04-03-2010, 16:18 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: india
Member: 1102971 Status: Offline Sonork: 100.1611545 Thanks Meter: 15 | What is this MCU: V 07.23 17-07-09 RM-436 (c) Nokia IMEI: 359310022678718 Product code : 0572571 ******** Reading SimLock ******** Simlock Version : SIMLOCK SERVER CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SL2 Phone Detected... Certificate saved to : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\Backup\sl2_certificate_V 07.23 17-07-09 RM-436 (c) Nokia_359310022678718_Not Locked_75913.pm Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 27E00012 ID DWORD 1 : A3F05850 ID DWORD 2 : 7DFE2A8F ID DWORD 3 : E5298C06 ID DWORD 4 : 4F8AABB4 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 46 BootCodeLen : 61 SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00400000 (4194304) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) START READING RPL DATA Reading : NPC OK Reading : VARIANT VARIANT : Empty Reading : CCC OK Reading : HWC OK Reading : R&D OK FINISHED READING RPL DATA RPL saved to: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\backup\359310022678718\3593100226787 18_80002.rpl FlashInfo.RestartMode : 2 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__07.23.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1170 Entry Point: 0x5047 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__07.23.ppm_mr CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 454 Entry Point: 0x00B6 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__07.23.image_mr CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 528 Entry Point: 0x00C2 Page Format : -1 MAX PAGE : 0x00004000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 27E00012 ID DWORD 1 : A3F05850 ID DWORD 2 : 7DFE2A8F ID DWORD 3 : E5298C06 ID DWORD 4 : 4F8AABB4 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 46 BootCodeLen : 61 SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00400000 (4194304) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) No partition info.... No partition info.... No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x0036 (54) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x33 (51) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00040000-000BFFFF 3 : 000C0000-0013FFFF 4 : 00140000-0119FFFF 5 : 011A0000-0133FFFF ERASE_REQUEST_BB5 : 5001123300000000000000000006BF000006C00001FFFF0004 0000000BFFFF000C00000013FFFF001400000119FFFF011A00 000133FFFF8C Please wait ERASING......... >> Time Elapsed 5 seconds >> Time Elapsed 10 seconds >> Time Elapsed 15 seconds >> Time Elapsed 20 seconds >> Time Elapsed 25 seconds >> Time Elapsed 30 seconds >> Time Elapsed 35 seconds >> Time Elapsed 40 seconds >> Time Elapsed 45 seconds >> Time Elapsed 50 seconds >> Time Elapsed 55 seconds >> Time Elapsed 60 seconds >> Time Elapsed 65 seconds >> Time Elapsed 70 seconds >> Time Elapsed 75 seconds >> Time Elapsed 80 seconds >> Time Elapsed 85 seconds >> Time Elapsed 90 seconds >> Time Elapsed 95 seconds >> Time Elapsed 100 seconds >> Time Elapsed 105 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01340000-01BDFFFF ERASE_REQUEST_BB5 : 5001120B0000000134000001BDFFFFF0 Please wait ERASING......... >> Time Elapsed 5 seconds >> Time Elapsed 10 seconds >> Time Elapsed 15 seconds >> Time Elapsed 20 seconds >> Time Elapsed 25 seconds >> Time Elapsed 30 seconds >> Time Elapsed 35 seconds >> Time Elapsed 40 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. StartErase_DCT5... BlockLength : 0x0016 (22) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01BE0000-01F7FFFF 1 : 01F80000-03FBFFFF ERASE_REQUEST_BB5 : 5001121300000001BE000001F7FFFF01F8000003FBFFFF2F Please wait ERASING......... >> Time Elapsed 5 seconds >> Time Elapsed 10 seconds >> Time Elapsed 15 seconds >> Time Elapsed 20 seconds >> Time Elapsed 25 seconds >> Time Elapsed 30 seconds >> Time Elapsed 35 seconds >> Time Elapsed 40 seconds >> Time Elapsed 45 seconds >> Time Elapsed 50 seconds >> Time Elapsed 55 seconds >> Time Elapsed 60 seconds >> Time Elapsed 65 seconds >> Time Elapsed 70 seconds >> Time Elapsed 75 seconds >> Time Elapsed 80 seconds >> Time Elapsed 85 seconds >> Time Elapsed 90 seconds >> Time Elapsed 95 seconds >> Time Elapsed 100 seconds >> Time Elapsed 105 seconds >> Time Elapsed 110 seconds >> Time Elapsed 115 seconds >> Time Elapsed 120 seconds >> Time Elapsed 125 seconds >> Time Elapsed 130 seconds >> Time Elapsed 135 seconds >> Time Elapsed 140 seconds >> Time Elapsed 145 seconds >> Time Elapsed 150 seconds >> Time Elapsed 155 seconds >> Time Elapsed 160 seconds >> Time Elapsed 165 seconds >> Time Elapsed 170 seconds >> Time Elapsed 175 seconds >> Time Elapsed 180 seconds >> Time Elapsed 185 seconds >> Time Elapsed 190 seconds >> Time Elapsed 195 seconds >> Time Elapsed 200 seconds >> Time Elapsed 205 seconds >> Time Elapsed 210 seconds >> Time Elapsed 215 seconds >> Time Elapsed 220 seconds >> Time Elapsed 225 seconds >> Time Elapsed 230 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:06:19 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : rm436__07.23.mcusw Total blocks to write : 1170 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW Processing : rm436__07.23.ppm_mr Total blocks to write : 454 Processing : rm436__07.23.image_mr Total blocks to write : 528 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:20 Total Flashing Time (Booting + Erase + Flashing) : 00:07:44 Box problame ya setting help brother |
04-04-2010, 08:49 | #3 (permalink) |
No Life Poster Join Date: Oct 2009 Age: 37
Member: 1149013 Status: Offline Thanks Meter: 247 | >> Time Elapsed 5 seconds >> Time Elapsed 10 seconds >> Time Elapsed 15 seconds >> Time Elapsed 20 seconds >> Time Elapsed 25 seconds >> Time Elapsed 30 seconds >> Time Elapsed 35 seconds >> Time Elapsed 40 seconds >> Time Elapsed 45 seconds >> Time Elapsed 50 seconds >> Time Elapsed 55 seconds >> Time Elapsed 60 seconds >> Time Elapsed 65 seconds >> Time Elapsed 70 seconds >> Time Elapsed 75 seconds >> Time Elapsed 80 seconds >> Time Elapsed 85 seconds >> Time Elapsed 90 seconds >> Time Elapsed 95 seconds >> Time Elapsed 100 seconds >> Time Elapsed 105 seconds >> Time Elapsed 110 seconds >> Time Elapsed 115 seconds >> Time Elapsed 120 seconds >> Time Elapsed 125 seconds >> Time Elapsed 130 seconds >> Time Elapsed 135 seconds >> Time Elapsed 140 seconds >> Time Elapsed 145 seconds >> Time Elapsed 150 seconds >> Time Elapsed 155 seconds >> Time Elapsed 160 seconds >> Time Elapsed 165 seconds >> Time Elapsed 170 seconds >> Time Elapsed 175 seconds >> Time Elapsed 180 seconds >> Time Elapsed 185 seconds >> Time Elapsed 190 seconds >> Time Elapsed 195 seconds >> Time Elapsed 200 seconds >> Time Elapsed 205 seconds >> Time Elapsed 210 seconds >> Time Elapsed 215 seconds >> Time Elapsed 220 seconds >> Time Elapsed 225 seconds >> Time Elapsed 230 seconds |
04-04-2010, 09:21 | #5 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | @narendra22 There is no problem. You can see here: Time Taken to Flash : 00:01:20 Time Taken to Erase : 00:06:19 Erasing 7210c really takes a LOT of time. This is 100% Normal for phones with SLOW and CHEAP NOR Flash Chips. Flasing 7210c takes only 1 minute and 20 second according to your logs. This is normal time as well. If you want to speed up erasing, use a cable with external VPP connection. B.R. X-Shadow |
What is this, what effect | 1122001122 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 01-29-2010 09:18 |
what is this ? What are you trying to do?UB TEAM! HELP ME !!!! | lidergsm1 | Universalbox | 1 | 04-14-2009 18:36 |
what is this sc team ware is chi mei option and ware is imode option | rajabrotherscom | Smart-Clip | 14 | 02-16-2007 00:25 |
what is this error? anyone get this? | sergioems | UFS2 + UFS3-Tornadoflasher | 3 | 08-18-2004 11:59 |
