Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 12-21-2012, 13:25   #1 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
v9.40 still usb flashing problem
i faced usb flashing problem in C5-03 and N8
please do the needful
Old 12-21-2012, 13:51   #2 (permalink)
saqib2009's Avatar
Member: 515406
Sonork: 100.1603457
Thanks Meter: 883
Atf Team Pliz Fix Usb Flashing Bug other tools easy Flash
Todat i update 9.40 and update imported file and flash nokia c2-03 rm-702 see result
Atf Result
16:20:08 : Number of Image Files: 3
16:20:08 :
16:20:08 : Processing Image File :
16:20:08 : rm702__07.48.mcusw
16:20:08 : rm702__07.48.ppm_q
16:20:08 : rm702__07.48_006.image_q_ctv_hk_9k9c0
16:20:09 :
16:20:09 :
16:20:09 : AUTO SELECTED DEAD USB FLASHING...
16:20:09 :
16:20:09 : If Phone Booting does not Start in 5 Seconds,
16:20:09 : Then Perform Steps 1, 2, 3 and 4...
16:20:09 :
16:20:09 : 1. Remove USB and Battery...
16:20:09 : 2. Insert USB.
16:20:09 : 3. Insert Battery. (Some phones boot automatically)
16:20:09 : 4. Please Power on phone shortly...
16:20:09 :
16:20:18 : ERROR: BOOTING FAILED...
16:20:31 : Number of Image Files: 3
16:20:31 :
16:20:31 : Processing Image File :
16:20:31 : rm702__07.48.mcusw
16:20:31 : rm702__07.48.ppm_q
16:20:31 : rm702__07.48_006.image_q_ctv_hk_9k9c0
16:20:33 :
16:20:33 :
16:20:33 : AUTO SELECTED DEAD USB FLASHING...
16:20:33 :
16:20:33 : If Phone Booting does not Start in 5 Seconds,
16:20:33 : Then Perform Steps 1, 2, 3 and 4...
16:20:33 :
16:20:33 : 1. Remove USB and Battery...
16:20:33 : 2. Insert USB.
16:20:33 : 3. Insert Battery. (Some phones boot automatically)
16:20:33 : 4. Please Power on phone shortly...
16:20:33 :
16:20:36 :
16:20:36 : Infineon USB Boot: F00A1FB300020303010100FF
16:20:36 : Sending PBL...
16:20:39 : PBL Successfully Sent...
16:20:39 : Sending SBL...
16:20:39 : SBL Successfully Sent...
16:20:39 : Setting Transmission Speed Done...
16:20:39 : Flash Chip Manufacturer: Intel Electronics Corp.
16:20:39 : Flash Boot Successful...
16:20:39 : Unique Data: EF0B80800C0C6000
16:20:39 : Original Product Code: 059D434
16:20:40 : Reading : CCC... OK!
16:20:40 : Reading : HWC... OK!
16:20:40 : Reading : NPC... OK!
16:20:40 : RPL Backup was Successful...
16:20:40 : Plain RPL saved to:
16:20:40 : C:\AdvanceBox Turbo Flasher\Nokia\Backup\359325043387966\3593250433879 66_42040.rpl
16:20:40 :
16:20:40 :
16:20:41 : Data Sections : 04
16:20:41 : Current File : rm702__07.48.mcusw
16:20:41 : Compile Name: rm702__07.48.mcusw_ebl_psi.fls
16:20:41 : Image Type : Main Firmware
16:20:41 : Data Size : 29363592 Bytes
16:20:41 :
16:20:41 : Sending Certificate Block
16:20:41 : FIRMWARE Certificate Block Sent Successfully...
16:20:41 : Processing Section 01
16:20:41 : FIRMWARE Erase Block: 0x40000000~0x4001FFFE
16:20:41 : Start Erasing...
16:20:41 : Erasing Please Wait...
16:20:42 : Block Erase Done...
16:20:42 : Preparing Data Blocks...
16:20:42 : Data Size: 131072 bytes
16:20:42 : Data Checksum: EE63
16:20:42 : Uploading Data Blocks to phone...
16:20:42 : Block Write Successful...
16:20:42 : FIRMWARE Data Blocks uploaded to phone...
16:20:42 : Processing Section 02
16:20:42 : FIRMWARE Erase Block: 0x40040000~0x4005FFFE
16:20:42 : Start Erasing...
16:20:42 : Erasing Please Wait...
16:20:43 : Block Erase Done...
16:20:43 : Preparing Data Blocks...
16:20:43 : Data Size: 131072 bytes
16:20:43 : Data Checksum: 7AB2
16:20:43 : Uploading Data Blocks to phone...
16:20:43 : Block Write Successful...
16:20:43 : FIRMWARE Data Blocks uploaded to phone...
16:20:43 : Processing Section 03
16:20:43 : FIRMWARE Erase Block: 0x40060000~0x4015FFFE
16:20:43 : Start Erasing...
16:20:43 : Erasing Please Wait...
16:20:49 : Block Erase Done...
16:20:50 : Preparing Data Blocks...
16:20:50 : Data Size: 1048576 bytes
16:20:50 : Data Checksum: C893
16:20:50 : Uploading Data Blocks to phone...
16:20:51 : Block Write Successful...
16:20:51 : FIRMWARE Data Blocks uploaded to phone...
16:20:51 : Processing Section 04
16:20:51 : FIRMWARE Erase Block: 0x40280000~0x41DBFFFE
16:20:51 : Start Erasing...
16:20:51 : Erasing Please Wait...
16:23:30 : Block Erase Done...
16:23:30 : Preparing Data Blocks...
16:23:30 : Data Size: 28049408 bytes
16:23:30 : Data Checksum: 6FB2
16:23:30 : Uploading Data Blocks to phone...
16:24:09 : Block Write Successful...
16:24:09 : FIRMWARE Data Blocks uploaded to phone...
16:24:09 : Processing Section 05
16:24:09 : FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
16:24:09 : Start Erasing...
16:24:09 : Erasing Please Wait...
16:24:09 : Block Erase Done...
16:24:09 : Data Verification Successful...
16:24:09 :
16:24:09 :
16:24:09 : Data Sections : 01
16:24:09 : Current File : rm702__07.48.ppm_q
16:24:09 : Compile Name: package_q.ppm_ebl_psi.fls
16:24:09 : Image Type : PPM Image
16:24:09 : Data Size : 5545148 Bytes
16:24:09 :
16:24:09 : Sending Certificate Block
16:24:09 : PPM Certificate Block Sent Successfully...
16:24:09 : Processing Section 01
16:24:10 : PPM Erase Block: 0x41DC0000~0x424BFFFE
16:24:10 : Start Erasing...
16:24:10 : Erasing Please Wait...
16:24:33 : Block Erase Done...
16:24:33 : Preparing Data Blocks...
16:24:33 : Data Size: 5541804 bytes
16:24:33 : Data Checksum: AF6C
16:24:33 : Uploading Data Blocks to phone...
16:24:41 : Block Write Successful...
16:24:41 : PPM Data Blocks uploaded to phone...
16:24:41 : Data Verification Successful...
16:24:41 :
16:24:41 :
16:24:41 : Data Sections : 01
16:24:41 : Current File : rm702__07.48_006.image_q_ctv_hk_9k9c0
16:24:41 : Compile Name: package_q_ctv_hk.image.fls
16:24:41 : Image Type : CONTENT Package
16:24:41 : Data Size : 14814480 Bytes
16:24:41 :
16:24:41 : Sending Certificate Block
16:24:41 : CONTENT Certificate Block Sent Successfully...
16:24:41 : Processing Section 01
16:24:41 : CONTENT Erase Block: 0x424C0000~0x43E1FFFE
16:24:41 : Start Erasing...
16:24:41 : Erasing Please Wait...
16:27:18 : ERROR: Erasing Failed
and here is next try with Infinty Best dongle same selected file see log
Best Dongle Result
Connect phone on selected interface...
Core : v1.59 , BB5XG FlashEngine : v3.8
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm702__07.48.mcusw
PPM : rm702__07.48.ppm_q
CNT : rm702__07.48_006.image_q_ctv_hk_9k9c0
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" - just reinsert battery
-> If flashing freeze - reinsert cable and try again
--- Press phone's power button or insert charger! ---
Connection opened successfully
DBG : F00A1FB300020303010100FF
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_10.46_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 359325043387966
IMEI 2 : 359325043387974
PCcode : 059D434
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\359325043387966_35 9325043387974_XG213_CRT.rpl
===Flashing [MCU]===
Image : rm702__07.48.mcusw_ebl_psi.fls
Cert block found, sending....
Cert sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:06
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01B40000
Erasing, wait ...
Erase done, time : 00:02:51
Write , Start : 0x40280000 , Len : 0x01AC0000
Flashing , wait ...
Region flash done, time : 00:00:42
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
===Flashing [PPM]===
Image : package_q.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41DC0000 , Len : 0x00700000
Erasing, wait ...
Erase done, time : 00:00:33
Write , Start : 0x41DC0000 , Len : 0x00548FAC
Flashing , wait ...
Region flash done, time : 00:00:06
===Flashing [CNT]===
Image : package_q_ctv_hk.image.fls
Cert sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x424C0000 , Len : 0x01960000
Erasing, wait ...
Write , Start : 0x424C0000 , Len : 0x00E20000
Flashing , wait ...
Region flash done, time : 00:00:19
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:07
No write data, skip
Flashing done!
Total flash time : 00:04:50
Reboot phone now...
Reading Phone Info....
Connected phone - C2-03
Software Info: V 07.48 23-02-12 RM-702 (c) Nokia
IMEI: 359325043387966
PPM version : V 07.48 23-02-12 RM-702 (c) Nokia Q
Product code: 059D434
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Checking User Certificates...
Total - 42 certs
Data exist, skip certificate repair...
Battery voltage is enough for start
AfterFlash operations done ;D
Done!
Elapsed: 00:05:32
Phone found!
Series 40 Device detected!
read info... - Ok
Old 12-21-2012, 21:15   #3 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: Kfe~Labs Co.-
Thanks Meter: 568
Flash Again With ATF.
I sure 100% Phonet Nokeya Drivers
Polaco
Page generated in 0.18872 seconds with 8 queries
