Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 08-08-2014, 08:27   #1 (permalink)
Member: 636569
Thanks Meter: 192
Cool when update atf box?
when update atf box for nokia xl rm1030 fullboot 1.2.3.1 root and google service ???
best infinity dongle already support.
Old 08-08-2014, 10:09   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
Already added ROOT via Custom Recovery last June on ATF 11.50...
This should work on all firmware versions of X, X+ and XL.
Old 08-08-2014, 11:56   #3 (permalink)
Member: 651945
@lages_79
I saw 1.2.3.1 on XL is using different VID PID for USB ADB...
So better to use 11.69 which I already add the new VID PID.
AdvanceBox.exe <-------- Put in C:\AdvanceBox Turbo Flasher\
Already tested to ROOT and GOOGLE Stuff.. All working like before.
B.R.
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 08-08-2014, 12:22   #4 (permalink)
Member: 651945
Just Tested on New Firmware
Here is Launcher... also look at #SuperSU Icon:
Here is PlayStore
All Good.
Old 09-15-2014, 12:09   #5 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Hello, have one of this Lumia 930 Power OFF.
I want know if have need to install this vers. 11.69 for work with this model.
There are issues if i overwrite it in 11.60?
Link to Nokia .Ini file not work more, when can dowload Drivers for this model?, are ok Lumia Drivers from 11.60?
And last question, this phone is Power OFF, how can do for read right P.Code and RM/Sw version?, have need of open phone and try with Jtag or can Read Info from Dead Usb?
allumts
Old 09-15-2014, 12:20   #6 (permalink)
Member: 651945
@allumts
You can have 2 AdvanceBox.exe in same folder (OLD and NEW) just as long as they are not the same filename. Lumia 930 drivers normally can get it from Windows Update. Product code is inside sim tray, look for small plastic there, then pull it out. Try USB flashing first, if not work, then try to charge battery externally using USB PORT + and - directly connected to battery terminal which battery is disconnected from PCB of phone. When voltage of battery rise above 4.0v, then it should be enough to perform flashing.
AdvanceBox.exe
Nokia.ini
Old 09-15-2014, 12:43   #7 (permalink)
allumts's Avatar
Member: 1564612
Ok, i can rename also with an letter or line this other .exe, right?
In the plastic sim tray there isn't write any P.Code.
But w/o P.Code what file download from NaviFw 3.2?
Sorry, this step not understand, (i have external charger and can charge with + and - w7o battery connected to pcb), or how charge with USB cable with + and - connected directly in battery?.
Now i've connected normal Usb Charger pressed power on and device is charging, (battery was to 0%), but now is stopped in screen whre write "Sim Error" emrgency call or closed, but Touch not work.
11.69 just downloaded and also Nokia .Ini, are in same C://Advancebox.... renemed.
Old 09-15-2014, 12:58   #8 (permalink)
Member: 651945
@allumts
There is product code written inside SIM tray Socket, not the SIM tray itself. Remove SIM tray and look at the hole inside, you will see a small thin plastic, pull it out and you will see product code.
If you do not know how to charge battery externally, please do not attempt to do it. It is dangerous and I assumed you already know what I was talking about...
If your phone powers up now, then probably you do not need to flash it anymore. Just full charge it first and check touch problem later.
B.R.
Old 09-15-2014, 13:14   #9 (permalink)
allumts's Avatar
Member: 1564612
Ok, very thanks @X-Shadow, now i loock good inside Sim tray.
I never have open this model, but if i open sure that understand what you has sayng about charge batteri with Usb port.
Now phone is charging w/o problem, only this Touch not permitte of power off phone, slide down or any other command in touch.
Customer not report it, now reading good the problem, it's reporting that this Lumia 930 is also Locked, no solution for unlock it also?
Update: customers are lol....now reading where insert Sim Tray there's write RM-821 FCC ID:PYARM-821 cannot extract other Sim Tray how above photo, is wrote very small in case. No Imei or P.Code.
allumts
Old 09-15-2014, 15:57   #10 (permalink)
Member: 651945
That is a lumia 920... Not a 930
Just full charge phone and try to flash it via usb. I don't remember where product code is in Lumia 920, I left my test phone in another country.
Old 09-15-2014, 17:19   #11 (permalink)
allumts's Avatar
Member: 1564612
@X-Shadov,
Customer have send me photo of box, here there's Operator and model, but no P.Code.
From NaviFw Plus i've searched this P.Code: 059R082 and have find this original Fw for H3G Italy Black but the RETAIL file is in .ffu format.
Anyway here photo of Box of Lumia 920:
Issues important, this Lumia in this moment not respond Touch and first of enter in my shop this phone many time was Stopping w/o accepting command.
Old 09-16-2014, 04:59   #12 (permalink)
Member: 651945
@allumts
Flash it via USB when it is already full battery.
.ffu format is correct.
Page generated in 0.18881 seconds with 8 queries
