03-29-2011, 08:59 | #10 (permalink) |
No Life Poster Join Date: Feb 2009 Location: uk
Member: 973412 Status: Offline Thanks Meter: 117 | 12:02:51 : AdvanceBox Turbo Flasher Found 12:02:51 : Driver Version : 00020422 12:02:51 : Library Version : 00030119 12:02:51 : Initialize Device.... 12:02:52 : Init TRY : 1 12:02:53 : Box Name : AdvanceBox Turbo 12:02:53 : Box Firmware : LogiCore 9.02.10 12:02:53 : Software Version : v7.24 12:02:53 : AdvanceBox SN : E59FEA39D4440070A01EF6D2 12:02:53 : BOX Status : ACTIVATED 12:02:53 : INIT : OK 12:02:53 : 12:02:53 : VBATT OFF... 12:02:57 : VBATT ON 12:02:57 : Setting VBATT Done!... 12:02:57 : 12:02:57 : 12:02:57 : ///////// /// /// /////// /////// ///////// 12:02:57 : /// /// /// /// // /// /// /// /// 12:02:57 : /// /// /// /////// /////// /// /// 12:02:57 : /// /// /// /// /// /// /// /// /// 12:02:57 : /// ///// /// /// /////// ////// 12:02:57 : 12:02:57 : ======================================= 12:02:57 : /// /// /// ///////// /////// ////// 12:02:57 : ///// /// /// /// /// // /// /// 12:02:57 : /// ///// /// /// /////// /// /// 12:02:57 : /// //// /// /// /// /// /// /// 12:02:57 : /// /// /// /// /// /// ////// 12:02:57 : ======================================= 12:02:57 : 12:03:01 : 12:03:01 : Make sure that you plugged the cable to the 12:03:01 : RJ-45 Port Marked << EXTENSION >> 12:03:01 : 12:03:01 : ======================================= || FLASHBUS EXTENSION || || ======= ======= || || | | |\ /| || || | | (O) (O) (O) | CABLE | || || | | |/ \| || || ======= ======= || || || ======================================= ^ ^ ^ | | | | | | PLUG IN CABLE HERE 12:03:03 : 12:03:03 : Booting Phone... 12:03:05 : CPU ID Response: A200341100 12:03:05 : CPU Type: XG110 2.1B 12:03:05 : Phone Booted at after First attempt... 12:03:05 : 12:03:05 : ************************************************** **** 12:03:05 : START INFINEON BUS CHECK 12:03:05 : ************************************************** **** 12:03:05 : 12:03:05 : 12:03:05 : Sending PBL 37888 bytes... 12:03:07 : PBL Successfully Sent... 12:03:07 : Sending SBL 65024 bytes... 12:03:08 : SBL Successfully Sent... 12:03:08 : 12:03:08 : Flash Chip Manufacturer: Samsung Electronics Corp. 12:03:08 : Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR 12:03:08 : Extended Information: Multiple Bank / Burst / 1.8v 12:03:08 : 12:03:08 : ************************************************** **** 12:03:08 : INFINEON BUS CHECK DONE 12:03:08 : ************************************************** **** 12:03:08 : 12:03:09 : 12:03:10 : MCU: V 02.51 29-07-10 RM-689 (c) Nokia 12:03:10 : IMEI: 353794043932038 12:03:10 : Mastercode : 3440450156 12:03:10 : Product Serial Number: DRY995516 12:03:10 : Product Code : 059B341 12:03:10 : Module Code : 0204671 12:03:10 : Basic Production Code: 0597858 12:03:10 : MCU SW Version : V 02.51 29-07-10 RM-689 (c) Nokia IJ 12:03:10 : ADSP Version : p V 02.51\n29-07-10\nRM-689\n(c) NMP\nij 12:03:11 : PPM Version : V 02.51 29-07-10 RM-689 (c) Nokia 12:03:11 : HW Version : 1000 12:03:11 : UEM Version : 1328 12:03:11 : UPP Version : 8850 12:03:11 : LCD Version : UNKWN: IDs: 00:00:00 12:03:12 : ********** SIMLOCK INFO ********** 12:03:12 : CONFIG_DATA : 0010100000000000 12:03:12 : PROFILE_BITS : 0000000000030002 12:03:12 : Asic : 11 12:03:12 : Provider : Default Test Operator 12:03:12 : 12:03:13 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 12:03:13 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 12:03:13 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 12:03:13 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 12:03:13 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 12:03:13 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 12:03:13 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open |
03-29-2011, 09:53 | #14 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @azhergoga007 1. Check your cable, is it working one? 2. Restore box from product support page 3. Be sure, You have pluged cable into 'EXTENSION' port NOT in 'FLASHBUS' BR |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
