02-26-2013, 12:25 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: hang on logo
Member: 272814 Status: Offline Thanks Meter: 43 | usb flashing problem Number of Image Files: 3 Processing Image File : rm598__10.81.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 159 Entry Point: 0x0259 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm598__10.81.ppm_meaa CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 23 Entry Point: 0x011D Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm598__10.81.image_meaa_0590660_007 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 62 Entry Point: 0x0154 Page Format : -1 MAX PAGE : 0x00040000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00000001 ID DWORD 3 : 020C1921 ID DWORD 4 : 02044100 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001051 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001060 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 22200315 ID DWORD 1 : CFC46040 ID DWORD 2 : 3D0AE592 ID DWORD 3 : 46CF6E90 ID DWORD 4 : 3BB99ACD 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 67E82268 CRC 1 : F29CEA60 CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0030 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0431 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0030 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 08000000 (128 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_XSR17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) Booting/Flashing Failed... Please Try Again... |
02-26-2013, 18:08 | #2 (permalink) |
Member: 272814 Status: Offline Thanks Meter: 43 | any way no answer from atf team , to be known i try different solution finally it is programme conflict with samsung kies , i remove the kies and now flashing goes well.... |
02-26-2013, 21:52 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, That's kinda strange... KIES shouldn't have any thing to do with ATF USB flashing. The error should be resolved by: reinstalling Nokia USB drivers, updating important files in ATF Software. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
