07-21-2014, 03:14 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: ecuador
Member: 2078045 Status: Offline Thanks Meter: 151 | TRUE SOLUTION CHERRY skyfire 2 MOBILE Phone Type : Cherry Mobile Skyfire 2.0 CPU Type : Qualcomm MSM8225Q Storage TYpe : eMMC 4GB Boot Package : Full Factory Restore Android Version: 4.1.2 (Jelly Bean) Kernel Version : 3.4.0 Build Number : TBW593316_8765_V006075 www.advance-box.com Default language ID 0x240A JTAG Interface Connected, S/N xxxxxxxxx Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 26/11/2013 11:10:00 a.m. ================================================== ======== Phone Type : Cherry Mobile Skyfire 2.0 CPU Type : Qualcomm MSM8225Q Storage TYpe : eMMC 4GB Boot Package : Full Factory Restore Android Version: 4.1.2 (Jelly Bean) Kernel Version : 3.4.0 Build Number : TBW593316_8765_V006075 ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs 8. Full Factory Restore takes 40 minutes to Finish ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...Hynix XINYH, 3.61 GiB Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91460 Op/Sec) Restoring Partition #1... Saving "..\Logs\Screenshots\2014-07-20_20-01-54.jpg"...OKOK Restoring Partition #2...OK Restoring Partition #3...OK Completed in 0h 52m 16s. Code Download Speed 217 KiB/sec. Full Factory Restore Done! Warning: IMEI1 and IMEI2 has been Changed! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Enter Recovery: Press Volume Up + Power Buttons until LCD Becomes RED 3. Select "wipe data/factory reset" 4. Select "Yes -- delete all user data" 5. Select "reboot system now" 6. Wait for 3-5 minutes while Phone is Performing Initial Boot Sequence 7. After Phone starts up, you may need to format Internal SD Card 8. Restore Original IMEI1 and IMEI2 by following intructions here: ================================================== ========================== |
