02-01-2016, 06:46 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: india
Member: 1161713 Status: Offline Sonork: 100.1607798 Thanks Meter: 421 | update Box Firmware ERROR FireWall Exclusion List === DONE Make sure you put ATF Software in your Virus Scanner Exclusion List ==== DONE |
03-14-2016, 07:32 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Read regularly about product update in official section Install full installer of ATF 12.60 >>> Auto update to V12.67 & Update box firmware Br - srinibas |
03-14-2016, 08:10 | #5 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Poland
Member: 372482 Status: Offline Thanks Meter: 93 | You can only this way update your box when you cant add hosts via ATF SOFTWARE. Tested by me at 4 atf boxes and 4 Laptops and Pc's You have 2 ways if you get the problem with "error server connection" 1. You go to: C:\Windows\System32\drivers\etc 2. Make a copy of the file hosts 3. Rename the file hosts to hostold 4. Rename hosts copy to hosts 5. Now you can click in ATF SOFTWARE the button called "Add ATF Servers to Windows hosts File" 6. Update firmware and feal the POWER other way is: 1. You go to: C:\Windows\System32\drivers\etc 2. Open the file hosts with NOTEPAD 3. Add at the end this 2 lines: 174.120.45.28 www.advanceturboflasher.com 174.120.45.29 www.atf-lightning.com 4. Save the file hosts 5. Update firmware and feal the POWER If my posts was useful please click on thanks button |
The Following 4 Users Say Thank You to Madol1 For This Useful Post: |
03-15-2016, 08:10 | #11 (permalink) |
Member: 372482 Status: Offline Thanks Meter: 93 | Why you so lazy? I have already posted solution to get the atf servers manualy added to hosts file. See here: http://forum.gsmhosting.com/vbb/f609.../#post11691761 |
03-18-2016, 05:08 | #12 (permalink) | |
Member: 1161713 Status: Offline Sonork: 100.1607798 Thanks Meter: 421 | Quote:
Thanks Prob Solved by this method Code: 1. You go to: C:\Windows\System32\drivers\etc 2. Make a copy of the file hosts 3. Rename the file hosts to hostold 4. Rename hosts copy to hosts 5. Now you can click in ATF SOFTWARE the button called "Add ATF Servers to Windows hosts File" 6. Update firmware and feal the POWER | |
03-19-2016, 09:49 | #13 (permalink) | |
Freak Poster Join Date: Jul 2010 Location: Behind u...
Member: 1355122 Status: Offline Sonork: inside certificate Thanks Meter: 34 | Quote:
03-27-2016, 10:21 | #15 (permalink) |
Member: 1161713 Status: Offline Sonork: 100.1607798 Thanks Meter: 421 | For Windows 7 Users just Download This File And paste Here C:\Windows\System32\drivers\etc Download Download Last edited by omkar3268; 03-27-2016 at 10:27. |
