Unable to flash Lumia 800 Hi sirs can't flash lumia 800! my system can't find qualcomm cdma technologies msm!!! tested on xp, 7 32bit, 7 64bit! winusb e zune drivers installed! ATF software can "see" the phone but when the flashing start and phone go in flashing mode (asking qualcomm's drivers) the process stops any advice? br sasą |
Install windows Mobile device center |
Zune suite : Download Zune software | Zune.net - Zune software |
Thank's to all but.... zune installed, windows mobile device center installed, same problem |
I have the same problem. Can't install qualcomm's drivers. I try drivers from AFT DRIVERS folder ant try install Zune but this not help. I flash before 2 pcs. Lumia 800, one Lumia 710 but now get one pcs. Lumia 800 and have this problem. Phone work good, but when try flash I have problem qualcomm's drivers. |
Dear I had the same problem and I solved it with doing a hard reset Press and hold the Volume Down, Power and Camera buttons at the same time. When the phone vibrates release the Power button but keep the Camera and Volume Down buttons held for a further five seconds. The phone will now be reset. Good luck |
install lumia driver C:\AdvanceBox Turbo Flasher\Driver\Lumia Phone Drivers BR |
The Problem with devices detected as QUALCOMM MSM Devices cannot be solved by Drivers... because there is no Public Drivers available for this. This is a BUG by Nokia or Microsoft in which the phone does not enter the proper boot mode (OSBL) but instead it reverts to the "developers" boot mode which is the Snapdragon's. Some phones have this problem and some phones don't... It depends on the MODEM file flashed inside the Phone at the factory. You can search Nokia Developer's Forum and see many people having the same problem with no proper solution from Nokia. Nokia Service Centers in my country cannot even flash the phone for me when I brought them 1 Lumia 710 with the QUALCOMM MSM problem. Lumia 710 which are detected as QUALCOMM MSM will also be detected as a Removable Hard Drive. Windows will ask you to format it... But for obvious reasons, do not format it. |
Hmm. And that Nokia Care suite to see and it works? ATF can not see and can not switch modes:-( http://mark1.uw.hu/Care.JPG |
explain the procedure. Is it a normal lumia or a "qualcom msm" model? br |
I do not know, but I did it that way. Nearly 40 pieces, orange tmobile DE etc.... HOWTO Debrand your Nokia Lumia 800 - Giffgaffers g... - The giffgaff community |
too late to saw this post |
In case you missed it, now its possible to repair such phones ;) BR |
plz boss what about using tp to unlock the phone is it possible? |
