10-25-2015, 14:49 | #1 (permalink) | |||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | USB Boot Repair for GT-i9505 Lollipop 5.0.1!! NOT WORK!! Quote:
With "Emergency Drivers": Quote:
Any solution please? BR allumts | |||
10-26-2015, 21:24 | #3 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | This is same problem of all, no one are showing more that have solved, so i think there's any Bug stopping this restore I9505....impossible that small time ago i've repaired more piece at first time and now are all with Broken EMMC...but who can answer will be busy and we must need of wait the Big @ X-Shadow....hope answer soon becouse i'm tired of replace EMMC BR allumts |
10-26-2015, 22:49 | #4 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Mr allumts. This is problem in rom2 partition. Solution is emmc direct and dump file in version 5.1. When boot 2 is ok, usb repair work very well without errors. |
The Following 2 Users Say Thank You to toninhosantos For This Useful Post: |
10-26-2015, 23:02 | #5 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Sorry, you have this dump file for write with EMMC direct? or i've understand bad? You means only write Rom2 via EMMC direct and later .bin boot 5.1 by Usb...is right or no |
11-11-2015, 13:29 | #6 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @toninhosantos, full Dupmp posted by Atf Team is complete of all, i've read all partition with "Mount Virtual Disk", and issue isn't in ROM 2...for me problem is only in Drivers becouse with all these Update from Microsoft now also drivers always working yesterday have get my ATF in "USB DUAL SERIAL", after installed one Update....must need of restore Eprom and re-install first from "ATF NEW DRIVERS" and later update these with Microsoft... So see that mode always has worked in USB only for I9505, i think that if X-Shadow get one test or explain why not work more with this Full Boot.bin for 5.1.1 we not go out of this issue... you procedure for 4.4.4 working good, but must need EMMC DIRECT TP, at this time is useless this Update released...or i'm wrong?...mmmmhhmm not think Update is Clear: Quote:
allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
