Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 02-14-2014, 06:54   #61 (permalink)
alex_030385's Avatar
Member: 875541
Sonork: 100.1604468
Thanks Meter: 327
after install image file to mmc card ,should I insert micro uart 150k cable rj45 side to atf port ?, I have z3x micro uart cable is it possible to get download mood ?
I m new for ATF explai ATF experts
Report Post
make sure you are fully charge and memory card slot 100% working
try to use rj45 cable c3303k and conect to z3x or use modified 300k resistor...
N7100 deadboot another shot by ATF easy boot feel the power...
Old 02-14-2014, 11:33   #62 (permalink)
Member: 1233181
i747 unknown baseband possible to repair sdc file
Old 02-14-2014, 11:50   #63 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
@alex_030385 and ALL, how do you can use the "JIG UNBRICK" 301K resistor, at the same mode can connect easy only "MicroUartCable" 130K resistor (Rextore for Octopus), if not have the 130K for Octopus can use the C3303 Rj45 always for Octopus ...OR any MicroUartCable is good for help device to go in D.Mode....., No need to connected in Any BOX, only these cables whith them resistors inside are Ok for get the Target...not begin to confuse things!!!!
ONLY for write Full Flash whith 4 files, (mx-pit inclusive), after phone is entered in D.Mode, you can write this whith any BOX, that support format of fw, or simple Odin for Full Flash in Home.tar format....
I want to hope that all this can help to understand good WHY the RJ45-130K, 301K,(Jig Unbrick), Rj45-3303 or Any "MicroUartCable RJ45" cable, WHY the Samsung Box, Why Odin... ATF goes used only for create "Boot Card" via sdc .img file and mmc card !!!!
Best Regard,
allumts
NOTE: if device after full procedure remain in "Bootloop", (blinking Logo Samsung), just rewrite EFS whith Odin
Old 02-14-2014, 12:27   #64 (permalink)
allumts's Avatar
Member: 1564612
Originally Posted by young_floyd View Post
@lemor
It worked fine, I needed to set the pit file for the N7100, by the way do you know any source where I can download full flash (4 files) to flash I9300 I got one from telcel Mexico to repair boot, but cant find full flash.
thank you.
Hello, FOR ALL,
here posted Firmware Multi File for Samsung Galaxy SIII GT-I9300 (Android 4.0.4/4.1.2/4.3)
http://forum.gsmhosting.com/vbb/10069708-post1.html
tx to DZ-DEVELOPER,
regards
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 02-17-2014, 06:59   #65 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
required n900p sdc file
Old 02-17-2014, 08:21   #66 (permalink)
Member: 1627229
Thanks Meter: 48
i have note 2 product mode is black can u repair this phone
Old 02-17-2014, 22:06   #67 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
Does GT-I9300_I9500_N7100.img.sdc support up to 4.3 or only lower versions?
Old 02-18-2014, 00:38   #68 (permalink)
allumts's Avatar
Member: 1564612
bro, 4.3 is lower version?
Old 02-18-2014, 07:49   #69 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
you didnt understand what i mean. i mean if this image only works when on phone was a firmware version lower than 4.3. because on some image files is 4.3 written on the end of the filename.
Gesendet von meinem GT-I9100 mit Tapatalk
Old 02-18-2014, 08:35   #70 (permalink)
Member: 764695
Sonork: 100.1627861
Thanks Meter: 45
need i9100g img.sdc file
Old 02-18-2014, 08:40   #71 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
can any sure about resistan it 150k or 330K am so cofuse whice 1 must i use >?
big thank to Aft to the big boom update
Old 02-18-2014, 09:15   #72 (permalink)
Member: 764695
Sonork: 100.1627861
Thanks Meter: 45
need i9100g img.sdc file urjent plz help me any one
Old 02-18-2014, 12:19   #73 (permalink)
allumts's Avatar
Member: 1564612
Bro i've understand you question and tested in I9300 Bricked, this I9300 was whith V. 4.1.2 and Sdc . img file has put this in D.Mode w/o problem, after of the D.Mode i can choise which fw multi file whith mx-Pit flash in device, is wrote V.4,3 becouse now all New Security device have this version, but it's working whith any Full Fw, hope i'm clear now.
For the Microuart Cable, there is wrote 130K resistor becouse Test was been whith one BOX that have this Uart cable, but you can use , (tested by to me), easy JIG Unbrick for put in D.Mode or if you have Octopus for example, you can use they Uart cable 3300K, any Uart cable sent in D.Mode working phone, test yourself, insert one Micro Uart cable of any BOX in I9300, (4 example), from power off and you see that this goes in D.Mode.....
Regards
allumts
Old 02-18-2014, 13:11   #74 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
your bricked device had version 4.1.2. my question was if this image file works when the bricked device had 4.3 installed.
Old 02-18-2014, 13:26   #75 (permalink)
allumts's Avatar
Member: 1564612
Off course is sdc .img file I9300/N7100/I9500 no matter which fw had first the device, is bricked now, So you can restore and aftere rewrite 4.3 fw version w/o problem..
Page generated in 0.20697 seconds with 9 queries
