07-20-2014, 22:57 | #2 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
UNHAPPY?? and why? this isn't Samsung section, or Atf is Samsung Box, if you want to try with Boot Card via Sdc file, please post request in right section, Here: Samsung SDC Un-Bricker Files Request For G7102_8GB_4.3 is just ready here: SAMSUNG SDC FILES by Linus H. - Page 4 - 4shared For good success on Unbrick you have need same version of Fw wrote in the phone first of Brick and same GB of memory device, if is 8Gb need 8GB sdc file for 16GB same thingh, 16GB sdc file, itc... Br allumts | |
The Following 2 Users Say Thank You to allumts For This Useful Post: |
07-21-2014, 03:03 | #3 (permalink) |
Freak Poster Join Date: Aug 2006 Location: qwer
Member: 329405 Status: Offline Thanks Meter: 29 | ihave the same problem and i solve it with atf download the sdc file and create it with atf after that insert the micro sd to phone now put the phone in download mode by volume - and home and power key or if you have usb jig its easy now the solution------- the phone must vibrate with black lcd and now phone in download mode you can be sure its in download mode if odin detect the phone or not flash the phone with right file regin from sammobile and it should work with you and best thanks to atf team for this solution |
The Following 3 Users Say Thank You to hussam@ For This Useful Post: |
07-25-2014, 10:37 | #5 (permalink) | |
becouse not read post above? i've linked Sdc file for this model, but if you had 4.4.2 version first of Brick, you can create you Sdc file only with BL, CP and PIT file for G7102 v. 4.4.2 easy. What help you want if write "Procedure Problem no solve", not all BRICKED Samsung can be repaired many phones have HW issues and procedure Fail then replace eMMc and solve. Br allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
08-17-2014, 00:23 | #6 (permalink) |
Insane Poster Join Date: May 2014 Location: ******
Member: 2193576 Status: Offline Thanks Meter: 19 | hello .. I updated my grand 2 to 4.4.2. But I found slow net issues. Then I try to back to 4.3 jellybean. But I flash again by odin. But suddenly hang in updating. I remove battery. But I put battery now my phone not charge not going to on . I use many methods to make again download mode. But fail. I make jtag but fail no boot. Please give me any way to put back my grand 2 in normal position. Please help please |
08-18-2014, 04:11 | #7 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | SDC File Created with "G7102XXUBNH3_G7102ODDBNG7_G7102DDUBNG1_HOME.tar.md5" SM-G7102_4.4.2_8GB_G7102XXUBNH3.sdc Flash File from s a m m o b i l e . c o m http://www.s a m m o b i l e . c o m...download=33779 remove spaces... our forum not allow linking to this site. So try with SDC first... |
08-26-2014, 10:07 | #13 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 455296 Status: Offline Sonork: xxxxxxxxx Thanks Meter: 66 | Hi there, okay, let me not to be a spammer. I managed to boot into download mode using SDC "SM-G7102XXUBNG7_4.4.2_8GB", but unfortunately I am not able to find a single multi-file package 4.4.2 for G7102. but I tried single file, Flash is successful, but It boots from memory card!!! It's like eMMC has been chaged to TFCard!!?? It booting into recovery mode with some errors regarding mounting of every single partition pda, csc, efs etc!!! urgent help is required. thanks in advance for your time and help. |
08-26-2014, 13:31 | #14 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @G4N0K Here is G7 "single multi-package" which I used for making SDC image SM-G7102XXUBNG7_4.4.2_8GB So it SHOULD WORK on your phone. Download INU G7102XXUBNH3 20140814141556 zip Also, here is official PIT FILE, which you might need for Odin Repartition (not sure). MS013G_EUR_OPEN_8G.pit |
The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
08-26-2014, 21:18 | #15 (permalink) |
Member: 455296 Status: Offline Sonork: xxxxxxxxx Thanks Meter: 66 | Thank you buddy I was just witing for your special reply, and here u came I did as u said, But still the same thing, not booting from phone memory, It boots from SDCard with mounting errors I am wondering how does exactly SDC thing works? |
