Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 12-10-2012, 09:40   #1 (permalink)
Advance-Box's Avatar
Member: 651945
Unlock Lumia 710 via USB Only in 4 Simple Steps
If you have Qualcomm OSBL, go directly to STEP 3.
If you don't know what Qualcomm OSBL is, start from STEP 1.
STEP 1.
- Update your ATF exe to 9.30 and also UPDATE IMPORTANT FILES.
- After doing this, you should be able to see this File in your Hard Disk:
C:\AdvanceBox Turbo Flasher\Nokia\Lumia\RM803_OSBL_QUALCOMM.esco
---If you cannot see this file inside your Hard Disk, go back to Step 1---
STEP 2.
- Flash this 1 File to your Phone using the +MCU Button on the ATF
software and manually Locating the File in the correct Directory:
Screenshot Helper:
STEP 3.
- Click SP Unlock Button...
STEP 4.
- There is no step 4...
B.R.
X-Shadow
The Following 60 Users Say Thank You to Advance-Box For This Useful Post:
Old 12-10-2012, 09:45   #2 (permalink)
Member: 1699052
Sonork: Don't Use
Really GooD Info Sir Tnx Advance-Box
The Following User Says Thank You to .RoMoN. For This Useful Post:
Old 12-10-2012, 09:46   #3 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Wow, so nice update. Waiting for more Lumia to be added.
The Following User Says Thank You to fun For This Useful Post:
Old 12-10-2012, 09:55   #4 (permalink)
fawad85's Avatar
Member: 301242
awesome great team atf.............................
The Following 2 Users Say Thank You to fawad85 For This Useful Post:
Old 12-10-2012, 10:13   #5 (permalink)
Member: 943187
after upate error.
pls check.
thanks.
Old 12-10-2012, 10:18   #6 (permalink)
Member: 138234
About LUMIA 800, same stapes??
Thx.
Old 12-10-2012, 10:23   #7 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Originally Posted by dArk_shAdE View Post
after upate error.
thanks.
Don't post here n there - ATF Lumia 7.x Direct Unlock v9.30 Update!! Public Discussion Thread:
Br - srinibas
Old 12-10-2012, 10:30   #8 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thx.
Yeah, if your lumia 800 has already OSBL QUALCOMM inside.
Else, you will need to change boot to OSBL QUALCOOM via TP.
Old 12-10-2012, 10:35   #9 (permalink)
alex_030385's Avatar
Member: 875541
Sonork: 100.1604468
STEP 4.
i lol, this one sir your are not only intellegent person you have also a great sense of humor...
Old 12-10-2012, 10:37   #10 (permalink)
Member: 1584200
@dArk_shAdE
uninstall ATF & also delete ATF folder
( before delete ATF folder Keep the backup folder safe )
Install V9.30 & update important files
The Following 3 Users Say Thank You to Saeed Bhai For This Useful Post:
Old 12-10-2012, 10:37   #11 (permalink)
Member: 955311
Wink
And same file use for lumia 800? I meant to ask for unlocking. Thanks
The Following User Says Thank You to maazi For This Useful Post:
Old 12-10-2012, 10:41   #12 (permalink)
Member: 643472
Sonork: 100.96901
Hi,
No files for lumia 800. Because in order to change lumia 800 boot,
you need to make TP.
Old 12-10-2012, 11:00   #13 (permalink)
xxxman's Avatar
Member: 59185
Sonork: 100.1593175
after upate error.
pls check.
thanks.
GOTO SETTINGS , GeneralSettings
select IMetal_Dark.skn
The Following 2 Users Say Thank You to xxxman For This Useful Post:
Old 12-10-2012, 11:26   #14 (permalink)
unlock phones's Avatar
Member: 1552610
Originally Posted by Saeed Bhai View Post
@dArk_shAdE
after change skin to imataldark now working file
The Following 3 Users Say Thank You to unlock phones For This Useful Post:
Old 12-10-2012, 11:30   #15 (permalink)
aliyousafzai's Avatar
Member: 1358184
Sonork: 100.1616912
Great team did always great work
The Following 5 Users Say Thank You to aliyousafzai For This Useful Post:
Page generated in 0.38011 seconds with 10 queries
