Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 08-09-2012, 13:36   #1 (permalink)
kabul's Avatar
Member: 433097
usb flashing problem ERROR: PBL Not Found - [SOLVED]
Number of Image Files: 3
Processing Image File :
rm761__11.56.mcusw
rm761__11.56.ppm_mec
rm761__11.56.image_mec_059J541_003
[]: Found 1 active devices.
[Nokia USB Phonet]: Opening Connection
[Nokia USB Phonet]: Port opened OK!
SW: V 10.60 20-01-12 RM-761 (c) Nokia
IMEI: 359348041212044
START FULL PM BACKUP
Please Wait...
Reading : PM 0~400... OK!
FULL PM Backup Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\359348041212044\USB_FULL_BACK UP_V 10.60 20-01-12 RM-761 (c) Nokia_359348041212044__53409.pm
Reading Battery Value : 3721 mV
Rebooting Phone...
AUTO SELECTED DEAD USB FLASHING...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Old 08-09-2012, 13:47   #2 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
From Advance-Box
@ALL
PBL not found means your flash files are not correct as they may have
been downloaded from another team's Support Site which they edit the
flash files so that it will only work with their software.
Solution is simple, just download the Flash Files again using ATF Support
or Navifirm (if available)
Example: c1 error: pbl not found
Polaco
Old 08-09-2012, 16:15   #3 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
@el-polaco
That's your Flash File problem. Just click on CHECK button...
+MCU
+PPM
+CNT
Clear
Check <---- this button.
And you'll see what I meant... We already added Flash File Check
before Flash starts in our next version. So, no more will be this kind
of problems caused by bad flash files...
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 08-09-2012, 22:17   #4 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
Originally Posted by ..::Angel::.. View Post
@el-polaco
+MCU
+PPM
+CNT
Clear
I not have a doubt about this problem!
I ask you about this problem
x2-01
Good idea fix this flash problem,But, I waiting for stand alone process (no more authorize Phone)
br
polaco
Old 08-10-2012, 09:02   #5 (permalink)
kabul's Avatar
Member: 433097
Thanks for help sovled my problem
rm761__11.64.mcusw
rm761__11.64.ppm_mec
rm761__11.64.image_mec_059J5Q0_003
2. Insert USB.
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Sections : 04
Current File : rm761__11.64.mcusw
Compile Name: rm761__11.64.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 26480008 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 04
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: C1BC
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 04
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7A7A
Processing Section 03 of 04
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: 18CC
Processing Section 04 of 04
FIRMWARE Erase Block: 0x40280000~0x41A7FFFE
Start Erasing...
Block Erase Done...
Data Size: 25165824 bytes
Data Checksum: 4DD9
Data Verification Successful...
Sections : 01
Current File : rm761__11.64.ppm_mec
Compile Name: package_mec.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 6668840 Bytes
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x41A80000~0x421BFFFE
Start Erasing...
Block Erase Done...
Data Size: 6665496 bytes
Data Checksum: A496
PPM Data Blocks uploaded to phone...
Sections : 01
Current File : rm761__11.64.image_mec_059J5Q0_003
Compile Name: package_mec_059J5Q0.image.fls
Image Type : CONTENT Package
Data Size : 15338768 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x421C0000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 15335424 bytes
Data Checksum: DE32
CONTENT Data Blocks uploaded to phone...
Total Flashing Time (Erase + Flashing) : 00:04:22
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
Basic Phone Information
MCU Version: V 11.64 07-06-12 RM-761 (c) Nokia
IMEI Plain : 359348041212044
IMEI Spare : A359348041212040
IMEI SV : 33593480412120409F
Phone Model: Nokia 200
Category : Entry Phone
Phone Type : RM-761
Extended Phone Information
Product Serial Number: 761DA49AH
Product Code : 059J4L0
Module Code : 0204895
Basic Production Code: 059F7N6
Long Production SN : 0
PPM SW Version : V 11.64 07-06-12 RM-761 (c) Nokia MEC
BT MCM Version : 19e2-47026
MCU SW Version : V 11.64 07-06-12 RM-761 (c) Nokia
HW Version : 1000
RFIC Version : Dummy RFIC version
LCD Version : AUO
FWID Version : kV 11.64 07-06-12 RM-761 (c) Nokia V 11.64 07-06-12 RM-761 (c) Nokia MEC 059J4L0 003
Content Pack Version : Content: mec_059J5Q0 V 11.64 07-06-12 RM-761 (c) Nokia
Bluetooth ID : F4:8E:09:34:CB:88
CS Type : GSM900, GSM1800
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 800000000003000B
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : 06150123
DCC Ver: 008027
Status : OK
Selected VPL File:
RM761_059J5Q0_11.64_015.vpl
Variant Details : RM-761 NDT MEA10 ARABIC BLUE
Software Version : 11.64
Product Type : RM-761
Product Code : 059J5Q0
Variant Version : 015
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
RESET LIFE TIMER TO : 0000:00
OK
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-28-1999 14:56
Page generated in 0.42285 seconds with 11 queries
