Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 06-17-2011, 12:05   #1 (permalink)
unlock phones's Avatar
Member: 1552610
Sonork: 100.1604734
Thanks Meter: 1,279
Smile WHen will be supported flashing for nokia X101 RM 713 on ATF
Old 06-17-2011, 12:09   #2 (permalink)
klmamn's Avatar
Member: 986273
Thanks Meter: 395
it is supported MAN ...........
Old 06-17-2011, 12:09   #3 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,487
Hello.
Just try flashing with currect version..
X1-00 already supported, so it should be too.
X1-00 RM-732 ATF First In The World FBUS Flashing from 4.35 to 4.55 !!!
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 06-18-2011, 11:27   #4 (permalink)
Member: 1552610
Sonork: 100.1604734
Thanks Meter: 1,279
Originally Posted by ..::Angel::.. View Post
Hello.
X1 is an other model i know that is supported but x101 is an other model that is not in the list
Old 06-18-2011, 11:39   #5 (permalink)
Member: 643472
Sonork: 100.96901
Hello.
It can be added to list.
open Nokia.in from here: C:\AdvanceBox Turbo Flasher\Nokia
add this after C1-01, save ini and open software again.
[X1-01 : RM-713]
GENERATION=INFINEON
Model=X1-01
Type=RM-713
DefaultProductCode=
Band=
Mode=USB
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 06-19-2011, 13:48   #6 (permalink)
Member: 1552610
Sonork: 100.1604734
Thanks Meter: 1,279
yes i added it thanx
Old 06-24-2011, 13:13   #7 (permalink)
swechacnu's Avatar
Member: 115144
Sonork: 100.1590698
Thanks Meter: 498
Hello.
[X1-01 : RM-713]
GENERATION=INFINEON
Model=X1-01
Type=RM-713
DefaultProductCode=
Band=
Mode=USB
Hi, Br
x1-01 rm-713 there is no usb port so can i add fbus text here (above showing text red color)
BR,
Srinivas Reddy.
Old 06-24-2011, 13:25   #8 (permalink)
Member: 643472
Sonork: 100.96901
Originally Posted by swechacnu View Post
Hi, Br
BR,
Srinivas Reddy.
My mistake @ALL, please add FBUS instead of USB
Old 06-28-2011, 08:50   #9 (permalink)
javokhir's Avatar
Member: 1020688
Thanks Meter: 59
X1-01 rm-713
Old 09-28-2011, 15:44   #10 (permalink)
drsty's Avatar
Member: 1033768
Sonork: sonork_id=100.1603335
Thanks Meter: 81
Flash file need x101 rm-713
Old 09-29-2011, 06:07   #11 (permalink)
Member: 1552610
Sonork: 100.1604734
Thanks Meter: 1,279
find here flash file of RM-713
Blue-Nokia.com by Obnoxy
Old 12-03-2011, 09:07   #12 (permalink)
..::HITU::..'s Avatar
Member: 1212089
Thanks Meter: 122
x1-01 after phone flash phone same old version
problum -
x1-01 rm-513 call log empty no missad ,no receve,no dial call.i try to flash v5.44 but after flash phone same old version 5.39 and same problum .why ? where i'm wrong ?
13:53:14 : MCU: V 05.39 01-09-11 RM-713 (c) Nokia
13:53:14 : IMEI: 359034048889469
13:53:14 : Product Serial Number: D14D36CAI
13:53:14 : Product Code         : 059D8N7
13:53:14 : Module Code          : 0204758
13:53:14 : Basic Production Code: 059L6H8
13:53:14 : PPM SW Version       : V 05.39 01-09-11 RM-713 (c) Nokia MG
13:53:14 : ADSP Version         : p+V 05.39\n01-09-11\nRM-713\n(c) NMP\nmg_nlt
13:53:15 : MCU SW Version       : V 05.39 01-09-11 RM-713 (c) Nokia
13:53:15 : HW Version           : 3051
13:53:15 : UEM Version          : 1328
13:53:15 : UPP Version          : 8850
13:53:15 : LCD Version          : WIN:BARACOAv80 NT39121
13:53:16 :   ********** SIMLOCK INFO  **********
13:53:16 : CONFIG_DATA  : 0010100000000000
13:53:16 : PROFILE_BITS : 0000000000030002
13:53:16 : ASIC         : 11
13:53:16 : PROVIDER     : Default Test Operator
13:53:16 :
13:53:17 :    Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
13:53:17 :    Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
13:53:17 :    Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
13:53:17 :    Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
13:53:17 :    Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
13:53:17 :    Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
13:53:17 :    Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
13:53:17 : ST_LCD_TEST               : PASSED
13:53:17 :
13:53:34 : VBATT Powering Down <<<<
13:53:37 : VBATT Powering Up   >>>>
13:53:37 : SET VCCIO Level Done
13:53:37 : SET BSI Load Done
13:53:37 :
13:53:37 : Booting Phone...
13:53:37 : CPU ID Response: A200341100
13:53:37 : CPU Type: XG110 2.1B
13:53:37 : Phone Booted at after First attempt...
13:53:37 :
13:53:37 : ******************************************************
13:53:37 :                  TIME STARTS HERE
13:53:37 :
13:53:37 :
13:53:37 : Sending PBL 19456 bytes...
13:53:39 : PBL Successfully Sent...
13:53:39 :
13:53:39 : Sending SBL 65024 bytes...
13:53:40 : SBL Successfully Sent...
13:53:40 :
13:53:40 : Flash Chip Manufacturer: STMicroelectronics
13:53:40 : Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
13:53:40 : Extended Information: Multiple Bank / Burst / 1.8v
13:53:40 :
13:53:40 : Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-713\rm713_005.440
13:53:40 :
13:53:40 : FIRMWARE Image Found...
13:53:40 : Number of Sections: 03
13:53:40 : FIRMWARE Certificate Block Sent Successfully...
13:53:40 : Processing Section 01 of 03
13:53:40 : FIRMWARE Erase Block: 0x00000000~0x0001FFFE
13:53:40 : Start Erasing...
13:53:40 : Erasing Please Wait...
13:53:40 : Block Erase Done...
13:53:40 : Preparing Data Blocks...
13:53:40 : Data Size: 24576 bytes
13:53:40 : Data Checksum: 55FD
13:53:40 : Uploading Data Blocks to phone...
13:53:41 : FIRMWARE Data Blocks uploaded to phone...
13:53:41 : Processing Section 02 of 03
13:53:41 : FIRMWARE Erase Block: 0x00800000~0x00BFFFFE
13:53:41 : Start Erasing...
13:53:41 : Erasing Please Wait...
13:53:41 : Block Erase Done...
13:53:41 : Preparing Data Blocks...
13:53:41 : Data Size: 4128768 bytes
13:53:41 : Data Checksum: 2909
13:53:41 : Uploading Data Blocks to phone...
13:54:40 : FIRMWARE Data Blocks uploaded to phone...
13:54:40 : Processing Section 03 of 03
13:54:40 : FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE
13:54:40 : Start Erasing...
13:54:40 : Erasing Please Wait...
13:54:40 : Block Erase Done...
13:54:40 : Preparing Data Blocks...
13:54:40 : Data Size: 1697536 bytes
13:54:40 : Data Checksum: 7639
13:54:40 : Uploading Data Blocks to phone...
13:55:05 : FIRMWARE Data Blocks uploaded to phone...
13:55:05 : Start Data Verification... (Please wait)
13:55:05 : Data Verification Successful...
13:55:05 :
13:55:05 :
13:55:05 : Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-713\rm713_005.44mg
13:55:05 :
13:55:05 : PPM Image Found...
13:55:05 : Number of Sections: 01
13:55:05 : PPM Certificate Block Sent Successfully...
13:55:05 : Processing Section 01 of 01
13:55:05 : PPM Erase Block: 0x00100000~0x0060257E
13:55:05 : Start Erasing...
13:55:05 : Erasing Please Wait...
13:55:05 : Block Erase Done...
13:55:05 : Preparing Data Blocks...
13:55:05 : Data Size: 5252480 bytes
13:55:05 : Data Checksum: 28D8
13:55:05 : Uploading Data Blocks to phone...
13:56:18 : PPM Data Blocks uploaded to phone...
13:56:18 : Start Data Verification... (Please wait)
13:56:18 : Data Verification Successful...
13:56:18 :
13:56:18 :
13:56:18 : Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-713\rm7130_nai05.44mg_nlt
13:56:18 :
13:56:18 : CONTENT Image Found...
13:56:18 : Number of Sections: 01
13:56:18 : CONTENT Certificate Block Sent Successfully...
13:56:18 : Processing Section 01 of 01
13:56:18 : CONTENT Erase Block: 0x00E60000~0x00F5D0BE
13:56:18 : Start Erasing...
13:56:18 : Erasing Please Wait...
13:56:19 : Block Erase Done...
13:56:19 : Preparing Data Blocks...
13:56:19 : Data Size: 1036480 bytes
13:56:19 : Data Checksum: DCBC
13:56:19 : Uploading Data Blocks to phone...
13:56:33 : CONTENT Data Blocks uploaded to phone...
13:56:33 : Start Data Verification... (Please wait)
13:56:33 : Data Verification Successful...
13:56:33 :
13:56:33 :
13:56:33 : Exit Flash Mode Done...
13:56:33 : Time Elapse : 00:02:55
13:56:37 :
13:56:37 : ******************************************************
13:56:37 :    You must Factory Reset the phone to enable the
13:56:37 :   ringtones and other  customized settings to work
13:56:37 :
13:56:37 :
13:56:37 : Waiting For Phone to go Online...
13:56:37 :
13:56:37 : 5,
13:56:37 : 4,
13:56:37 : 3,
13:56:37 : 2,
13:56:37 : 1...
13:56:37 :
13:56:37 : MCU: V 05.39 01-09-11 RM-713 (c) Nokia
13:56:37 : IMEI: 359034048889469
13:56:38 : Product Serial Number: D14D36CAI
13:56:38 : Product Code         : 059D8N7
13:56:38 : Module Code          : 0204758
13:56:38 : Basic Production Code: 059L6H8
13:56:38 : PPM SW Version       : V 05.39 01-09-11 RM-713 (c) Nokia MG
13:56:38 : ADSP Version         : p+V 05.39\n01-09-11\nRM-713\n(c) NMP\nmg_nlt
13:56:39 : MCU SW Version       : V 05.39 01-09-11 RM-713 (c) Nokia
13:56:39 : HW Version           : 3051
13:56:39 : UEM Version          : 1328
13:56:39 : UPP Version          : 8850
13:56:39 : LCD Version          : WIN:BARACOAv80 NT39121
13:56:40 :   ********** SIMLOCK INFO  **********
13:56:40 : CONFIG_DATA  : 0010100000000000
13:56:40 : PROFILE_BITS : 0000000000030002
13:56:40 : ASIC         : 11
13:56:40 : PROVIDER     : Default Test Operator
13:56:40 :
13:56:41 :    Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
13:56:41 :    Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
13:56:41 :    Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
13:56:41 :    Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
13:56:41 :    Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
13:56:41 :    Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
13:56:41 :    Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
13:56:41 : ST_LCD_TEST               : PASSED
13:56:41 :
13:56:42 :
13:56:42 : FACTORY SET TO : Full Factory Set
13:56:44 : FAILED
13:56:44 : FACTORY SET TO : User Data
13:56:44 : OK
13:56:44 : FACTORY SET TO : Leave Factory
13:56:45 : FAILED
13:56:45 : FACTORY SET TO : Service Center
13:56:45 : OK
13:56:45 : FACTORY SET TO : Software Upgrade
13:56:45 : OK
13:56:45 : FACTORY SET TO : Production Tune
13:56:45 : OK
The Following User Says Thank You to ..::HITU::.. For This Useful Post:
Old 12-03-2011, 09:10   #13 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,045
@HITU
Because Your flash files are not OK.
(Maybe you got flash files from another Box Support Site)
Use Navifirm to Download Flash files and try again.
Old 12-03-2011, 09:20   #14 (permalink)
Member: 651945
Download RM-713_dp_v_02_12_MCUSW05_39.zip for free on Filesonic.com
Download and install this and try it.
Here is old thread which have same problem
as you and Solved it.
nokia x1-01 strange problem - (SOLVED + GOOD INFO)
B.R.
Old 12-03-2011, 09:39   #15 (permalink)
Member: 1212089
Thanks Meter: 122
Originally Posted by Advance-Box View Post
@HITU
again flash with other firmware but same . where i download good flash file ?
plz give me link !
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.53552 seconds with 8 queries
