10-03-2016, 00:13 | #4 (permalink) | |
Freak Poster Join Date: Aug 2015
Member: 2438620 Status: Offline Thanks Meter: 156 | Look here Quote:
The Following User Says Thank You to brianhamp For This Useful Post: |
10-03-2016, 09:20 | #7 (permalink) |
Freak Poster Join Date: May 2010 Location: Egypt Age: 33
Member: 1298419 Status: Offline Sonork: 100.1672105 Thanks Meter: 69 | If ATF D.R.I.V.E. does not work for your device , you can read full dumb of Userdata partition and use any Forensic tool to extract your data. |
10-03-2016, 14:54 | #8 (permalink) |
Freak Poster Join Date: Mar 2014 Location: morocco
Member: 2149341 Status: Offline Thanks Meter: 31 | when its mounted its said format the drive any solution ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 150100414645414242005C1860FE3067 CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3072 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : AFEABB Product Rev : 0.0 Product SN : 5C1860FE Manufactured : March 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 150100414645414242005C1860FE3067.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Dumping Custom Region Please wait for some time... Partition Selected: USER AREA (eMMC Clock 7500000 Hz) Custom Block Read OK File Saved: C:\AdvanceBox Turbo Flasher\eMMC\Recovered\eMMC_GPT.bin Total Elapsed Time 00:00:00 EFI Partition Table Header Signature: EFI PART Revision: 0x00000100 Header Size: 0x0000005C Header CRC32: 0x889C561A Reserved: 0x00000000 Current EFI Partition Header LBA: 0x0000000000000001 Backup EFI Partition Header LBA: 0x0000000001D59FFF First Usable LBA: 0x0000000000000022 Last Usable LBA: 0x0000000001D59FDE Disk GUID: 0x200C003DB32B6EA04BF2BBE298101B32 LBA of EFI Partition Entries: 0x0000000000000002 Number of Partition Entries: 128 Size of each Parition Entry: 128 Partition Entries CRC32: 0x1AAD70EB Partition Name: apnhlos Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 01000000000000000000000000000000 Starting LBA: 0000000000002000 Ending LBA: 00000000000083C7 Partition Attributes: 0000000000000000 Partition Name: mdm Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 02000000000000000000000000000000 Starting LBA: 00000000000083C8 Ending LBA: 0000000000021FFF Partition Attributes: 0000000000000000 Partition Name: sbl1 Partition Type GUID: 2CBAA0DEDDCB0548B4F9F428251C3E98 Unique Partition GUID: 03000000000000000000000000000000 Starting LBA: 0000000000022000 Ending LBA: 00000000000220FF Partition Attributes: 0000000000000000 Partition Name: sbl2 Partition Type GUID: AD526B8C9E8A9843AD09AE916E53AE2D Unique Partition GUID: 04000000000000000000000000000000 Starting LBA: 0000000000022100 Ending LBA: 00000000000222FF Partition Attributes: 0000000000000000 Partition Name: sbl3 Partition Type GUID: DF44E005F1922543B69E374A82E97D6E Unique Partition GUID: 05000000000000000000000000000000 Starting LBA: 0000000000022300 Ending LBA: 00000000000226FF Partition Attributes: 0000000000000000 Partition Name: aboot Partition Type GUID: CDFD0F40E022E7479A23F16ED9382388 Unique Partition GUID: 06000000000000000000000000000000 Starting LBA: 0000000000022700 Ending LBA: 00000000000236FF Partition Attributes: 0000000000000000 Partition Name: rpm Partition Type GUID: 93F78D0912D73D419D4E89D711772228 Unique Partition GUID: 07000000000000000000000000000000 Starting LBA: 0000000000023700 Ending LBA: 0000000000023AFF Partition Attributes: 0000000000000000 Partition Name: tz Partition Type GUID: 7FAA53A0B8401C4BBA082F68AC71A4F4 Unique Partition GUID: 08000000000000000000000000000000 Starting LBA: 0000000000023B00 Ending LBA: 0000000000023EFF Partition Attributes: 0000000000000000 Partition Name: pad Partition Type GUID: 38684A002A06DF4481524F340C05225D Unique Partition GUID: 09000000000000000000000000000000 Starting LBA: 0000000000023F00 Ending LBA: 000000000002C2FF Partition Attributes: 0000000000000000 Partition Name: efs Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 0A000000000000000000000000000000 Starting LBA: 000000000002C300 Ending LBA: 0000000000032FFF Partition Attributes: 0000000000000000 Partition Name: modemst1 Partition Type GUID: AFADBEEBC9223BE38F5D0E81686A68CB Unique Partition GUID: 0B000000000000000000000000000000 Starting LBA: 0000000000033000 Ending LBA: 00000000000347FF Partition Attributes: 0000000000000000 Partition Name: modemst2 Partition Type GUID: 1F8B280AC9223BE38F5D0E81686A68CB Unique Partition GUID: 0C000000000000000000000000000000 Starting LBA: 0000000000034800 Ending LBA: 0000000000035FFF Partition Attributes: 0000000000000000 Partition Name: m9kefs1 Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 0D000000000000000000000000000000 Starting LBA: 0000000000036000 Ending LBA: 0000000000036617 Partition Attributes: 0000000000000000 Partition Name: m9kefs2 Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 0E000000000000000000000000000000 Starting LBA: 0000000000036618 Ending LBA: 0000000000036C2F Partition Attributes: 0000000000000000 Partition Name: m9kefs3 Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 0F000000000000000000000000000000 Starting LBA: 0000000000036C30 Ending LBA: 0000000000037247 Partition Attributes: 0000000000000000 Partition Name: system Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 10000000000000000000000000000000 Starting LBA: 0000000000037248 Ending LBA: 000000000059B247 Partition Attributes: 0000000000000000 Partition Name: persist Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 11000000000000000000000000000000 Starting LBA: 000000000059B248 Ending LBA: 000000000059F247 Partition Attributes: 0000000000000000 Partition Name: cache Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 12000000000000000000000000000000 Starting LBA: 000000000059F248 Ending LBA: 00000000009AA247 Partition Attributes: 0000000000000000 Partition Name: param Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 13000000000000000000000000000000 Starting LBA: 00000000009AA248 Ending LBA: 00000000009AD247 Partition Attributes: 0000000000000000 Partition Name: boot Partition Type GUID: 867F112085E95743B9EE374BC1D8487D Unique Partition GUID: 14000000000000000000000000000000 Starting LBA: 00000000009AD248 Ending LBA: 00000000009B2247 Partition Attributes: 0000000000000000 Partition Name: recovery Partition Type GUID: 867F112085E95743B9EE374BC1D8487D Unique Partition GUID: 15000000000000000000000000000000 Starting LBA: 00000000009B2248 Ending LBA: 00000000009B7247 Partition Attributes: 0000000000000000 Partition Name: fota Partition Type GUID: 175D8CD89CEDD24BB06D1484E918208B Unique Partition GUID: 16000000000000000000000000000000 Starting LBA: 00000000009B7248 Ending LBA: 00000000009BC247 Partition Attributes: 0000000000000000 Partition Name: backup Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 17000000000000000000000000000000 Starting LBA: 00000000009BC248 Ending LBA: 00000000009BF247 Partition Attributes: 0000000000000000 Partition Name: fsg Partition Type GUID: E2F88F63C9223BE38F5D0E81686A68CB Unique Partition GUID: 18000000000000000000000000000000 Starting LBA: 00000000009BF248 Ending LBA: 00000000009C0A47 Partition Attributes: 0000000000000000 Partition Name: ssd Partition Type GUID: 42E7862C5E74DD4FBFD8B6A7AC638772 Unique Partition GUID: 19000000000000000000000000000000 Starting LBA: 00000000009C0A48 Ending LBA: 00000000009C0A57 Partition Attributes: 0000000000000000 Partition Name: persdata Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 1A000000000000000000000000000000 Starting LBA: 00000000009C0A58 Ending LBA: 00000000009C5257 Partition Attributes: 0000000000000000 Partition Name: hidden Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 1B000000000000000000000000000000 Starting LBA: 00000000009C5258 Ending LBA: 0000000000ABF257 Partition Attributes: 0000000000000000 Partition Name: carrier Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 1C000000000000000000000000000000 Starting LBA: 0000000000ABF258 Ending LBA: 0000000000AC9257 Partition Attributes: 0000000000000000 Partition Name: userdata Partition Type GUID: AF3DC60F838472478E793D69D8477DE4 Unique Partition GUID: 1D000000000000000000000000000000 Starting LBA: 0000000000AC9258 Ending LBA: 0000000001D57257 Partition Attributes: 0000000000000000 Partition Selected: userdata Total Blocks: 0x000000000128E000 First LBA: 0x0000000000AC9258 Last LBA: 0x0000000001D57257 |
10-03-2016, 14:58 | #9 (permalink) |
Member: 2149341 Status: Offline Thanks Meter: 31 | ATF eMMC to Virtual Hard Disk 1.0 ============================================ eMMC Partition Mounted as Drive: F [READ ONLY] [READ OPERATION] Block Address: 0x0000000000000000 Chunk Size : 0x0000000000000200 |
