02-25-2014, 18:13 | #1 (permalink) |
Junior Member Join Date: Oct 2012 Location: manipur
Member: 1818885 Status: Offline Sonork: kabi Thanks Meter: 0 | updadate firmware poblem. done that step 1 to 4 again again but problem not solve Please update your Box Firmware ============================================== * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button * Make sure you put ATF Software in Windows FireWall Exclusion List * Make sure you put ATF Software in your Virus Scanner Exclusion List ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
02-25-2014, 23:25 | #3 (permalink) | |
Insane Poster Join Date: Nov 2011 Location: mindoro
Member: 1690198 Status: Offline Sonork: 100.1652096 Thanks Meter: 13 | Quote:
first of all check this: Make sure you put ATF Software in Windows FireWall Exclusion List PROBLEM: SOLUTION: TIP: turn off your anitvirus and be sure your not afected of any system block by virus or autorun.inf pile or etc. DONE: PROVE: good luck sir,. | |
