Index : 0 (00) CMT 13:30:39 : ID DWORD 0 : 00000001 13:30:39 : ID DWORD 1 : 00000226 13:30:39 : ID DWORD 2 : 00010006 13:30:39 : ID DWORD 3 : 030C1921 13:30:39 : ID DWORD 4 : 01033000 13:30:39 : 2 ROM_ID 15 13:30:39 : Block Length : 5 (05) 13:30:39 : BB ASIC Index : 0 (00) CMT 13:30:39 : ID DWORD 0 : 00000296 13:30:39 : 3 ROM_ID 15 13:30:39 : Block Length : 5 (05) 13:30:39 : BB ASIC Index : 0 (00) CMT 13:30:39 : ID DWORD 0 : 00000B22 13:30:39 : 4 PUBLIC_ID 12 13:30:39 : Block Length : 21 (15) 13:30:39 : BB ASIC Index : 0 (00) CMT 13:30:39 : ID DWORD 0 : 2160010A 13:30:39 : ID DWORD 1 : D0EC8956 13:30:39 : ID DWORD 2 : 0B4986C3 13:30:39 : ID DWORD 3 : C0A07CC8 13:30:39 : ID DWORD 4 : D57CB523 13:30:39 : 5 ASIC_MODE_ID 13 13:30:39 : Block Length : 2 (02) 13:30:39 : BB ASIC Index : 0 (00) CMT 13:30:39 : Mode Id : 00 13:30:39 : 6 ROOT_KEY_HASH 14 13:30:39 : Block Length : 17 (11) 13:30:39 : BB ASIC Index : 0 (00) CMT 13:30:39 : Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 13:30:39 : 7 ROM_ID 15 13:30:39 : Block Length : 9 (09) 13:30:39 : BB ASIC Index : 0 (00) CMT 13:30:39 : CRC 0 : 273F6D55 13:30:39 : CRC 1 : DFAAF68F 13:30:39 : Checksum 14 13:30:39 : BootCodeLen : 61 13:30:39 : SearchForBootstrap_DCT5.. 13:30:40 : Boot File MATCH : RAP3Gv3_2nd.fg 13:30:40 : Boot File - Version : 009.011.001 13:30:40 : Boot File - Revision : 0x0000 13:30:40 : BB5ProtocolType == : Original 13:30:41 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 13:30:41 : MCU_CONFIGURATION_RESPONSE_BB5: 13:30:41 : MessageID : C1 13:30:41 : SubBlocks : 03 13:30:41 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 13:30:41 : Block Length : 0B 13:30:41 : BB ASIC Index : CMT 00 13:30:41 : Device Type : NOR 00 13:30:41 : Device Index : 00 13:30:41 : Manufacturer Code : 0089 -> 13:30:41 : Device ID : 8982 -> Type not in database 13:30:41 : Extended/Fixed ID : 0000 13:30:41 : Revision ID : 8A31 13:30:41 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 13:30:41 : Block Length : 13 13:30:41 : BB ASIC Index : CMT 00 13:30:41 : Device Type : NOR 00 13:30:41 : Device Index : 00 13:30:41 : Device Contents : 00000000000000000000 13:30:41 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 13:30:41 : Block Length : 0B 13:30:41 : BB ASIC Index : CMT 00 13:30:41 : Device Type : MMC 04 13:30:41 : Device Index : 00 13:30:41 : Manufacturer Code : FFFF -> Flash 13:30:41 : Device ID : 0000 -> BAD FLASH TYPE 13:30:41 : Extended/Fixed ID : 0000 13:30:41 : Revision ID : 0000 13:30:41 : Checksum : 51 13:30:41 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 13:30:41 : FLS1SendAlgoCodeEx.. 13:30:41 : SendAlgoCode_DCT5.. 13:30:41 : SearchForAlgorithm_DCT5.. 13:30:41 : Looking for ALL Devices... 13:30:43 : File MATCH : RAP3Gv3_algo.fg 13:30:43 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00) 13:30:43 : TransmissionTypeRequest_DCT5... 13:30:43 : SuggestedType : 01 16BIT 13:30:43 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC 13:30:43 : ReturnedType : 01 16BIT 13:30:43 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 13:30:43 : 13:30:43 : Uploading ALGO File... 13:30:43 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 13:30:43 : No partition info.... 13:30:43 : VPP Enabled by Software 13:30:43 : Using External VPP 13:30:43 : StartErase_DCT5... 13:30:44 : BlockLength : 0x0016 (22) 13:30:44 : ERASE Blocks : 0x0001 (1) 13:30:44 : 0 ERASE_AREA_BB5 0x12 13:30:44 : Block Length : 0x13 (19) 13:30:44 : BB ASIC Index : 0x00 CMT 13:30:44 : Device Type : 0x00 NOR 13:30:44 : Device Index : 0x00 13:30:44 : 0 : 01DC0000-0215FFFF 13:30:44 : 1 : 02160000-03FBFFFF 13:30:44 : ERASE_REQUEST_BB5 : 5001121300000001DC00000215FFFF0216000003FBFFFFD3 13:30:44 : Please wait ERASING......... 13:33:43 : Status_BB5 STATUS_REQUEST_BB5.. 13:33:43 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 13:33:43 : Block Length : 01 13:33:43 : BB ASIC Index : 00 13:33:43 : Successfully erased.. 13:33:44 : Time Taken to Erase : 00:03:00 13:33:44 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 13:33:44 : ReturnedType : 04 DDRand2TX 13:33:44 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 13:33:44 : 13:33:44 : Is Flashing CLOCK AUTO : -1 13:33:44 : Processing : rm561__07.81.image_ea_blac 13:33:44 : Total blocks to write : 536 13:34:08 : ContinueFlash_DCT5 Complete 13:34:08 : Status_BB5 STATUS_REQUEST_BB5.. 13:34:08 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 13:34:08 : Block Length : 01 13:34:08 : BB ASIC Index : 00 13:34:08 : FlashInfo.RestartMode : 2 13:34:08 : Continue Flash Complete : : No Error - 0 (0x00) 13:34:08 : Time Taken to Flash : 00:00:23 13:34:08 : Making delay between files for 1000ms 13:34:09 : 13:34:09 : Total Flashing Time: 00:01:36 13:34:09 : (Excluding ERASE Times) 13:34:09 : 13:34:09 : Rebooting Box ... 13:34:09 : AdvanceBox Turbo Flasher Found 13:34:09 : Initialize Device.... 13:34:10 : Init TRY : 1 13:34:10 : Changing Clock to 15mhz.. 13:34:11 : Box Name : AdvanceBox Turbo 13:34:11 : Box Firmware : LogiCore 1.16.10 13:34:11 : Software Version : v2010.0.1.21 13:34:11 : AdvanceBox SN : 850C6E369E48098ABB7F4E12 13:34:11 : BOX Status : ACTIVATED 13:34:11 : DDR DELAY : 01 13:34:11 : INIT : OK 13:34:11 : 13:34:11 : VBATT OFF ... 13:34:14 : VBATT ON 13:34:14 : Setting VBATT Done!... 13:34:14 : Waiting for phone to Power On, 8000 ms delay 13:34:26 : Changing MODE : UART 13:34:26 : Reading Phone Information... 13:34:27 : MCU: V 07.81 26-08-09 RM-561 (c) Nokia 13:34:27 : IMEI: 35419203119xxx |
Compare Speed Flashing ATF with Other Nokia Box.. | bestncheap | Advance-Box | 23 | 03-03-2010 08:17 |
Any One Test Flashing Kg225 With Kg220 Flashes ?? | tsarkh | Infinity-Box | 2 | 05-15-2008 16:06 |
Factory Test Flashes | corachon | BF, BG, TH, BHx Series | 8 | 10-23-2003 12:03 |
V3690 dead, urgently need tested flash | asas | Motorola Old Legacy (EMMI) | 1 | 01-28-2003 21:27 |
