06-18-2015, 12:54 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Advance-Box Nokia Lumia 800 RM-801 unlock successfully .::By::. .:::Advance-Box:::. Code: 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 90014A48594E4958205C0014DB8CAE25 CSD : D04F01320F5903FFFFFFFFFF8A400001 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 8192 KB USER AREA SIZE : 15896412160 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB Lumia 800/800C Detected eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : HYNIX Product Rev : 5.12 Product SN : 0014DB8C Manufactured : January 2011 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 300 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 90014A48594E4958205C0014DB8CAE25.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Dumping Custom Region Please wait for some time... Partition Selected: USER AREA (eMMC Clock 15000000 Hz) Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... Patch OK! Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:00:28 |
The Following 3 Users Say Thank You to kabul For This Useful Post: |
06-18-2015, 14:51 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | YOU still unlocking it with Test Points? Didn't you read that this model can be unlocked with USB also? BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
06-19-2015, 08:49 | #3 (permalink) | |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Quote:
Fist IN tray usb unlock bootloader not unlocked Test Points unlock don but locked how to unlock bootloader or network lock Code: SW Version : 1750.0823.8862.13110 IMEI Plain : 359289044879084 HW Version : 112.1402.2.3 Phone Type : RM-801 Product Code : 059L8M3 Basic Product Code: 059J2N6 Module Code : 0205051 PSN Number : 003A2C0AB NCSD Version : 1.9 Variant Information: 3 UK GB v5 Black (PR2.11) ================================================ Extended Phone Information ================================================ Public ID : B7335B2B70B8A79B34A59D4EE6CC8FCD Wireless Lan ID: 14:36:05:D2:DF:68:00:00 Bluetooth ID : 14:36:05:D2:B8:58:00:00:00:00:00:00 Rebooting to OSBL MODE ERROR: Data Rejected at SEQ 0x1 ERROR: Data Rejected at SEQ 0x2 Sending OSBL Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED | |
06-19-2015, 09:27 | #4 (permalink) |
No Life Poster Join Date: Oct 2008 Age: 39
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | for me always working this method usb only... http://forum.gsmhosting.com/vbb/f609...2/#post9004291 |
The Following User Says Thank You to alex_030385 For This Useful Post: |
06-19-2015, 11:26 | #5 (permalink) | |
The Following User Says Thank You to kabul For This Useful Post: |
