03-26-2020, 22:15 | #1 (permalink) |
Freak Poster Join Date: Oct 2013 Location: italy
Member: 2048673 Status: Offline Thanks Meter: 62 | ERROR: Invalid Reply Detected... 0xA0 Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : 9C4B7028D4CEE566B3018947 ERROR: Invalid Reply Detected... 0xA0 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
04-15-2020, 15:02 | #2 (permalink) |
Junior Member Join Date: Feb 2020 Location: Turkmenistan
Member: 2947512 Status: Offline Sonork: 213123213 Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : DFE359C2906DA9C6920C15F9 ERROR: Invalid Reply Detected... 0xA0 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done after reinstall windows 7 this problem please any solution |
04-19-2020, 16:05 | #4 (permalink) |
Freak Poster Join Date: May 2012 Location: Pakistan Panjab, Sahiwal
Member: 1758871 Status: Offline Sonork: Zaka Ullah Bhatti Thanks Meter: 144 | ERROR: Invalid Reply Detected... 0xA0 ERROR: Invalid Reply Detected... 0xA0 after Window install problem hellp me |
05-07-2020, 10:32 | #6 (permalink) | |
Member: 2048673 Status: Offline Thanks Meter: 62 | Quote:
Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : 9C4B7028D4CEE566B3018947 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done | |
05-12-2020, 00:27 | #7 (permalink) |
Member: 2048673 Status: Offline Thanks Meter: 62 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : 9C4B7028D4CEE566B3018947 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
The Following User Says Thank You to hassan-k For This Useful Post: |
