01-17-2014, 21:17 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Made In Brazil Age: 42
Member: 264903 Status: Offline Sonork: 1584531 Thanks Meter: 3,350 | Unlock Lumia 610 Help - [SOLVED] Code: ========================================================== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... Searching for PIN/PUK Unlock Codes... Please wait for a while... Unlock Codes Not Found! All Done!OK Saving "..\Logs\Screenshots\2014-01-17_18-13-12.jpg"...OK |
The Following User Says Thank You to LuisinhoCell For This Useful Post: |
01-18-2014, 00:12 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Use ATF JTAG's new version 1.0.5. It will give you unlock codes. |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
01-18-2014, 12:21 | #3 (permalink) |
Member: 264903 Status: Offline Sonork: 1584531 Thanks Meter: 3,350 | Unlock Done Code: ========================================================== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN LEVEL 1: 22372020 - LOCKED PUK LEVEL 1: 56394757 - LOCKED PIN LEVEL 2: 97494188 PUK LEVEL 2: 61136921 PIN LEVEL 3: 27832066 PUK LEVEL 3: 03291998 PIN LEVEL 4: 51557837 PUK LEVEL 4: 23428953 PIN LEVEL 5: 55854064 PUK LEVEL 5: 19151939 ========================= Reading Unlock Codes Done! ============================================================================ 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ============================================================================ All Done!OK Saving "..\Logs\Screenshots\2014-01-17_18-20-32.jpg"...OK |
