02-27-2015, 07:29 | #1 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Gampaha, Srilanka
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | Unable to find bootloader option Lumia 520... - SOLUTION INSIDE FOR SAMSUNG EMMC ONLY I try to flash it with ATF and here is the log: Quote:
02-27-2015, 13:48 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Ransiri You can repair this via ATF 12.00 (Which you can get from AUTO-UPDATE Server or downloader full installer here: ATF_v12.00_Full_Installer.rar As of now, only SAMSUNG EMMC CHIP is supported. So Check your Phone if inside is a Samsung eMMC Chip. The EMMC Chip is the one with the YELLOW BOX in the TP Pictures. If your eMMC is SK Hynix, then there is nothing we can do for now. To Repair: You need to open phone and Connect 4 wires to eMMC Connection. Pinout is here: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\TP_PIX\520_TP_HIRES.jpg Then After you solder the Wires correctly, do this: After you do this, check if phone still need to be flashed via USB... Otherwise, WP BIT IS ALREADY REMOVED. B.R. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
03-10-2015, 16:29 | #3 (permalink) |
Freak Poster Join Date: May 2007 Age: 25
Member: 503942 Status: Offline Thanks Meter: 61 | Yep. Works like a charm. Before removing Write Protection : 15:09:47 : ================================================ 15:09:47 : Advance Turbo Flasher Found 15:09:47 : ================================================ 15:09:47 : Driver Version : 00020830 15:09:47 : Library Version : 00030207 15:09:49 : Box Type : AdvanceBox Turbo 15:09:49 : Box Firmware : LogiCore 11.0.10 15:09:49 : Software Version : v12.05 15:09:49 : AdvanceBox SN : FEF4D0B7E1E22C5AA6590D9F 15:09:49 : Box Status : ACTIVATED 15:09:49 : ================================================ 15:09:49 : Box Successfully Initialized 15:09:49 : ================================================ 15:09:49 : 15:09:49 : VBATT Powering Down <<<< 15:09:54 : VBATT Powering Up >>>> 15:09:54 : SET VCCIO Level Done 15:09:54 : SET BSI Load Done 15:09:54 : 15:09:54 : 15:09:54 : 15:09:54 : ///////// /// /// /////// /////// ///////// 15:09:54 : /// /// /// /// // /// /// /// /// 15:09:54 : /// /// /// /////// /////// /// /// 15:09:54 : /// /// /// /// /// /// /// /// /// 15:09:54 : /// ///// /// /// /////// ////// 15:09:54 : 15:09:54 : ======================================= 15:09:54 : /// /// /// ///////// /////// ////// 15:09:54 : ///// /// /// /// /// // /// /// 15:09:54 : /// ///// /// /// /////// /// /// 15:09:54 : /// //// /// /// /// /// /// /// 15:09:54 : /// /// /// /// /// /// ////// 15:09:54 : ======================================= 15:09:54 : 15:09:59 : 15:09:59 : ================================================== ==== 15:09:59 : Selected VPL File: 15:09:59 : RM914_059S359_3058.50000.1425.0008_058.vpl 15:09:59 : ================================================== ==== 15:09:59 : Variant Details : RM-914 VAR PL PTK CENTERTEL 15:09:59 : Software Version : 3058.50000.1425.0008 15:10:00 : Product Type : RM-914 15:10:00 : Product Code : 059S359 15:10:00 : Variant Version : 058 15:10:00 : 15:10:08 : 15:10:08 : ================================================== ==== 15:10:08 : Flash File Checksum Verification 15:10:08 : ================================================== ==== 15:10:23 : RM914_3058.50000.1425.0008_RETAIL_eu_poland_302_08 _443021_prd_signed.ffu: CHECKSUM PASSED 15:10:23 : ================================================== ==== 15:10:23 : Verification Done... 15:10:25 : Windows Phone 8/8.1 Flashing Started 15:10:25 : Loading Flash Files Please Wait... 15:10:25 : [DEAD BOOT REPAIR SUPPORTED] 15:10:26 : 15:10:26 : ================================================== ==== 15:10:26 : Windows Phone 8/8.1 Lumia Flasher 15:10:26 : ================================================== ==== 15:10:26 : 15:10:26 : If the Phone is ALIVE 15:10:26 : 1. Power On the Phone and Connect it to the USB Port 15:10:26 : 15:10:26 : If the Phone is DEAD 15:10:26 : 1. Connect Phone to the USB Port 15:10:26 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 15:10:26 : 3. Wait until the Phone Vibrates Shortly... 15:10:26 : 4. Stop Pressing the Buttons... 15:10:26 : 15:10:26 : If the Phone is DEAD BOOT 15:10:26 : 1. Connect Phone to the USB Port 15:10:26 : 2. Install Correct Drivers: 15:10:26 : "Nokia Emergency Connectivity" 15:10:26 : ================================================== ==== 15:10:26 : 15:11:18 : Nokia Phone Info Mode Initiated... 15:11:18 : Please wait upto 15 Seconds for SW Reset 15:11:18 : IMEI: 359205059067464 15:11:18 : Version: 1.1.1.3 15:11:18 : Product Code: 059S591 15:11:18 : Module Code: 0205435 15:11:19 : 15:11:19 : Continuing Previous Boot... 15:11:19 : Please wait upto 30 Seconds for Boot Re-entry 15:11:20 : 15:11:20 : Boot Flash Mode Successful... 15:11:20 : Buffers Flushed OK... 15:11:20 : 15:11:20 : Phone Info Query Start... 15:11:20 : Blocks Returned: 0x07 Blocks 15:11:20 : Block ID 0x01 :00241000 15:11:20 : Block ID 0x02 :00240000 15:11:20 : Block ID 0x03 :00E90000 15:11:20 : Block ID 0x05 :Nokia.MSM8227.P6036.1.2 15:11:20 : Block ID 0x0D :0001 15:11:20 : Block ID 0x0F :0301010100000101FF 15:11:20 : Block ID 0x10 :0100130000 15:11:20 : Checking SD Card Size... 15:11:20 : Card Size: 0x00000000 15:11:20 : Checking Platform Security Status... 15:11:20 : Platform Secure Boot Status: Active 15:11:20 : Secure FFU EFUSE Status: Active 15:11:20 : Debug Status: Active 15:11:20 : RDC Status: Not Active 15:11:20 : Authentication Status: Not Active 15:11:20 : UEFI Secure Boot Status: Active 15:11:20 : Checking Secure FFU Mode... 15:11:20 : Secure FFU Mode : 15:11:20 : Query Flash App Information... 15:11:20 : Flash App Information: 02010F011C00 15:11:20 : UEFI App: FLASH APP 15:11:20 : Flash App Protocol Version: 1.15 15:11:20 : Flash App Implementation Version: 1.28 15:11:20 : Query ROOT KEY HASH... 15:11:20 : ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD 15:11:20 : 15:11:20 : Sending Image Signatures... 15:11:21 : ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) 15:11:21 : This Flash File is NOT COMPATIBLE with this Phone. 15:11:21 : ERROR: Flashing Failed! And after Romoving Write Protection : 16:22:33 : Windows Phone 8/8.1 Lumia Flasher 16:22:33 : ================================================== ==== 16:22:33 : 16:22:33 : If the Phone is ALIVE 16:22:33 : 1. Power On the Phone and Connect it to the USB Port 16:22:33 : 16:22:33 : If the Phone is DEAD 16:22:33 : 1. Connect Phone to the USB Port 16:22:33 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 16:22:33 : 3. Wait until the Phone Vibrates Shortly... 16:22:33 : 4. Stop Pressing the Buttons... 16:22:33 : 16:22:33 : If the Phone is DEAD BOOT 16:22:33 : 1. Connect Phone to the USB Port 16:22:33 : 2. Install Correct Drivers: 16:22:33 : "Nokia Emergency Connectivity" 16:22:33 : ================================================== ==== 16:22:33 : 16:22:54 : Nokia Phone Info Mode Initiated... 16:22:54 : Please wait upto 15 Seconds for SW Reset 16:22:54 : IMEI: 359205059067464 16:22:54 : Version: 1.1.1.3 16:22:54 : Product Code: 059S591 16:22:54 : Module Code: 0205435 16:22:54 : 16:22:54 : Continuing Previous Boot... 16:22:54 : Please wait upto 30 Seconds for Boot Re-entry 16:22:55 : 16:22:55 : Boot Flash Mode Successful... 16:22:56 : Buffers Flushed OK... 16:22:56 : 16:22:56 : Phone Info Query Start... 16:22:56 : Blocks Returned: 0x07 Blocks 16:22:56 : Block ID 0x01 :00241000 16:22:56 : Block ID 0x02 :00240000 16:22:56 : Block ID 0x03 :00E90000 16:22:56 : Block ID 0x05 :Nokia.MSM8227.P6036.1.2 16:22:56 : Block ID 0x0D :0001 16:22:56 : Block ID 0x0F :0301010100000101FF 16:22:56 : Block ID 0x10 :0100130000 16:22:56 : Checking SD Card Size... 16:22:56 : Card Size: 0x00000000 16:22:56 : Checking Platform Security Status... 16:22:56 : Platform Secure Boot Status: Active 16:22:56 : Secure FFU EFUSE Status: Active 16:22:56 : Debug Status: Active 16:22:56 : RDC Status: Not Active 16:22:56 : Authentication Status: Not Active 16:22:56 : UEFI Secure Boot Status: Active 16:22:56 : Checking Secure FFU Mode... 16:22:56 : Secure FFU Mode : 16:22:56 : Query Flash App Information... 16:22:56 : Flash App Information: 02010F011C00 16:22:56 : UEFI App: FLASH APP 16:22:56 : Flash App Protocol Version: 1.15 16:22:56 : Flash App Implementation Version: 1.28 16:22:56 : Query ROOT KEY HASH... 16:22:56 : ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD 16:22:56 : 16:22:56 : Sending Image Signatures... 16:22:59 : Image Signatures Accepted! 16:22:59 : Erasing Data Partition... 16:23:01 : Data Partition Erased Successfully 16:23:01 : Preparing Buffers for DATA LOOP... 16:23:01 : Allocating System RAM OK! 16:23:01 : Start Sending DATA BLOCKS... 16:27:00 : Finished Sending all DATA BLOCKS! 16:27:00 : Exiting FLASH Mode via REBOOT... 16:27:00 : Exit FLASH Mode Successful! 16:27:00 : 16:27:00 : Flashing Done! 16:27:00 : Total Flashing Time : 00:04:04 Big thanks !!! |
03-11-2015, 11:57 | #4 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @suchywilk I hope more users will realize that Solution already exists and is Super Easy to perform. |
The Following 4 Users Say Thank You to Advance-Box For This Useful Post: |
03-16-2015, 15:19 | #5 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Iran Age: 36
Member: 103435 Status: Offline Thanks Meter: 49 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D384732594300F2E54A126017 CSD : D02701320F5903FFF6DBFFEF96404063 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : F2E54A12 Manufactured : June 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D384732594300F2E54A126017.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ ERROR: PERM_WP BIT is NOT SET... You do not have to Perform this Operation... any0ne could solve this problem emmc chip is samsung but cant remove write protection |
03-16-2015, 15:51 | #7 (permalink) |
No Life Poster Join Date: Apr 2007 Location: CLOUD Age: 40
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | i have lumia 625 same problem Error : Unable to find a boot loader option. Press any key to shutdown " can i solved this mathed |
03-16-2015, 15:52 | #8 (permalink) |
Member: 103435 Status: Offline Thanks Meter: 49 | phone was Unable to find bootable option press any key to shut down after writing big boot file *.mmc for flashing the phone got this error "Sending Image Signatures... ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! :" |
03-17-2015, 11:01 | #9 (permalink) |
Freak Poster Join Date: May 2011 Location: Himachal Pradesh,Kangra,India
Member: 1587904 Status: Offline Thanks Meter: 59 | @kasra Bro Post here EMMC CHIP Screen Short then it may clear which type of emmc chip is inside and product manger do something as i have same problem |
03-19-2015, 10:48 | #10 (permalink) |
No Life Poster Join Date: Nov 2003
Member: 44904 Status: Offline Thanks Meter: 45 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D3847325943004248BCD9A0E3 CSD : D02701320F5903FFF6DBFFEF96406063 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : 4248BCD9 Manufactured : October 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: YES TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D3847325943004248BCD9A0E3.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Samsung Remove Write Protection ================================================== ==== --> DO NOT PERFORM THIS ON A NON SAMSUNG BRAND EMMC --> Make Sure you BACKUP eMMC DUMP Just In Case... ================================================== ==== Permanent Write Protection Removed! Perform USB Firmware Update if Needed... error flash : Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR SUPPORTED] ================================================== ==== Windows Phone 8/8.1 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" ================================================== ==== Recovery Handle Found! - (WinUSB) Sending Factory Loader... Loader Upload Done! Executing Loader... Start Loader Done! Waiting for USB Cycle... USB Cycle OK! Device Factory Mode OK! USB Reconfiguration Done... eMMC Detected OK... Extracting Partitions from FFU... Looking for SBL1... SBL1 OK Looking for SBL2... SBL2 OK Looking for SBL3... SBL3 OK Looking for UEFI... UEFI OK Looking for RPM... RPM OK Looking for TZ... TZ OK Looking for WINSECAPP... WINSECAPP OK Extracting Partitions Done! Start Writing eMMC Blocks at : 0x00000000 Start Writing eMMC Blocks at : 0x01000000 Start Writing eMMC Blocks at : 0x01200000 Start Writing eMMC Blocks at : 0x01400000 Start Writing eMMC Blocks at : 0x01600000 Start Writing eMMC Blocks at : 0x01A00000 Start Writing eMMC Blocks at : 0x01C00000 Start Writing eMMC Blocks at : 0x01E00000 eMMC Write OK! Closing Partition... Partition Close OK! BOOT WRITE DONE! Waiting for USB Cycle... USB Cycle OK! Rebooting Phone... Recovery Handle Found! - (WinUSB) USB BOOT Repair FAILED! Try to use eMMC or JTAG Boot Repair Method... ERROR: Flashing Failed! |
03-19-2015, 12:20 | #11 (permalink) |
Member: 44904 Status: Offline Thanks Meter: 45 | Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...No Devices found in Chain! Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...Powered eMMC Not Found, Responce 0x00000000 Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...Powered eMMC Not Found, Responce 0x00000000 |
04-30-2015, 10:44 | #12 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Minsk
Member: 536992 Status: Offline Thanks Meter: 87 | eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D384732594300EA744BFE6093 CSD : D02701320F5903FFF6DBFFEF96406007 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : EA744BFE Manufactured : June 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: YES TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D384732594300EA744BFE6093.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Samsung Remove Write Protection ================================================== ==== --> DO NOT PERFORM THIS ON A NON SAMSUNG BRAND EMMC --> Make Sure you BACKUP eMMC DUMP Just In Case... ================================================== ==== ERROR: SET_BLOCK_LEN (CMD16) A1 Check your Test Point Soldering! |
04-30-2015, 14:06 | #13 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Serg5555 Somebody suggested to change speed to 2.5 Mhz before performing WP Removal. Here: http://forum.gsmhosting.com/vbb/11020988-post9.html |
05-27-2015, 15:44 | #14 (permalink) |
No Life Poster Join Date: Apr 2007 Location: India
Member: 481609 Status: Offline Sonork: 100.1659889 Thanks Meter: 367 | here is another one done eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D38473259430066CBC0609059 CSD : D02701320F5903FFF6DBFFEF96404063 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : 66CBC060 Manufactured : September 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D38473259430066CBC0609059.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ use always new setup |
