Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 11-26-2012, 01:13   #1 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
Very frustrating problem... <<< SOLVED >>>
I have been having this error for sometime back, i was thinking that it was problem from windows because its been long i've been using system, so i install clean os and did installed aft 9.10 full installer , then install box with new drivers and update to version 9.15 also updated box fw. still this error will not go anytime i scan phones it comes up, i have to restart software again before i can continue work..just frustrating atimes.
What can i do pls team...
Old 11-26-2012, 06:24   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Step 1: Delete all files inside
C:\AdvanceBox Turbo Flasher\Data\
Step 2: Overwrite
C:\AdvanceBox Turbo Flasher\AdvanceBox.ini
with File Attached on this post...
Br - srinibas
Old 11-26-2012, 09:55   #3 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
@thomp4pal
Download and install ATF 9.20. We fixed this in it..
Old 11-26-2012, 10:02   #4 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
Step 2: Overwrite
Br - srinibas
Thank you bro, for your reply..I followed steps as you directed but still same error when i scan phone..? i wonder why
am runing xp sp2.
Old 11-26-2012, 10:11   #5 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
Originally Posted by ..::Angel::.. View Post
@thomp4pal
Okay, i only have link for 9.10, if update files will it upadte to 9.20? A direct link would do though..thanks
Old 11-26-2012, 10:15   #6 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
http://forum.gsmhosting.com/vbb/8965957-post30.html
Br - srinibas
The Following User Says Thank You to srinibas For This Useful Post:
Old 11-26-2012, 10:19   #7 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
Pls. check this post too, i need value urgently as set must be returned shortly..
http://forum.gsmhosting.com/vbb/8964881-post31.html
Thanks
Old 11-26-2012, 10:46   #8 (permalink)
Member: 643472
Sonork: 100.96901
Thanks
Hi,
That is 10K Ohms resistor.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 11-26-2012, 10:50   #9 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
Hi,
you are too kind, thanks man
Old 11-27-2012, 01:35   #10 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
Bro still same problem with version 9.20, i will upgrade to xp sp3 and see if this problem is with sp2,
B.R
Old 11-27-2012, 01:53   #11 (permalink)
Rhyan777's Avatar
Member: 893209
Thanks Meter: 274
Bro TRy this,,,
http://forum.gsmhosting.com/vbb/8779800-post60.html
1.RUN REGEDIT
2.GO TO HKEY_LOCAL_MACHINE/NAVIGATE TO SOFTWARE
3.GO TO NOKIA MOBILE PHONES/TSSshared
4.SELECT InsPath/delete "REG_BIN" IF its visible
5.RIGHT CLICK InsPath/GO TO PERMISSION/CHECK DENY ALL/YES
6.Done
Coz last time i'm facing also that PROBLEM same as your's then i fix using that Solution..
Hope your ATF WORKING FINE,,,
Br,.
Rhyan
Old 11-27-2012, 11:23   #12 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
Originally Posted by Rhyan777 View Post
Bro TRy this,,,
1.RUN REGEDIT
6.Done
Br,.
Rhyan
Okay thanks for your input, but i cant find step 3. in my machine. (3.GO TO NOKIA MOBILE PHONES/TSSshared ) here it is only NOKIA, not NOKIA MOBILE PHONES...pls check attached picture
Old 11-27-2012, 11:24   #13 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
Bro TRy this,,,
1.RUN REGEDIT
6.Done
Br,.
Rhyan
B.R
Old 11-27-2012, 11:45   #14 (permalink)
Member: 6719
same error for me, fresh win 7 64 or 32 i have atf big box with modifed pcb , i have 3x pc with same error all have amd procesor in 1 pc with intel procesor program work ok
Old 11-27-2012, 13:37   #15 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: Kfe~Labs Co.-
Thanks Meter: 568
B.R
I sure you have a Old Drivers Ftd, Watching Your Screen Shot, Is Not Stable For ATF Box If Use Older Interfaz like JAF or Mx-Key..
Dont Forget Exclude ATF Path Folder for Anti-Virus.
Polaco
Page generated in 0.24763 seconds with 9 queries
