06-01-2016, 02:17 | #1 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Cameroon
Member: 1433726 Status: Offline Sonork: 100.1644838 Thanks Meter: 106 | Lumia 540 RM-1141 flash succesfully done with ATF Windows Phone 8/8.1/10 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ================================================== ==== Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x0A Blocks Block ID 0x01 : 00241000 Block ID 0x1F : 01 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x04 : 01DACC00 Block ID 0x05 : Nokia.MSM8212.P6247.1.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01000F0000 Block ID 0x20 : 010000000100000004 Checking SD Card Size... Card Size: 0x01DACC00 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020225023C00 UEFI App: FLASH APP Flash App Protocol Version: 2.37 Flash App Implementation Version: 2.60 Query ROOT KEY HASH... ROOT_KEY_HASH: 86ACB97612E34C682490412CE98BAAD27779008E2189E5FB38 665BBF1476EC98 Query PUBLIC ID... PUBLIC_ID: 2CD1CC0E3385FAA7931B81EF6F676192C88495A7 Query eMMC Info... EMMC Manufacture ID: HYNIX EMMC Product SN : A159E93F EMMC_SIZE: 8 Gigabytes Query Battery Charge Status... BATTERY CHARGE_STATUS: 54% Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Fixing Partitions... Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:07:08 |
The Following 3 Users Say Thank You to hotech For This Useful Post: |
11-01-2018, 18:12 | #3 (permalink) | |
Freak Poster Join Date: May 2012 Location: Pakistan Panjab, Sahiwal
Member: 1758871 Status: Offline Sonork: Zaka Ullah Bhatti Thanks Meter: 144 | nokia lumia 540 rm-1141 Flash Done with ATF box Done Windows Phone 8/8.1/10 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ Quote:
By Zaka Ullah Bhatti | |
The Following User Says Thank You to bhatti123 For This Useful Post: |
