04-19-2014, 15:29 | #52 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Arizona Age: 38
Member: 630795 Status: Offline Thanks Meter: 177 | Phone found! Series 40 Device detected! read info... - Ok Core : v1.82 , BB5XG FlashEngine : v9.5 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm961_02.700 PPM : rm961_02.70ic CNT : rm961_nai02.70ic Infineon flashing... -> Infineon XG110 : IMEI Backup Created Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 PBL : Dynamic Boot Ok , 01AB SBL : Dynamic Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH VEN : 00000020 FLASH DIE : 00008804 FLASH ID : UNKNOW [Not In Base] Boot Done! ===Flashing [MCU]=== File : rm961_02.700 Image : hw_b1_rm961_02.700.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00000000 , Len : 0x00020000 Erasing, wait ... Erase done Write , Start : 0x00000000 , Len : 0x00006000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00800000 , Len : 0x00400000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x003F0000 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00C5D000 , Len : 0x00203000 Erasing, wait ... Erase done Write , Start : 0x00C5D000 , Len : 0x0019E700 Flashing , wait ... Region flash done Check : FCAF ===Flashing [PPM]=== File : rm961_02.70ic Image : hw_b1_rm961_02.70ic.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00100000 , Len : 0x00700000 Erasing, wait ... Erase done Write , Start : 0x00100000 , Len : 0x00571840 Flashing , wait ... Region flash done Check : 1B36 ===Flashing [CNT]=== File : rm961_nai02.70ic Image : hw_b1_rm961_nai02.70ic.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00E60000 , Len : 0x00100000 Erasing, wait ... Erase done Write , Start : 0x00E60000 , Len : 0x000FEE00 Flashing , wait ... Region flash done Check : 54CF Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! MY PHONE STOPED WORKING SUDDENLY i FLASHED IT SUCCESSFULY BUT IT WONT START . ITS KINDA DEAD OR WHAT ?? I TRIED SO MANY FLASHES |
The Following User Says Thank You to sobaro For This Useful Post: |
05-13-2014, 20:10 | #59 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Almoradi (ALICANTE) . SPAIN
Member: 1677266 Status: Offline Thanks Meter: 90 | hi i get this error try to read flash from phone,but whit this phone no luck.it has Spanish Portuguese, English and dutch.if someone can help to read the flash to upload. thanks START INFINEON BUS CHECK ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer ID: 0x00EF Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Multi-Bank / 1.8v Reading NOR Flash: 0x00000000~0x00800000 WARNING: Invalid Data at 0x007FF800 Flash Dump Done... ************************************************** **** INFINEON BUS CHECK DONE ************************************************** **** Detected Phone Type: RM-908 MCU File Saved: C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-908\rm908_02.700 PPM File Saved: C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-908\rm908_02.70ag CNT File Saved: C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-908\rm908_nai02.70ag VPL File Saved: C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-908\RM908_059R447_02.70_001.vpl Performing Final File Checks... MCU File is OK... ERROR: PPM File is Incomplete! Deleting PPM File... CNT File is OK... Flash Files Dump Success! Total Time: 00:02:08 |
