Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-16-2017, 13:08   #31 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
UPDATE OF 16/03/2017
Those are still facing server problem >>>>>
Delete " hosts " file from C:\WINDOWS\system32\drivers\etc
Try to update box & post result
Old 03-20-2017, 16:05   #32 (permalink)
Member: 2220893
Thanks Meter: 8
please help he
i have atf (big)new brand from gsm server and i try update firmware but every time have same issue (query result - not found)
i try in 2 pc win 7 32 bit and win 10 64 bit
now i tried in laptop win 10 32 bit without antivirus and disable windows defender.
I use ATF_v12.60_Full_Installer whit and whitout update v12.67
update drivers and reinstall box
update important files
run as administrator
deactivate antivirus and firewall
box is already activate
add line in hosts file
restore box
Imgur: The most awesome images on the Internet
Old 03-20-2017, 16:46   #33 (permalink)
allumts's Avatar
Member: 1564612
Originally Posted by Friendscomputer View Post
please help he
restore box
You will have Wiew Problem for NOT to see my above UPDATE in post #32
THIS NO lol:
Old 03-21-2017, 06:18   #34 (permalink)
Member: 2220893
Thanks Meter: 8
ATF SERVER ERROR
please help he
restore box
Old 03-21-2017, 06:20   #35 (permalink)
Member: 2220893
Thanks Meter: 8
ATF Error SErver connection
Old 03-21-2017, 06:26   #36 (permalink)
Member: 2220893
Thanks Meter: 8
ATF server show error i chek all method of Gsmhosting
Old 03-22-2017, 05:21   #37 (permalink)
Member: 2220893
Thanks Meter: 8
Atf server connection problems
Originally Posted by allumts View Post
What Browser are using?.....
Dear sir Kindly chek my problem and Give me solution i alrady chek all gsmhosting method but no luck
ATF box error mention
My box not problem Driver here is img
here is Main ATF box page
http://imgh.us/2_2917.jpg
Now i try to update box firmware but Give this Error
here is screen short
And also host file Secreen short
Iread From gsmhosting page Delete host file from windos system32 driver etc folder host file when i delete host file then give me this Error
http://imgh.us/4_2172.jpg
i hope you will give me Ans At once Thank you
Old 03-23-2017, 05:19   #38 (permalink)
Member: 2220893
Thanks Meter: 8
Sir i use 2 pc and one laptop one pc windows xp sp3 and an other pc&laptop have windows7
i use Defult brwoser internet explorer
scond pc i install google chorm
3rd pc i install firefox google chorm and latest internet xplorer i try to udate box firmware without instaling any antivirus but same progress no luck no update Error server connection when i edit host file
when i delete host file then show Query Result not found
Old 03-23-2017, 13:45   #39 (permalink)
Member: 2087466
Thanks Meter: 3
Connecting to the atf network, invalid response. I can't authorize phone, what is with servers?
Old 03-24-2017, 06:57   #40 (permalink)
Member: 2220893
Thanks Meter: 8
ATF show Error server connection
[YOUTUBhttps://https://*********/yhyea9eGGUY/yhyea9eGGUYTUBE]
Old 03-24-2017, 12:38   #41 (permalink)
Member: 2220893
Thanks Meter: 8
ATF Server Error
Chek Detail
http://www.youtube.com/watch?v=yhyea9eGGUY
Old 03-27-2017, 09:33   #42 (permalink)
Member: 619251
Thanks Meter: 19
pls help me why i restore box , atf server said need 49 credit for active . this box is actived
Untitled - Up ?nh nhanh không c?n tài kho?n
Untitled1 - Up ?nh nhanh không c?n tài kho?n
Old 03-30-2017, 08:29   #43 (permalink)
Member: 2098615
Sonork: 100.1585406
Thanks Meter: 2
..........still facing server problem.........
ATF box error query result not found
Old 03-30-2017, 17:26   #44 (permalink)
Member: 712150
Thanks Meter: 31
Last time posting samethings.
For all that have issue in Update Fw, Autoupdate or Server Not working, (for you, server is always working).
Try in this mode First of any above procedure:
Disable AV when "AUTOUPDATE".
First go to: C:/Windows/System32/drivers/etc/Hosts
Open this file "Hosts" with Notepad
Add these line:
Save and turn back to restart Atf Sw and try now to "AUTOUPDATE", "UPDATE FIRMWARE" itc...
NOTE: If have OLD version of ATF, Uninstall all, delete all folder Atf, then Launch Last "Full Install 12.60" and continue with above procedure.
WARNING: who not is able or haven't enough knowledge in Windows, please not do mistake and ask help to who is able in this.
Post result
allumts
br i am not understand it because my problem is
Please Try Again Later (Server Busy)
ATF SOFTWARE IS NOT ACTIVATED ON THIS PC
Please Activate your ATF Software
* Follow these Instructions
1. Connect this PC to the INTERNET
2. Restart ATF Software
Box Successfully Initialized
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
how can resolve this problem
Old 03-30-2017, 18:21   #45 (permalink)
allumts's Avatar
Member: 1564612
When Server isn't more BUSY you will do anything
Page generated in 0.29361 seconds with 8 queries
