08-20-2011, 08:09 | #1 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 796514 Status: Offline Sonork: 100.1583845 Thanks Meter: 53 | Urgent need Nokida E5 ENO file RM-632 - [SOLVED - ENO Link Inside] Friends and mods, I need nokia E5 Rm-632 v 071.003 ENO file very urgent. Due to wrong software tires phone is now just white screen condition and sometime blink. Before wrong tries it was just vibrate when press power button and shows test mode attaching fbus cable. I will be thankful If someone can give file or do help. thanks and regards. |
08-20-2011, 09:19 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @Mr. Right I chked, there is no ENO file available for Nokia E5-00 RM-632, even NOT inside newest package - 71.xx BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
08-20-2011, 09:33 | #4 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Can suggest you only to flash with latest version and matching product code file. EraseFlash - cannot suggest as it requires ENO afterwards. BR | |
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post: |
08-21-2011, 23:05 | #8 (permalink) | ||
Freak Poster Join Date: Sep 2007 Location: Indonesia Age: 41
Member: 584778 Status: Offline Thanks Meter: 78 | Quote:
u can erase that phone with ATF and flash again with same product code then 1st step u must fill PM file 120 and then write again RPL. now,that phone have SD invalid ,so u can authorized phone with ATF network and repair SD.next step u must fill phone with another PM file from good phone and then u must fill again with Original PM (Standalone). now you'll make it back to normal Phone. Good luck BR, mr_dany | ||
The Following User Says Thank You to dany_kroya81 For This Useful Post: |
08-23-2011, 09:32 | #10 (permalink) | |
Member: 796514 Status: Offline Sonork: 100.1583845 Thanks Meter: 53 | Quote:
Now it is not connecting with ATF, following is log AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C35 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0D500109 ID DWORD 1 : B29C0344 ID DWORD 2 : AF18DBF2 ID DWORD 3 : F136A905 ID DWORD 4 : A1279CAF 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B Checksum D6 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Boot File - Version 011.016.00 Boot File - Revision 0x0003 (3) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 ERROR: Phone did not respond... ERROR: Sending Loader Failed... | |
08-23-2011, 15:32 | #11 (permalink) | |
and your box have any problem please restore box first | |
08-24-2011, 08:45 | #12 (permalink) | |
No, it will NOT work for newest RAPU and RAPIDO phones, since they needs ENO file after full ERASE and without ENO file, phone will be only in WHITE DISPLAY - means you cannot even write your PM backup to fix simlocks : ) However, you could write RPL to fix IMEI but It's useless with simlocks corrupetd! BR | |
08-24-2011, 17:10 | #13 (permalink) | |
I have E5-00 with same problem and now this phone work perfect I have backup before Phone have problem (1 month ago i have backup this phone) This Phone come again to me with a white display, cant make a call. try to flash it with any version problem not solved.and i try to repair this phone with erase flash. step 1. Full erase 2. Write full backup PM (1-309) 3. Write RPL ( now SD Invalid) 4. Connect to ATF Network and Repair SD (now Phone Security test failed ) 5. Write PM with Other PM (Normal Phone) (Standalone) 6. Write PM again with Original PM (Standalone) 7. Try to read info What wrong sir ???? and now phone work perfectly............ can you tell me what's wrong with my step ? what the phone is corrupt simlock ? now im enjoy working with my lovely ATF | |
08-25-2011, 09:31 | #14 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: sai baba shirdi Age: 44
Member: 670629 Status: Offline Sonork: 100.1590208 Thanks Meter: 431 | Quote:
go for atf support site and download e5-rm-632 eno file | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
