05-07-2015, 13:22 | #1 (permalink) |
Junior Member Join Date: Apr 2015 Location: china
Member: 2383926 Status: Offline Thanks Meter: 0 | video.Lumia925 ATF jtag.The problems encountered,Please help me! Please help me! Thank you very much~! I recorded the video URL:YOUTU .BE/6MXGUKiP8co(You need to modify the right URL..Delete YOUTU Behind Space.) log: Default language ID 0x0804, LR 14 JTAG Interface Connected, S/N 0x5654947C Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 2014/9/3 15:38:00 ================================================== ======== Phone Type : Lumia 925, 925T CPU Type : Qualcomm MSM8960 Storage Type: eMMC 16/32GB Procedure : WP8 FFU Flasher via JTAG More Info : http://www.advance-box.com/ffu_flasher/ ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Cannot Halt Core! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...11010030313647393311224DC4FE502F Flash Description: Toshiba 016G93, 14.68 GiB, SN 224DC4FE, May 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (6024 Op/Sec) FFU File Loaded: RM892_3051.50009.1424.0008_RETAIL_eu_euro1_249_08_ 443141_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0xE772CB23 Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...Flash Write Error at 0x00000200, Loader Error, Code 0x72 Please send this log and "..\Logs\.log" file to support! Last edited by mengtingyi; 05-07-2015 at 13:30. |
